weel, here goes:
Im gonna use a 30l ss boiler with a 2000W acid-tolerant element.
the column wil be about 60 CM long and 10 CM in diameter, it will be openable on the top, for cleaning and such.
from the top, there will go a tube a further 40 cm, wich the condensors are conected in series to (so the vapors have to go through all of them).
(check my drawing in the first page)
there will go an reflux pipe from each collector (the big pieze at the bottom of the condensors) and an output-valve on each of them.
to regulate the reflux, i regulate the output valve. when output is 0% there is a 100% reflux FROM THAT CONDENSOR, and so on.
i plan to add valves to the water flow in each condensor too, so i can adjust what condenses in each condenser (this is my feeble attempt to make it easier to split the different compounds in the wash into different collectors).
i am pretty sure that the fusil oils, with higher boiling temp will condens first, mainly in the first condensor. the ethanol, wich boils at 78,3* can be collecter in second or third condenser, and the heads in the 3/4 condesor(s).... dunno if this will work as i intend, but as i said, its just a feeble attempt...
one thing i am SURE will work, is making a good drinkable spirit with this design....
I hope this atleast answers SOME of your questions to my design.
i am not trying to keep it a secret, and will ofc post pictures of the still both finished and under construction, so you can see what i mean more clearly....
Thorin...
