Water cooling contraption
30xs
Re: Water cooling contraption
Post by 30xs »
Yummyrum wrote: ↑Fri Nov 13, 2026 11:16 pm I’ve never really looked at using a radiator as a cooling device as have always had ample water . But it seems that the car radiator makes the most sense .
Typical 100kw IC engine is at best 30% efficient ( turned into movement ) . Roughly 30% goes out the exhaust as heat and the remaining 40ish% engine block heat gets cooled by radiator .
So hell , if a car radiator can remove 40kW of heat , that has to be a winner . :thumbup:
And a car stopped at the lights is probably idling and so the thermatic fan kicks in . Removing a good 5-10kw while it’s stationary .
I think I see a new project . I guess it does involve Glycol . I wonder if using water in a non pressurised system would provide the same level of heat removal .
And a safety plug about using food grade Propylene glycol as apposed to poisonous Ethylene glycol which is the common car radiator coolant. .
All I used was water, no glycol. It was in a basement so no fear of freezing. The water did cook off its chlorine content, so an additive to help keep algae from forming would be a beneficial, even if it’s just a splash of pool chlorine or bleach.
Empty Glass may have been the one that I followed on my design. The idea came from this forum, I just adopted it. The radiator I used was a 1992-2000 Honda civic 3 row core. I think it was about $70 brand new off of eBay back then.
Speaking of cooling efficiency. A typical IC engine in a car uses a thermostat to maintain a preset temp. It will regulate flow to keep a set temp. I’ve seen a few engines overheat due to not having a thermostat. The water doesn’t get enough time in front of the fan before going back to remove more heat. That’s why I say keep the water flow to a minimum on the condensers to maximize efficiency. It will heat up an area a bit. A small shed may want to plan accordingly for the extra heat.
Username
Post by Username »
30xs wrote: ↑Sat Nov 14, 2026 12:50 am The radiator I used was a 1992-2000 Honda civic 3 row core.
It's not really clear from the pic 30xs, is that an additional fan mounted behind the radiator or have you got the radiator fan hooked up to a power supply?
30xs
Post by 30xs »
Username wrote: ↑Sat Nov 14, 2026 1:06 am
It was a 30 year old 3 speed box fan pulling air through the radiator. Usually ran on low or medium speed, I didn’t even have a makeshift shroud on it.
Edited to add that the box fan was chosen for two reasons. 1 I had it. 2 it’s a hell of a lot quieter on the lower speeds than most (cheap) automotive fans. Auto fans are also smaller requiring a shroud t make sure air is traveling through the whole cooling area.
BigSwede
Post by BigSwede »
I am the very famous definition of insanity: “...doing the same thing over and over and expecting different results”
Most guys who have had success do this as a condenser, or have a higher cooling capacity, like a car radiator. All I want to do is tame my reservoir heat just enough to do a modest run with a big poly trash can reservoir.
These elements have 0.875" / 22mm OD copper tubing. I'm hoping the relatively slow trickle and long dwell time as the condenser-out water moves through 2 meters of the stuff will remove enough heat to make it viable.
I'll slap something together and try it in a few days. Will report the probable failure back here. :tired:
Corn Cracker
Post by Corn Cracker »
A fan blowing through that tankless water heater heat exchanger in the op helped a bunch, i think your set up is gonna fit the bill just fine, 2m is at least twice as much as that thing
30xs
Post by 30xs »
BigSwede wrote: ↑Sat Nov 14, 2026 4:38 am I am the very famous definition of insanity: “...doing the same thing over and over and expecting different results”
I’ve always admired your approach. I’d say more of an outside the box thinking strategy instead of insanity. With some of the cleanest craftsmanship around.
In my hillbilly thinking I would believe you will see some returns over 2m, and eager to see how much. Large volume reservoir will help. 3/4” will be a slower flow rate, but also a thicker column to try and pull heat from. The thinner the wall thickness the better.
For a heat exchanger, what counts is surface area exposed to the air.
Per dollar of investment, a small radiator or even a heater core has more area than finned tubing.
Finned tubing is also long and narrow, there for more difficult to flow air through.
Here's how I would build a Water cooling contraption.
Homesweethome
Post by Homesweethome »
I never have such a problem, but if you want to dump heat during too warm periods you obviously need to find a good, big cold sink.
In summer the very best, for free, cold sink can be found in the underground soil.
During summer the coldest soil temperature can be found at around 3 meter (10 feet) deep, depending where you live.
Shady , wouldn’t it be better having water entering bottom and exiting top ?
That would ensure the whole radiator was full of water rather than it just dribbling down through a few channels near the cap .
30xs
Post by 30xs »
Only thing I would change on Shady’s is put a loop in th return to keep the radiator full. :thumbup:
Edit to add I prefer pulling air through the radiator vs pushing. It allows me to direct the hot air where I want it and I think it should be more air through the radiator without a shroud when pulling.
30xs
Post by 30xs »
Yummyrum wrote: ↑Sat Nov 14, 2026 2:17 pm Shady , wouldn’t it be better having water entering bottom and exiting top ?
If you look at my picture on page 2, the copper tube from the bottom is return. It just sets the water level inside the radiator. I’m not completely full, but didn’t have a cap at the time to be able to extend it higher. Worked well enough that I didn’t bother extending.
:thumbup:
30xs wrote: ↑Sat Nov 14, 2026 2:19 pm IMG_4570.jpeg
Damn I forgot about gravity. :lol:
Here's another way to plumb a heat exchanger, it would keep the radiator full, but I think it would have efficiency problems.
The radiator should be on the hot end of the condenser where the temp is highest, for delta T reasons.
In this drawing the HX is chilling the water from the hot reservoir before it goes to the PC.
Not the best but it wouldn't require any water traps to keep the HX full of water.
30xs
Post by 30xs »
shadylane wrote: ↑Sat Nov 14, 2026 6:04 pm Here's another way to plumb a heat exchanger, it would keep the radiator full, but I think it would have efficiency problems.
It would delay the need for a fan early on until the reservoir heated, but like you said the lower delta would probably hurt efficiency. With a 20 gallon reservoir once everything settled in held a fairly steady temp. I was running CM and although it wasn’t regulated mains stable it wasn’t a hair pulling adjustment battle every jar either. I’d definitely opt for cooling returns if possible.
30xs wrote: ↑Sat Nov 14, 2026 6:55 pm
Lower delta T, the pump has to overcome the natural thermosyphon effect, and survive higher temps.
But other than that, it would work. :lol:
30xs
Post by 30xs »
Running that way it would likely heat up the reservoir faster. You’re pumping the coldest water off the bottom while returning hot water with no cooling effect. The whole tank would have to be hot before you were actually cooling something before sending it to the condenser. The temp gradient of the barrel would actually be working against the cooling system.
BigSwede
Post by BigSwede »
It's done. I've got as efficient a placement as possible between the two finned sections and the fan bank.
Condenser water goes in the hose barb, fills the "U" shape, and exits like a faucet back into the reservoir. I've got a thermowell at the condenser out port, and a meat thermometer at the exit of this thing should show how it's working.
Hopefully, I'll try it tomorrow with an aggressive strip.
30xs
Post by 30xs »
Looks tidy. Hopefully those are the quiet muffin fans. :D
Looking good Swede. :thumbup:
honnsmannen
Post by honnsmannen »
would it not be that the engine creates around 330kw of energy, 30% going to the crankshaft(100kw), and 30% to the exhaust leaving 133kw to be vented through the radiator, since the engines power is measured at the crankshaft or the wheels. so a car radiator rated for a 100kw engine should be able to handle 133kw of load. given that the inlet temp to the radiator is ~80 degrees or whatever the optimal engine temp is.
Corn Cracker
Nice and tidy, perfect!
honnsmannen wrote: ↑Sun Nov 15, 2026 3:20 pm
well if a radiator can dissipate 133kw , it should have no problems dealing with a pissy 6kw stripping run :ebiggrin:
BTW , that cooler looks great Bigswede . Hope it does the job for you .
BigSwede wrote: ↑Sun Nov 15, 2026 10:11 am
It's done.
What pump is going to be used?
BigSwede
Post by BigSwede »
shadylane wrote: ↑Sun Nov 15, 2026 7:43 pm
It's done.
A Little Giant pump external to the reservoir to avoid pump heat dumped into the water. The output is throttled with a ball valve. I'll try to figure out if more or less flow is best.
I think a flow slow enough to do the job properly will deliver the hottest water to the heat exchanger, and take advantage of delta T.
BigSwede
Post by BigSwede »
I ran a stripping run with the contraption today. The goal was a fast strip, closed loop, no water swapping. Very satisfactory.
Some numbers for those inclined:
Basic pot still, Boiler charge - 11 gal sugar wash, 10% ABV
Power - 3.5 KW
Reservoir - ~30 gallons
Elapsed time from 1st drop - 2 hours
Spout ABV when terminated - 12%
Low wines Collected - 9.4 liters / 2.5 gal
I slowed the water significantly down from what I would normally do, until the condenser water out was ~ 70 C / 158 f. It exited the gadget at 50 C / 122f. So, a respectable drop of 20 C / 36 f. and held this 20 degree drop throughout. No problems with incomplete condensation, and the product temp peaked at the very end to 33 C / 91 f.
I tried to calculate the efficiency of the gadget with total energy numbers, and canned that as too complex. Much easier was the flow rate, temp in vs. temp out of the exchanger. A 20 degree C drop at 66 liters/hour = 5200 BTU/H
The spec sheet on 6 feet of these things (no forced air) at 160 degrees is around 3,000 BTU/H. Seems like the forced air greatly improved the cooling.
My conclusion - I'll strip with it. For less frequent spirit runs, I'll use hoses for safety and consistency, since the supply will be at a fixed temp rather than gradually rising the whole time.
For fun, I did some thermals...
BigSwede
Post by BigSwede »
These thermal pics always seem to exaggerate heat difference. Just a couple of degrees and it looks like a volcano vs. a glacier.
Here, the water is entering on the right, and exiting on the left.
The water being dumped into the reservoir looks like lava!
Kind of fun to see this aspect of the hobby.
Corn Cracker
That is really cool seeing it in thermal.
Sounds like it all worked out great
Is the 30gal reservoir necessary?
