Rhum Miel
Anything to do with rum
TDick
Rhum Miel
Post by TDick »
Username wrote: ↑Sun Nov 08, 2026 9:09 am Enjoying a few days in the Canary islands. Ron miel has come to my notice, it's a honey rum liqueur.
I'm on the road this week but still checking and reading a lot. But even before I've been thinking about what to do with gifted local honey.
Used it last year to sweeten WineO's. Not unlike cough syrup. And I'm afraid simple distillation will strip out the honey character.
One of the great things about "micro distilling" with the Vevor Water Air Still is that it's great for small scale experiments.
I'm NOT going to corrupt Bill's SBB Rum thread with "I followed his recipe EXCEPT.....". I know it rightfully pisses him off. :evil:
When I get home, my idea for Rhum Miel Gen 1.
Jack the Honey
(no pectin so should be minimal methanol)
3:1 Water to Honey using 16 ounce (1 pound) Dark Honey with 1 Tablespoon Saf Instant Gold Level Yeast
Day 3 - Yeast bomb with 1 TBSP Dead Gold Level and pinch of Epsom Salts.
Give it plenty of time to settle. Move to Plastic Bottles to Jack. Save the Trub.
Freeze 24 Hours then pour off the Jack. Add the Ice Melt to the Trub.
Once jacking is completed, let it rest while fermenting the Rhum.
Preparing the Rhum
1 Gallon Feed Grade
1 Gallon HOT water to rinse out Molasses jug.
1/2 Gallon of previous run Feed Grade Dunder
Add trub and ice melt, plus water to 3.5 gallons.
Pitch Saf Instant Gold Label and add 3 Oyster Shells
(with trub and ice melt, MAY NOT need Yeast Bomb.)
Weather has gotten cooler so two weeks to ferment and settle.
Slow runs - 3.5L in VW Vevor Water Distiller. Toss fores, narrow cuts, save heads & tails for feints runs.
Saltbush Bill wrote: ↑Thu Jun 28, 2018 11:59 pm This is the way that I have made my rum for the last 4-5 years.
I’ve made this wash in many sizes from 28L/7.4Gal up to 180L/ 47.5 gal , it should scale up to any size you want without trouble.
I sometimes single run this wash through 4 plates , other times I strip a wash or two and then mix them 1/3 strip to 2/3 wash. Both ways give good results.
Here's where I'm unsure of how EXACTLY to incorporate Bill's 1.5 distilling into multiple small batch runs using the Air POT still .
When the rum is completed, test blends with the Honey Jack for ratios and see if I want to back sweeten with light honey.
3 Rounds of Nuclear Aging with oak chips.
Put it to rest.
Comments & Suggestions?
Re: Rhum Miel
I'd be running 100% low wines in a pot still.
Plated column is different.
Re: Rhum Miel
T
Why have you called this Rhum Miel ?
I thought Rhum was made using crushed sugar cain juice whereas you are basically just making an all Molasses Rum .
I am a bit confused though . Have I got this right , you are fermenting the Honey first , then jacking it and adding it to the Rum fermentation . ???
Sorry , my reading comprehension score at school wasn’t very good . :oops:
TDick
Re: Rhum Miel
Post by TDick »
Yummyrum wrote: ↑Mon Nov 16, 2026 3:54 am T
I thought Rhum was made using crushed sugar cain juice whereas you are basically just making an all Molasses Rum.
Good Morning!
You are not wrong!
Although technically Rhum is just Rum in French, my original intent - and it may be for GEN 2 -
was to use the Jaggery Sugar that is described as "Cane Sugar Juice".
And since everything I do is sort of "faux" I take liberties in the naming.
Since I am NOT following SBB's recipe, but I've seen it, simple Honey Rum would be more accurate, except for our French members.
:lol:
Username
Re: Rhum Miel
Post by Username »
I'm sure this will be a much nicer spirit than the Ron miel I'm talking about Tdick
