Distillation temperatures, step by step.
Elut
Post by Elut »
Bring up to boiling temperature (start the cooling water through the condensors once you get to about 50-60oC), then once it has started distilling;
Discard the first 50 mL's (this may contain some methanol),
Collect the next 2-3L of distillate.
Segregate the distillate into 500 mL containers as you collect it.
Stop distilling once the temperature gets to 96oC (else the flavours get nasty).
Set aside any distillate which smells of tails/fusels. This can be added to the wash of the next run, and cleaned up then.
Hi Everyone !
After reading the parent site several times, I still don't fully get the picture of the distillation temperatures.
If I correctly understand the parent site, it's just about letting the power source do its thing until the temperature
of the [alcoholic steam? Wort? Output?] reaches 96c.
I'm planning on building a temperature control based on the temperature readings of the wort and the steam.
So, upon your own experience, what would be the "best temperatures" to heat the wort at?
Would applying a constant 78~79c heat during the whole run be a good solution? If not, why?
Or at the contrary, should I get through several steps? If so, which?
Thanks a lot in advance, for explaining me more in details these blurry points ! :mrgreen:
This topic has 35 more replies
Register Login
