Complete reflux still build...
abbigss
Re: Complete reflux still build...
Post by abbigss »
Hi,
This seems to be a great still, encouraging the newbies (like me) for building a still. Great job..
But i still have some questions:
1- There seems to be 2 copper coils on pic 1 and 3... Where is the second coil used ? Did i miss something?
2- Why there isn't a thermometer on your still ? Isnt it a must?
And the most crucial point for me is:
3- I cannot exactly clarify in my mind, how the "tee" is working.. The pictures are not clear to understand. Will the "T" look upside or downside before soldering the main pipes? Can anyone explain this tee mechanism exactly?
abbigss
shifty
Post by shifty »
Hey mate. welcome aboard..
Re read the post and get back to me. Im sure most of the answers your after are in there. If not ill do my best..
Cheers....
drinka
Post by drinka »
I still don't understand the tee bit either. Does the outlet pipe get soldered to one side of the tee???
JethroBodine
Post by JethroBodine »
drinka, here are some pics from my build.
Hope they help.
This cup gets soldered into the bottom of the condensor.
View from above
View from above
Ready for assembly.
Ready for assembly.
Sorry for the fuzzy pics. I think the camera might have been drinking.
Master Bruce Lee said," The best style, is NO style."
I've had a LOT of practice at having no style.
abbigss
Post by abbigss »
Jethrobodine,
Thanks for photos, now its ok for me.
Do you have any more photos with the outlet pipe soldered to the tee?
JethroBodine
abbigss, I have some pics of the cup soldered to the condensor tube, but the takeoff doesn't attach to the tee, it only goes in far enough to collect the goodies that are puddling around the bottom of the cup. I drilled my takeoff hole perpendicular to the top of the tee( just seemed like the right thing to do).
Matching outlet holes
Cup soldered in with takeoff tube installed
Shifty, thanks again. I should be running my cleaning runs soon( for the LM head anyway, and am working out the designs to make this a trully universal( just for the fun of it) LM, CM, VM and HM( heat management, or pot still :lol: ).
HookLine
Post by HookLine »
Heat Management is usually referred to as Power Management (PM).
Be safe.
Be discreet.
And have fun.
shifty
Post by shifty »
Hey JethroBodine,
Cheers for posting up those other pix. Makes it a lot clearer to others..
Good work and good luck with it...
abbigss
Post by abbigss »
Now I feel ready to build my first reflux still..
When i was looking around the copper shops in Turkey, i found an interesting type of copper tube... they've been made for easy coiling and many dimensions are available..( i plan to use 5 mm tube for the coil)
does it make any negative (or positive) effects on cooling the vapour? what u think about it?
HookLine
Post by HookLine »
Nice. But how will the coolant in the inner star shaped tube come into contact with the heat exchange surface (the outer cylinder)?
Be safe.
Be discreet.
And have fun.
abbigss
Post by abbigss »
well it wont.... maybe it can be an extra cooler for the hot water flowing in the outside cyclinders... just thinking...
HookLine
Post by HookLine »
abbigss wrote:just thinking...
Thinking is good. New ideas are good.
Be safe.
Be discreet.
And have fun.
drinka
Post by drinka »
Thanks for the pics jethrobodine. Sure makes it clearer to me now. What sort of solder did you use?
JethroBodine
abbiigss, LOVE those tubes! If you could find some star shaped adapters, you could run the vapor on the outside tubes and the coolant down the middle( as part of a condensor, sort of a ready made leibig). MMMM, shiney copper....
drinka, I use silver bearing solder( Flo-temp) with a water soluble, lead free flux( Bernzomatic). Kinda' stiff and hard to get used to, but a plumber friend of mine said that it was strong and wouldn't leach into the vapors. I haven't noticed any pitting or corrosion, yet.
Hookline, :oops: I kinda got carried away with the alphabet soup
irish_moonshiner
Post by irish_moonshiner »
Nice still :D
I was just wondering how effective that ball valve is at accurately controling the output flow?? Im very near completion of my LM still and thought a needle valve was necessary but if a ball valve works fine I could save myself some money??
Thanks in advance.
Measure twice, Cut once.
My Build
shifty
Post by shifty »
irish_moonshiner wrote:Nice still :D
Thanks in advance.
I actually don't like my ball valve at all. It's too hard to control. If i were you id look for an alternative..
Just my opinion...
Kentucky shinner
Post by Kentucky shinner »
I am thinking about building this column but I have a couple of questions. Are you pleased with the production of this column? where would you place your temp gauge?
shifty
Post by shifty »
Kentucky shinner wrote:I am thinking about building this column but I have a couple of questions. Are you pleased with the production of this column? where would you place your temp gauge?
Hey mate
Im happy with the production of the column only because i know no better! :D This is the only type i have, apart from a pot still....
The temp gauge should be as close to the take off as possible. Mine is just under the tee section...
I think it works quite well and im very happy with the results so far....
Kentucky shinner
how did you mount the T section to both sections of the column. I see you used a cap to place the T in but I dont see how you conected it to the main part of the column.
shifty
Post by shifty »
The Tee section is the same diameter as the column shaft. In this case it is butt joined and soldered..
A better idea would be to use a sleeve joint..
Cheers...
Samohon
Post by Samohon »
Thats a nice build shifty. Hope shes easy to drive for ya....
♦♦ Samohon ♦♦
jackson98
Post by jackson98 »
that look good to me i just got two questions, first did you put just one set of coils in(just in the condensing section, none in the lower..) second did you pack the lower section. i am new to it(never built a still but always wanted to) and was looking at building the same thing as you. You also said you were adding a temp gauge below the tee right? how hard was it to build? thanks
shifty
Post by shifty »
jackson98 wrote:that look good to me i just got two questions, first did you put just one set of coils in(just in the condensing section, none in the lower..) second did you pack the lower section. i am new to it(never built a still but always wanted to) and was looking at building the same thing as you. You also said you were adding a temp gauge below the tee right? how hard was it to build? thanks
Just one coil mate. The other one you see in the shot was a failed first attempt. :D
I did pack the lower section with stainless pot scrubbers....
As for the temp gauge, all i did was drill the hole and poke it in.... :D
As far as still's go, id say this one is pretty easy...
jackson98
Post by jackson98 »
how did you create your cup? did you get a end cap and drill a home and solder the tee in?
still crazy
Post by still crazy »
Thanks in advance.
Just my opinion...
Remove the handle from the ball Valve and replace it with a longer one. This will give you more control as the long arm can be set to more precise angles.
Geezer
Post by Geezer »
I built a column very similar. 2" pipe. Having trouble finding a way to connect it to my pot. I welded a pressure cooker to my 15 gallon keg. The lid has a very slight dome. I have looked at many pictures on here. Suggestions would be greatly appreciated.
bokakob
for those who are looking for dimensions
Post by bokakob »
http://homedistiller.org/image/drawing_ ... ups_TC.jpg" onclick="window.open(this.href);return false;" rel="nofollow
and
cheers
