Posted: Wed Feb 22, 2006 12:43 pm
that only helps for overpressure... i have seen plans for simple cheap two-way pressure release valves.
you have two SS-plates of about 3 mm thick, and 6x6 cm.
one with a groove and one with a rise-up that fits the groove on the other.
weld one of them to a coupling that you can fit onto your still.
make a hole in the plate that corresponds to the coupling.
take a thin copper film and place it on the plate.
put the other plate on in front, with apropriate hole-size.
screw together..
the plates would need to be machined, to achieve the groove and the rise-up, pluss the holes for screws....
Thorin
screw together..
Thorin
