Bokakob 2" under construction.
Posted: Tue Oct 19, 2010 2:28 am
Thought id do a progress report on my first still. Making a 2" Bokakob and thought id start off with the coil/condenser. First time working with copper so im sure it will be a bit of a challenge.
Condenser is 300mm long using 5m of 1/4" copper. Used the 16mm and 32mm pipe method to form. Heated end as you can see to soften copper to make it easier to shape the inlet and outlet tubes but the rest was just wrapped around the tubes unfilled and un-heated.
If you can see any mistakes, or if you have any suggestions feel free.
More updates to come.
