Diagrams and Plans Thread
Kentucky shinner
Re: Diagrams and Plans Thread
Post by Kentucky shinner »
This a template for making a shotgun Dephagmator with 4 1" tubes. This will do away with one 4x2 cxc reducers.
Samohon
Post by Samohon »
Heres a Flake stand and Worm... (a small taster to part of a Design thread for the reading lounge coming soon...)
♦♦ Samohon ♦♦
Samohon
Post by Samohon »
and here's a common Liebig condenser... Sorry about the small image size...
(Larger images will be available in the Reading Lounge once the thread is ready to go live...)
♦♦ Samohon ♦♦
Samohon
Post by Samohon »
Here's my Pot Still Head...
Click Here for a larger Piccie...
♦♦ Samohon ♦♦
Samohon
Post by Samohon »
Heres a 2" Shotgun Condenser...
And a 4" Shotgun...
More to Come...
♦♦ Samohon ♦♦
Samohon
Post by Samohon »
Here's a Graham condenser and a 4" Dephlagmater...
More to come...
♦♦ Samohon ♦♦
Samohon
Post by Samohon »
Heres a Single Wound Helix Condenser...
and a Single Wound Helix Condenser with coldfinger...
and a Double Wound Helix Condenser...
more to follow...
♦♦ Samohon ♦♦
Samohon
Post by Samohon »
Heres a Double wound Reflux condenser with Coldfinger...
(more to follow)
♦♦ Samohon ♦♦
Samohon
Post by Samohon »
Here Harry's Crossflow condenser...
(more to follow)
♦♦ Samohon ♦♦
Samohon
Post by Samohon »
Heres my easy to make Pot Still Plan... I made the drawing before I built it, I've just annotated the plan for the beginners out there...
This works like a charm and could be modified quite easily to add a thumper, ect;
Think I built it for about $60... Not bad considering the whiskey I've taken from it...
The plan is in full A1 format ready to be printed.... Drawing last updated for text/dimensions correction on Jan - 22 - 2012
The Pot Still.pdf
(more to follow)
♦♦ Samohon ♦♦
Samohon
Post by Samohon »
Heres a Triple Wound Helix...
Ready to go live in the New Distillers Reading Lounge...
♦♦ Samohon ♦♦
Samohon
Post by Samohon »
Tee Trap in reflux cup for LM/VM Combo... Slant plate alternative...
♦♦ Samohon ♦♦
Samohon
Post by Samohon »
Thought I would update the D&D thread with a diagram for beginners starting to use the UJSSM...
Heres a printable version...
Click Here...
♦♦ Samohon ♦♦
Samohon
Post by Samohon »
Heres my current VM/Bok combo setup from another thread centering rings inside the column..
I take 1.8L per hour @ +96% abv @ 20°C from my parrot...
If I take +2L per hour, the abv is still +90% and the neutral/vodka is very very clean...
Heres a larger PDF...
Click to Download...
Hope it helps... :ewink:
♦♦ Samohon ♦♦
