First reflux run from low wines
Nash20x21
So I completed my first reflux run from low wines yesterday.
I fermented ~175L of shady’s sugar shine aug 18-24. First strip was aug 31, second 1st, last run was one the 2nd. Then it sat in carboys until yesterday.
Charged the still with ~10 gal of 40% low wines and spent the day switching out jars.
I wasn’t expecting azeotrope as my first run (from wash not low wines) only came off at 90 despite running it very slowly. My 3” column is also only 54” long, 6” short of the recommended length to achieve azeo.
To my surprise it was coming off at 96-97 the whole run (after temp correction). I was very excited to see that and it might be a testament for scoria!
I used an rv pressure regulator to reduce surging as recommended by smf, and I gotta say that was a game changer, much better for maintaining equilibrium.
Now the only thing, is twice I had a small wiff of vapour coming through my pc. I would quickly open the water up then slowly turn it down until I had a nice temperature gradient mid condenser and distillate was roughly finger temp. After it happened the second time I didn’t turn it back down and was taking product off around 10*C, I didn’t want to risk the vapour. I wonder if some dirt from the hose or something occluded the tap for the pc? I don’t need much water flowing through so I bet the opening in the tap is quite fine.
Anyways, that was my first run and I’m very pleased with the results. Time to confirm my cuts today, proof it down, and tuck it away to mellow!
Can’t say thanks enough to everyone who made this possible, a great community I’ve stumbled across! Cheers!
Variety is the spice of life - William Cowper
- BigSwede
Re: First reflux run from low wines
Congrats! That's a big ferment, and some very nice results.
Scoria is one of those packings that is recommended and used quite a bit by members here, and seems excellent. I've not tried it myself. I'd like to, one of these days.
Anyway, great job!
Not familiar with this. Are you referring to a pressure regulator for reflux and condenser water? Interesting.I used an rv pressure regulator to reduce surging as recommended by smf, and I gotta say that was a game changer, much better for maintaining equilibrium.
Did you actually see vapor or detect it with a mirror or glass at the output? There's always smells coming through during a run that may not be escaping vapor. Just having several jars open to the air might cause a smell that could be interpreted as a leak or lack of condensation, I'm thinking.Now the only thing, is twice I had a small wiff of vapour coming through my pc.
Anyway, great job!
Nash20x21
Thanks BigSwede!
It was a little intimidating but really it’s not too much time or money invested until you fire up the still. I think I was under $50 and maybe an hour or so to get the fermentation going.
For the ferment, I set the barrel on a piece of 3” sm foam, taped a couple seedling matts around the base of the barrel that were controlled with an old inkbird I had, wrapped an insulated tarp around it and let it go. I actually had to open the tarp up for the first couple days!
Yes the pressure regulator is for the water supply for the condensers, it helps prevent the surging water pressure when someone turns on another tap, water pump comes on etc.
This being my first real run I was watching like a Hawk and actually saw a small (think breakfast sausage) cloud of vapour come out the pc, I touched the pc and found it warm right to the end. After the second time I saw this, I didn’t taper the flow and just left it cold.
Next run I plan on leaving the hoses disconnected for a short interval while I flush them. I believe a needle valve is also in order. While I didn’t have the buffering while the still was in reflux, I experienced it periodically through all of my stripping runs. Mind you, I didn’t have the rv pressure regulator yet. I had ordered it after my first strip but it took more than two days to arrive and by then I was done stripping so I’ve yet to use it in pot mode.
- BigSwede
Sounds good. I think the chances of dirt or blockage in a condenser circuit are pretty low using tap water or any source fit for consumption, but you never know.
The pressure issue makes sense. I've not run a system requiring precise water flows yet, mainly just beat vapor into submission, but I've always liked the notion of two valves in a line if needed. One main valve is a coarse valve that delivers the bulk of the flow, and between that valve and the condenser, tee off into a needle valve or something with fine control that dumps some small % of the flow into the waste line. Just a thought.
Have fun! What's the goal for the neutral?
I'm always amazed at the amount of heat self-generated by a big ferment. My recent sugar wash held 6 to 8 f. above ambient for a good 3 or 4 days, with zero insulation, just a big metal vat.For the ferment, I set the barrel on a piece of 3” sm foam, taped a couple seedling matts around the base of the barrel that were controlled with an old inkbird I had, wrapped an insulated tarp around it and let it go. I actually had to open the tarp up for the first couple days!
- Salt Must Flow
For controlling water flow to my condensers, I've used 1/4" Brass Needle Valves on my 3" VM and 3/8" Brass Needle Valves on my 4" VM for each condenser (reflux condenser and product condenser). They worked well for years, but I noticed a significant fluctuation in flow rate (waste water) because I use well water and send the hot water down the drain. I also detected this by observing temperature fluctuations with thermowells in each condenser's water outputs. I did try using two brass needle valves in series, but it didn't appear to solve the annoying fluctuation. I then installed one of those RV Water Pressure Regulators. This greatly reduced the fluctuation and made the water flow much more stable after some adjustment. With some more patience & adjustment it may reduce it more if not eliminate it entirely. Don't know yet. I remove the regulator for stripping runs because it requires a higher water flow rate and I'd prefer to leave the pressure adjustment alone. One day I'll install a bypass for the regulator so I don't have to remove it for stripping and reinstall it for Spirit Runs.
Just for fun I bought one of these 2-0.2 LPM Water Flow Meters to see if it could replace one of my brass needle valves. It turned out to be the BEST needle valve I've ever tried with water. It was super precise with a high degree of resolution. It also gave me a visual reference to what the flow rate is as well as fluctuations. The brass needle valves worked, but had a very short range of useful adjustment during a run. Small adjustments made relatively large difference in flow rate. I don't 'need' this flow meter, but I appreciate the quality of the valve the most.
Nash20x21
What pressure do you like to run in reflux SMF?
I think the needle valve will help because I hardly have any water flowing through the product condenser and it’s hard to fine tune the barely open ball valve. I was going to use a 1/2” needle valve simply because that’s the size of the water inlet on the pc but a 1/4” will be much easier to find! Thanks again for another tip
goof stuff Nash .
You mentioned that you were surprised to get Azeo with the slightly shorter than optimum column length , but as you found out , it is only a guide line and depending on your packing and how fast you take off product , you can still kick goals .
I noticed you have a VM still ( although you posted in the CCVM section if the forum )
Don’t get too hung up on condenser flow rates .Especially the PC .
I’ve run the PC and RC in series for over 15 years now and as long as there is enough flow to keep the RC happy , the PC will be too .
I have about zero temp gradient in my PC . It is as cool at the top as it is at the bottom .
VMs are the most tolerant to pressure fluctuations of all the reflux still head designs .
The RC is the trickier one . As you found , if there is insufficient water flow , then vapour will puff out the top .
If the flow is too hard , it can over cool the reflux which effectively reduces the height of the packing .
You ideally want the reflux falling of the RC at close to condensation temp . But thats easier said than done .
In practice , find the flow where the vapour just starts to puff out the top and turn it uo a bit and that will be pretty damn close .
haggy
Nash,
Nice run. I can use it as a real case for the Haggy Packed Reflux Column Calculator in the Calculator section in HD. Maybe, now you can see how to use the calculator, and be able to use it to plan future runs.
I made some stabs at the input run conditions you ran ( I hope you can update them ) and scoria is quite efficient as a packing. I used an HETP of 3.5", meaning that of your 54" length there is about 15.4 plates.
The power used and takeoff rate are key things to getting an azeotrope abv. If you ran about 2500 watts and had a 3 Liter/hour takeoff rate, that can get you a 96% abv distillate for most of the run. Those conditions are about average for this type of run.
Higher power and lower takeoff rates will give a higher distillate abv - azeotrope. And you started with 40% abv low wines in the pot, that helps also.
So, here is a stab at your run on the calculator. If you know the actual input power and takeoff rate, please reply and I will update the calcs.
Input Data
Results
Time Steps Table
Input Data
Results
Time Steps Table
I've used a flow meter like that and it worked damn good.Salt Must Flow wrote: ↑Sun Nov 22, 2026 10:03 am
But I failed to drain it before freezing weather.
- Salt Must Flow
I don't recall what psi it is set at. I just turned it down low enough to ensure that I got more flow than I actually need. I could probably turn it down lower, but I'll have to fool around with it more.Nash20x21 wrote: ↑Sun Nov 22, 2026 5:24 pm What pressure do you like to run in reflux SMF?
I think the needle valve will help because I hardly have any water flowing through the product condenser and it’s hard to fine tune the barely open ball valve. I was going to use a 1/2” needle valve simply because that’s the size of the water inlet on the pc but a 1/4” will be much easier to find! Thanks again for another tip![]()
A 1/4" needle valve and 1/4" OD tubing worked well with my 3" VM. 1/4" tubing didn't provide enough flow for my 4" so I had to upgrade to 3/8" OD tubing. 3/8" provides enough flow even for stripping at 11000W.
Nash20x21
Thanks for the pointers Yummy!
I’m happy to hear it’s okay to let the distillate get cold and not to worry about it. Mine also had basically no gradient, slightly warm right at the top, good to hear a seasoned veteran doing the same. I’ll keep the Reflux set up the same and tweak the pot still mode to keep the buffeting down while stripping. No fun having low wines sputtering out the PC.
While I was running it I kept checking the housing for the RC, it was warm near the top but not hot and the water outlet was about finger temp so I thought that was an efficient temp to maintain. I originally had them plumbed in series, PC to RC to drain, on my vinegar, sac, and first run but wanted to switch to parallel after I was having the buffeting on my stripping runs. I’m using cut up old garden hose for lines and I had all the Y’s, gear clamps etc. already so it wasn’t much to plumb it in parallel.
Ya my initial plan was to make a ccvm so my thread title has ccvm in it but I thought I had posted in the construction site section of the forum, I could be wrong though, still a newb…
Nash20x21
Hi Haggy,
Thanks for introducing me to the calculator! That’s awesome, now I wish I had recorded some more metrics… unfortunately I’m unable to give you power input or discharge rates. My next run I’ll be sure to keep better notes.
It took about 75 minutes for first drips, I’d say starting temp was around 9-10*C. I only have a cheap deep fryer burner for now and I ran it full tilt the whole time. I recall reading scoria likes to be almost flooded so I figured I’d give it all I had.
Through hearts I had the 1” ball valve open 2.5 turns, fairly subjective data…
I’m going spend some more time going over the calculations so I can keep better notes in the future.
Thanks Haggy
Thanks Haggy
Nash20x21
I brought mine in before I even took the still down, I’ve lost many things to old man winter!shadylane wrote: ↑Mon Nov 23, 2026 2:45 pmI've used a flow meter like that and it worked damn good.Salt Must Flow wrote: ↑Sun Nov 22, 2026 10:03 am
But I failed to drain it before freezing weather.![]()
Nash20x21
Mine was set around 10psi, that could also have been a reason for potential crud getting caught in the valve of the PC, not enough pressure to clear it out until I opened the valve.Salt Must Flow wrote: ↑Mon Nov 23, 2026 3:40 pmI don't recall what psi it is set at. I just turned it down low enough to ensure that I got more flow than I actually need. I could probably turn it down lower, but I'll have to fool around with it more.Nash20x21 wrote: ↑Sun Nov 22, 2026 5:24 pm What pressure do you like to run in reflux SMF?
I agree 100%Yummyrum wrote: ↑Mon Nov 23, 2026 12:59 am
I think using a longer RC coil, so minimum water flow is needed works good.
The reflux is still very hot so it doesn't upset the column. Plus there's plenty of knockdown available to keep vapor from escaping out the vent.
