Re: sweetfeed whisky
Posted: Mon Mar 18, 2013 3:24 pm
Hi rastus. I don't know about the other guys but mine has been finishing out at 1.000 or below in about six days..
SD
SD
The Largest Online Resource for Distillers
https://homedistiller.org/forum/
PsYc0TiC wrote:Here is my stillF6Hawk wrote:PsYc0TiC,
Are you running a reflux or pot still? Don't see how you could get 80% alcohol with a normal wash on a pot still. That would indicate your wash was around 54% starting out. Sounds like some reflux is going on?
http://homedistiller.org/forum/viewtopi ... 32&t=35002
Wow 60 gallons, how big is your boiler??nike785 wrote:I've done several runs of the sweetfeed with great success. I am now looking to up the volume of my washes a fair amount. what would be the proper proportions for a 60 gallon sweetfeed wash?
i'm running a 32 qt pot now but this weekend i'll have my 15.5 G Keg finished up.Stainless dude wrote:Wow 60 gallons, how big is your boiler??nike785 wrote:I've done several runs of the sweetfeed with great success. I am now looking to up the volume of my washes a fair amount. what would be the proper proportions for a 60 gallon sweetfeed wash?
Since this recipe is based on about a six gallon wash, just multiply by ten and you should be good..![]()
SD
In all of your research, which we consider mandatory, you never read that you should never use Turbo Yeast with anything other than sugar...???redcorn53 wrote:hey fellas how's it going? I made a mash from the following recipe...
4 and 1 half inches of sweet feed in a 5 gallon bucket,5 gallons of water,and 5 pounds of sugar. I heated the mash up to 150 degrees and maintained that temperature for 1hour. afterwards I added the 5 pounds of sugar and mixed well. I let it cool to 90 degrees been added activated yeast. I used 4 oz of alcotec 24hr pure turbo super yeast. I theen poured the mash in a 5 gallon water jug with a stopper and airlock. the jugs bubbled up like crazy when the yeast started doing the work. I kept checking them for 4 or 5 hours and they where bubbling good. after I woke up 8 or 9 hours later I checked my jugs of mash progress they were not bubbling constantly or even 2 or 3 bubbles a minute. is this normal or what? What happened?
Well crap. I'm sorry I just joined this community. I did not know thAt. I already made the mash before hand. Sorry I read several thingz but there is a lot of info to sort through. I know that I didn't kill it...I waited very patiently for it to hit 90 degrees before I added the activaterad14701 wrote:In all of your research, which we consider mandatory, you never read that you should never use Turbo Yeast with anything other than sugar...???redcorn53 wrote:hey fellas how's it going? I made a mash from the following recipe...
4 and 1 half inches of sweet feed in a 5 gallon bucket,5 gallons of water,and 5 pounds of sugar. I heated the mash up to 150 degrees and maintained that temperature for 1hour. afterwards I added the 5 pounds of sugar and mixed well. I let it cool to 90 degrees been added activated yeast. I used 4 oz of alcotec 24hr pure turbo super yeast. I theen poured the mash in a 5 gallon water jug with a stopper and airlock. the jugs bubbled up like crazy when the yeast started doing the work. I kept checking them for 4 or 5 hours and they where bubbling good. after I woke up 8 or 9 hours later I checked my jugs of mash progress they were not bubbling constantly or even 2 or 3 bubbles a minute. is this normal or what? What happened?Or did you think we don't know anything and decided to go ahead and try it anyway...???
Either you wretched wash has fermented dry, which is doubtful, or it overheated and killed off the yeast colony, which is more likely...If it fermented to dry I sure wouldn't want to drink what comes out of your still...
It wasn't the pitch temperature that would have killed it, it would have been the heat generated by the turbo yeast on top of the heat generated by the sweet feed...redcorn53 wrote:Well crap. I'm sorry I just joined this community. I did not know thAt. I already made the mash before hand. Sorry I read several thingz but there is a lot of info to sort through. I know that I didn't kill it...I waited very patiently for it to hit 90 degrees before I added the activate
So what did you mean by fermented dry? I just checked my jugs and I still have one bubbling. What would happened if it was distilled? If you would answer that and possibly direct to the proper forum for this. Thank you for aswering and helping me.rad14701 wrote:It wasn't the pitch temperature that would have killed it, it would have been the heat generated by the turbo yeast on top of the heat generated by the sweet feed...redcorn53 wrote:Well crap. I'm sorry I just joined this community. I did not know thAt. I already made the mash before hand. Sorry I read several thingz but there is a lot of info to sort through. I know that I didn't kill it...I waited very patiently for it to hit 90 degrees before I added the activate![]()
Take a step back and do some research here...It'll save you a lot of headaches, in more ways than one...
RScottyL wrote:Stainless dude wrote:Packfan.packfan61 wrote:so i've read a lot of posts on here. And I am a novice at this. My question is: under the home distillation of alcohol page it says for whiskey, to heat your grain (cracked or crushed malt ) , then strain off the grain and ferment your wash. Is this only if your using corn? As the tried and true recipe for sweetfeed shine says to add boiled water,and later cooled water, to your grain and ferment the whole mash ( grain,sugar,yeast,water ), then strain prior to running it.I'm using a simple pot still.So the latter method ( tried and true for sweetfeed ) would give me a better tasting shine, correct? What's the proper way to strain the grain out of the fermented mash before running it? just simply pour through a mesh strainer? I'm thinking that if I syphoned it there would be debris in my wash that could possibly burn in the bottom of my pot still . Also, will i get more quantity and higher alcohol content by leaving the grain in to ferment? A guy told me he strains his sweetfeed grain off prior to fermentation, after he cooks it for an hour, and he still strains his wash prior to running it. I want the best method when making mine. Can someone help me with these issues please!I do use the sweetfeed all grain for my shine and have been straining it prior to fermentation as a friend had told me to do.
This is not whiskey, it is a sweetfeed wash. Leave the grain in your fermenter. When it is done fermenting you can either scoop out all of the wash with a pot or what ever and pour it through a strainer or a pillow case for that
matter. Leave the yeast and grain bed pretty much alone. After you get all of the wash out that you can, remove the top layer of feed. Replace the amount you took out. Make sure it is covered with water so your yeast don't die.
After you make your run, take 1 1/2 gallon of backset from your boiler while it is still hot and add your surgar for your new batch. Whenn it cools down to about 90 degrees add it to your fermenter, add remaining water and put the lid
on. It should take off in a few hours, mine always does.
SD
If anyone has not seen it, there is a video on YouTube by username Pontiusplate or something similar, which does something very similar to this. He walks you through the entire process! He even mentions this forum in his video description, so i assume he is a member on here!
http://www.youtube.com/watch?v=P-nGbAf81Zs" onclick="window.open(this.href);return false;" rel="nofollow
DuckofDeath wrote:Why did you boil the sweetfeed for 1 hour then pitch yeast.. without enzymes the boiling of grains will do NADA.
steve2md wrote:boiling will extract more flavor from the grains, but not sugar. Yeast is then pitched when the beer reaches pitching temp
granpopmaggot wrote:What grains are in this "sweetfeed"? I'm in Australia and no one seems to know anything about it . Any information would be of great help in this, my first atempt at Potstill whisky ... granpopmaggot of Oz : :
The big discount stores like Sam's Club and Costco carry bakers yeast in bulk... I buy 2 - 1 pound vacuum bricks for under $5USD from Sam's Club... But don't worry about buying lots of packets if you can't find bulk... People bake every day, and if you feel paranoid, purchase from multiple sources... I never buy all of my ingredients from the same store or at the same time...racksnquacks1 wrote:im trying to find bakers yeast in bulk, but cannot find locally. they only have the tblspoon packets and it would look suspicious to buy so many at a time, do they sell it at walmart of something? I try to avoid that store as much as possible but will go if need be.
