FLUTE TALK
Kentucky shinner
Re: FLUTE TALK
Post by Kentucky shinner »
rockchucker22 wrote:
Kentucky shinner wrote:Well here is the finished product from my latest build. I will do the cleaning runs on her, then I will box her up and send her on down the road.. I am really looking forward to running this baby.. Valved plate on the bottom and 3 perforated plates.. shotgun dephag... she should be a hot rod...
KS
She's pretty, did you vent the parrot?
I am adding the vent today, I have an idea of using the vent as a brace also. I just have to attach the vent tube.
Kentucky shinner
Re: FLUTE TALK
Ya I have vented the others I have made as well. you have to get the vent above the bottom of the graham.
Kentucky shinner
Re: FLUTE TALK
Here is the maden wash run after cleaning runs. shotgun dephlagmater, Valve plate on the bottom, the perforated plates. I just need to repolish, add sealer the ship this baby.
http://www.youtube.com/watch?v=UyEMcsomrw8" onclick="window.open(this.href);return false;" rel="nofollow
KS
Mr.Spooky
Re: FLUTE TALK
Post by Mr.Spooky »
i saw it!!!!!! hell yea!
do you think that the thermo is a must,,,, or just another "piece"???
thanks
spooky
Re: FLUTE TALK
kay I seen't it.
KS do you include the parrot with your builds ?
Kentucky shinner
Re: FLUTE TALK
Mr.Spooky wrote:i saw it!!!!!! hell yea!
thanks
spooky
Honestly I really don,t think it is necessary . you can tell when you hit the tails because it will just go to drips.
KS
bgrizzle
Re: FLUTE TALK
Post by bgrizzle »
KS... I cant wait to get mine...when are you going to start on it... and what are the differences in this flute and the one you are making for me?
olddog
Re: FLUTE TALK
Post by olddog »
Mr.Spooky wrote:do you think that the thermo is a must,,,, or just another "piece"?
I find it usefull for keeping the temp under the dephlag spot on for hearts take off.
OD
Kentucky shinner
Re: FLUTE TALK
bgrizzle wrote:KS... I cant wait to get mine...when are you going to start on it... and what are the differences in this flute and the one you are making for me?
Yours will have more plates, you will have 6 instead of 4. I ordered your parts Friday. Then sent me any email that some of the parts were back ordered and should be shipped out in 4 days. In the mean time I will build the dephlagmater, parrot, and some other things I can be working on while the other stuff comes in..
KS
Mr.Spooky
Re: FLUTE TALK
Post by Mr.Spooky »
OD
this might be a stupid question,,, but how do you control the temp under the deflag??? via heat input,,, or via reflux??????
thanks
spooky
Re: FLUTE TALK
Mr.Spooky wrote:via heat input,,, or via reflux??????
thanks
Yes.
But I recon you will gravitate to the CM rather than the PM
olddog
Re: FLUTE TALK
Post by olddog »
With the dephlag in full reflux, mine stabilizes at 78 degrees celcius, temperature is controled by the water flow to the dephlagmater.
OD
olddog
Re: FLUTE TALK
Post by olddog »
I just adjust mine to 79 degrees, and I get product flow, there will be different temps + or - depending on the position of the temp probe, and the accuracy of the thermometer calibration.
OD
Mr.Spooky
Re: FLUTE TALK
Post by Mr.Spooky »
i use a temp gun... do yall think that this would give the same measurment? anybody got both to see?????
spooky
Kentucky shinner
Re: FLUTE TALK
mine runs at 79c also. The 002 that I ran today set at 80c?
lordyd
Re: FLUTE TALK
Post by lordyd »
I've been thinking of using a 1/2 needle valve on my dephlag ( shotgun) for a bit more control but I'm not sure if the flow rate would be to low for the knock down at the start.
olddog
Re: FLUTE TALK
Post by olddog »
A needle valve would probably be a bit of an overkill to control water flow, a ball valve works well and a lot cheaper than a needle valve.
OD
Kentucky shinner
Re: FLUTE TALK
congrats RC, sounds like your gonna like your flute.. after you have run it a bit the dephlag will be easier to adjust. Glad to hear about your success.
KS
Kentucky shinner
Re: FLUTE TALK
I am just glad I could help you out man. Only way I can give back is to help others as much as I was helped out when I was doing my build..
I would love to see a pic of your still man..
KS
Mr.Spooky
Re: FLUTE TALK
Post by Mr.Spooky »
awsome!!!! i like the unions on each side of the condensor... i uses compression fittings. i havent had any problems from them,,, but if i ever do, im gonna hook myself up like you did.
good work Rc!!!!
spooky
olddog
Re: FLUTE TALK
Post by olddog »
Nice job there RC thanks for sharing. You guys seem to be using a smaller graham condenser than I do, how much coil have you got in there, or are you using your shotgun on this rig.
OD
Kentucky shinner
Re: FLUTE TALK
I think you did a hell of job there RC.. looks good man.. I like the union to attach the Parrot... It think that is a great idea....
Spooky I personally like the unions over the compression fittings too. I seem to have had better luck with them.
KS
Kentucky shinner
Re: FLUTE TALK
the Graham condensers I am using are from 10-14 inches. The work Great. These things are really efficient.
DOLIKEADRINK
Re: FLUTE TALK
Post by DOLIKEADRINK »
Mean Mother Flute
Another FLUTE will be up and running soon with a bit of luck "and a ship load of help from OD" :D :D
Well this is what i have been up to, I collected all my bits and pieces, Cut my pipe to length and Silver Soldered the SS ferrules on, I made the plates by splitting and flattening a length of 3" that i had, I used a hole saw and my pedistal drill to cut the plates out, I Tig Welded a 4" Ferrule to a old Keg that i acquired, This flute is intended to be a modular build, The lower section is 700mm and will have 4 plates in it for flavored spirits, The top section is 800mm long which will have 6 plates, Hopefully this will produce a good clean neutral. OD is going to make the plate tree removable so at a later stage if i so wish i can experiment with other plate designs. The MMF stands a near 3mtr's tall looks like i will need a step ladder to see the top plates.
THIS BUILD WOULD NOT BE POSSIBLE FOR ME WITHOUT THE HELP FROM OLDDOG THANKS MATE Here is a few pic's
Cheers: Dolikeadrink
"Your putting on the agony but missing all the style" Ya want a good Still PM olddog
olddog
Re: FLUTE TALK
Post by olddog »
I have just resized them for you.
still 034.jpg (26.25 KiB) Viewed 2474 times
OD
Kentucky shinner
Re: FLUTE TALK
its a beast man.. I look forward to reading about your results with this mammoth.... damn You may need a flag on top :ebiggrin: :ebiggrin:
Re: FLUTE TALK
Holly balls I jes realized what you got there.
Looks like a beefed up version of what Azeo was describing on another thread.
Beat him to the punch.
Can you say "proper nuetral"?
Love to hear how fast she'll drive.
Re: FLUTE TALK
DOLIKEADRINK wrote:What did you mean by proper neutral in your early post
Semantics really.
A barb for the fellers that question the versitility.
Wasn't too far back that some folks round about figgered this design would not work at the hobby level.
Proper would be 95 or better,,,,,one assumes.
DOLIKEADRINK
Re: FLUTE TALK
Semantics really.
Ah HA now i understand, Well we will find at about the versatilaty of this modula FLUTE design real soon i geuss, I recon it's gunna be a winner :D :D I wasn't having a dig at you i just didn't understand what you ment.
Cheers: Dolikeadink
Re: FLUTE TALK
DOLIKEADRINK wrote:I wasn't having a dig at you
No worries about that at all sir.
And in this instance,,,my lil bit-o-snark was not meant to be hurtful to any or all parties.
Cheers.
PS: spelled yer handle wrongly you did.
