Using a rice cooker heating element for my still?
x5XLReconFanx
Post by x5XLReconFanx »
I've got a big 60 cup commercial rice cooker that I can remove the rice cooker pot from and place my little stock pot still in instead. I want to do this because, since I can plug the rice cooker in anywhere there's an outlet, I could use my still outside of the kitchen and avoid the wrath of my housemates who aren't fond of me occupying the kitchen with my science experiments for hours at a time.
My question is, is this a terrible idea? My main concerns are:
-Temperature control, because the rice cooker only has "cook" mode and "warm" mode which boil or keep the contents at 160 F respectively. cycling this on and off would be annoying and imprecise.
-Possible fire/explosion risk? from the little bit of research I've done on this, there might be tiny sparks when the heating element on the rice cooker turns heat on and off and if my DIY still isn't perfectly sealed (despite my best efforts), that could be bad I reckon.
Any insight on whether this is a horrible idea or not would be appreciated :mrgreen:
Re: Using a rice cooker heating element for my still?
Give it a try, see if the rice cooker has enough power to bring a stockpot 3/4 full of water to boil.
x5XLReconFanx
shadylane wrote: ↑Wed Oct 28, 2026 11:32 am Give it a try, see if the rice cooker has enough power to bring a stockpot 3/4 full of water to boil.
Doing a test run with water seems like a great idea, I'll see what happens!
BigSwede
Post by BigSwede »
I believe the way a rice cooker works (might be very wrong here) is that it applies power to achieve a boil, 100C give or take, and once the temp goes above that, it tells the cooker "water boiled away, rice is done, turn off heat."
So - it might just power on full blast since a wash boils below 100C. The cooker thinks "this is one stubborn, big pot of rice." Might be worth monitoring the temp and ABV when used with ethanol, and obviously turn it off when complete.
I think you might be 100% right Big S
x5XLReconFanx
BigSwede wrote: ↑Thu Oct 29, 2026 3:56 am I believe the way a rice cooker works (might be very wrong here) is that it applies power to achieve a boil, 100C give or take, and once the temp goes above that, it tells the cooker "water boiled away, rice is done, turn off heat."
I'm planning on keeping it on the "cook" mode until i start to see drops, then putting it on the "warm" mode which will hopefully be about the right power to keep it at a good temp if I bump it back up to cook mode occasionally (kinda "throttling" it). We'll see how it goes this weekend I suppose, I'll keep the fire extinguisher handy :lol:
x5XLReconFanx wrote: ↑Thu Oct 29, 2026 11:49 am (kinda "throttling" it)
A still needs constant steady energy input to the boiler to work properly.
I suspect the "warm" setting isn't going to have enough power to keep the pot boiling.
I agree with all comments above .( based on the rice cookers we’ve had for last 20 years)
Cycling between cook and warm is not going to result in a nice spirit . Get a power controller . Our little rice cooker is only 400w . I think yours is a bit bigger , but even so , an off the shelf power controller that can easily handle that will be cheap as chips.
EDIT: just looking around , seems 60 cup (6Litre) rice cookers seem to typically have a 1950w element for cook and 85 watt for warm.
So something like this would be fine
https://kegland.com.au/products/gen2-24 ... controller
x5XLReconFanx
Yummyrum wrote: ↑Thu Oct 29, 2026 1:10 pm I agree with all comments above .( based on the rice cookers we’ve had for last 20 years)
Awesome, I'll see if my local brew supply shop has something similar (and do some research on how to use a power controller). Thanks for helping!!
fizanahmed
Post by fizanahmed »
I agree with the advice above, especially the water test and the power controller. A rice cooker is designed to boil water and then switch to warm, so it will not give the steady, controlled heat a still needs on its own. Testing with water first is a cheap way to see if it can even bring a full pot to a rolling boil, and if it cycles on and off a lot, the spirit will suffer and the run will be hard to control. A simple power controller, as Yummyrum suggested, is the usual fix, and it is worth getting one before you put any wash through it. Safety first too, as you said: make sure the element and wiring are sound, keep the still well ventilated, and do not leave it unattended while it is running.
Johnny_Mac
Post by Johnny_Mac »
How big a pot do you have? I think you can pick up a hot plate on Amazon for pretty reasonable.
Something like this?
https://www.amazon.com/TOPWISH-Electri ... 0aWM&psc=1
"I have not failed. I've just found 10,000 ways that won't work." — Thomas A. Edison
