How to wind a perfect coil condenser.
Re: How to wind a perfect coil condenser.
This is probably the best thread on how to wind a coil. Members have used other material besides salt. I had problem with water on a few that I wrapped do to air pockets. Silica sand worked best for me.
Built multiple 1/4 and 3/8 copper condenser coils over the years. Done by hand around a pipe with a roll of refrigeration tubing. The tubing stays round without having to use anything on the inside. Now with the presentation of using ccst I don't bother anymore, you can have a coil done in a matter of minutes.
60" CCST version for 3" pipe.
![Image](https://i.postimg.cc/k65pyFLx/20220304-210326-1.jpg)
![Image](https://i.postimg.cc/56zkptKk/20220304-210343-1.jpg)
![Image](https://i.postimg.cc/06VtrKrr/20220304-210437-1.jpg)
Ecir - How does that work in practice? That looks quite small.
picture is deceiving this one fits in a 3" pipe at top of LM nixon stone rig with a 2" column. 60" CCST can knock down allot of power with less than a liter per minute, very efficient, overkill on this rig.
How do you fill a coil of 1/4" copper tube with salt/sand?
- Dancing4dan
Does not need to be filled to form it. The C in CSS is for corrugated. Those ribs help it retain its shape and prevents kinking.
Marcus Aurelius
Marcus Aurelius
- Salt Must Flow
I crimp one end closed. I unroll the tubing to make it reasonably straight. I tape a funnel to the open end and pour salt into the copper tubing. It helps if you elevate the open end, like get up on the roof of a house or something like that. It helps the salt make its way all the way down easier. It also helps to jiggle the tubing too.
What diameter is your column? I used 5/16" to make a double wound coil for my 3" column.
2".Salt Must Flow wrote: ↑Mon Nov 14, 2022 11:39 am What diameter is your column? I used 5/16" to make a double wound coil for my 3" column.
Was gonna use 1/4" tube.
- Salt Must Flow
1/4" is appropriate for a 2" column. I was just curious just in case you had a larger diameter column.Bee wrote: ↑Mon Nov 14, 2022 5:00 pm2".Salt Must Flow wrote: ↑Mon Nov 14, 2022 11:39 am What diameter is your column? I used 5/16" to make a double wound coil for my 3" column.
