Rerunning Feints
Posted: Sun Dec 12, 2010 5:05 pm
Hey all,
I have read about saving the heads and tails to rerun as an all feints run, question is, once a head is a head, is it always a head, or will it remix with the rest, so that there will be heads and hearts and tails, like a normal run?
Is the ethanol locked in to the original azeotrope, or can they be moved? For that matter, when are the indiviual azeotrpoes created, during fermantaion, or distilling?
If you have a gallon of what you cut as heads, and you rerun it, are you just trying to get cleaner cuts and squeeze out some hearts that might have gotten past, or will the alcohol have remixed in the feints jar, to make another full heads, hearts, and tails mixture to be cut again?
-Thanks
-Thanks
