question regarding mashing at a lower temperature.
honnsmannen
Post by honnsmannen »
Hej homedestiller forum.
I have finally taken the first step toward making proper whiskey. For this batch, I prepared two 25-liter buckets, each containing 7.5 kg of malt. I monitored one of the buckets closely, adding fresh hot water as needed to keep the temperature within the 60–65°C range. By the time I got to the second mash, it was late and I was feeling a bit lazy; I added 70°C water, checked that the temperature had settled at 65°C, and then went to bed. The next morning, both mashes were at about 40°C. A few days later, I stirred both buckets and noticed that the consistency in the monitored bucket was much thinner than in the unmonitored one. I am fermenting on the grain, as I plan to build a thumper before I run these batches.
With that background, here is my question: Do you know how much less efficient enzymes become at sub-optimal temperatures? Or will they continue to work as long as they remain in the mash? Fermentation is active in both vessels, but it is significantly more vigorous in the one I monitored. I just hope the time spent on the second bucket wasn't a complete waste.
Thanks in advance!
This post was translated using google translate, so if there is any weird word choises, thats because it was originally written in swedish. :angel:
Re: question regarding mashing at a lower temperature.
Post by Novice »
What did your iodine test show you?
Username
Post by Username »
I'm sure you will be fine, ideally wrap the bucket in a blanket and stay away from it for an hour, it will hold temperature good enough.
Beta Amylase will work well down into the 50's, in your case, so not a waste of time at all. May be not as efficient a conversion but I'm betting it's very fermentable
A gravity reading would have pretty much answered this question for you and allowed you to figure out the abv of your mash after fermentation is complete. Not 100% necessary but I like to have that information, I know what to expect from my stripping run and can be sure of not exposing my elements
PalCabral
Post by PalCabral »
Since you didn't mention using enzymes I am going to assume you didn't add any and relied fully on the enzymes in the malt itself.
For malt, the optimal mashing temp to produce fermentable sugar is really around 62/63C, and your first batch probably got a lot of time at that temperature, giving the beta amylase time to convert starch to maltose. Your second batch most likely spent a bit more time above 65C and the alpha amylase in your barley malt will have converted some of that starch to unfermentable dextrines. Since you're not using glucoamylase in your mashing, the dextrines will not have been split into glucose which is fermantable. Most likely, the monitored batch will ferment out, but the other may land a bit short of 1.000. Not to worry, unless it is above 1.020 or more when it stopped fermenting, you can still use it.
A couple of tips:
- get glucoamlyse for the next time and add it when your mash is cooling. GA is temperature sensitive so check the brand's instruction. Often it can only be added at and below 60C. But use it, it's the best safety net and it works really well making unfermentable dextrines into fermentable glucose.
- get yourself a hydrometer and measure the gravity before adding yeast and after fermentation, so you know what you're dealing with.
- If you are unsure if you converted all the starch or not, use iodine (jod) to test the presence of starch in the mash. It is a good way to know if your mashing is done or not. Unconverted starch in your mash may cause scorching when you're running.
honnsmannen
i have meassured the gravity of my mashes now, the monitored one has fermented down to 1.010 SG and the unmonitored one read 1.070. i will se if i can get my hand on some glucoamylse and some iodine to check if i have converted all the starches. could i just add the GA to my fermenter and wait, or do i have to heat my ferment up to some temp? i have added some water to relive some stress on the yeast in the unmonitored ferment. I added an un even amount of yeast to each batch, since i split a bag, and accidentally split more to the monitored.
PalCabral
Post by PalCabral »
honnsmannen wrote: ↑Sat Nov 21, 2026 10:34 am i have meassured the gravity of my mashes now, the monitored one has fermented down to 1.010 SG and the unmonitored one read 1.070. i will se if i can get my hand on some glucoamylse and some iodine to check if i have converted all the starches. could i just add the GA to my fermenter and wait, or do i have to heat my ferment up to some temp? i have added some water to relive some stress on the yeast in the unmonitored ferment. I added an un even amount of yeast to each batch, since i split a bag, and accidentally split more to the monitored.
Yes, often GA can work during (in parallel with) fermentation, but check the brand you can get hold of to see what is the temp range. You can raise the temp on the unmonitored batch but then you will need to re-pitch more yeast.
Username
Post by Username »
honnsmannen wrote: ↑Sat Nov 21, 2026 10:34 am the unmonitored one read 1.070.
That suggests it hasn't fermented at all or very little, going by your figures.
How quickly was the temperature dropping in the 1st mash?
Is it possible there was an uneven split in the weight of the malt and more ended up in the second mash?
honnsmannen
Username wrote: ↑Sat Nov 21, 2026 11:16 am Is it possible there was an uneven split in the weight of the malt and more ended up in the second mash?
yes, it would appear so.
i did not do any active cooling, i just put the buckets on the shelf and let it cool over night. Both buckets were around the 37-40 degree range. the second mash was hotter since it had less time to cool down.
something in the bucket is fermenting since the airlock is active, but another packet of yeast might be in order. As well as the Glucoamylse.
PalCabral
Post by PalCabral »
Could be lacto?
