mash rookie wrote:
With all due respect I am not sure why you insist on using it wrong.. You need to use it as designed.
You exactly right - it needs to be used as designed. Unfortunately it's not designed for non-sinusoidal AC waveform. And AC waveform after phase-angle controller is not a sinus.
BTW - do you understand how phase-angle controller works?
- Dimmer_60_volts.png (5.47 KiB) Viewed 2275 times
Blue curve represents voltage on controller input (sinusoidal form), red curve is an output at ~40% of power. As you can see it doesn't look sinusoidal.
It is intended to show you line voltage in and amperage draw.
It's not so straightforward for AC as you think. Do you know what voltage and amperage this devise shows - RMS, Peak or Average? If it's not RMS you can not use it for power calculation. Please read this -
http://www.allaboutcircuits.com/vol_2/chpt_1/3.html" onclick="window.open(this.href);return false;" rel="nofollow and the chapter "Average electrical power" here -
http://en.wikipedia.org/wiki/Root_mean_square" onclick="window.open(this.href);return false;" rel="nofollow
What do you expect to learn? Do you understand power application relative to distilling?
I'm trying to find a way how this meter can be used with phase-angle controller and how correct it's reading.
My conclusion:
- You can not use it to measure voltage on heating element since it's power supply limitation.
- You can use it for amperage measurement, but reading not very accurate.
I see no value related to distilling from your post.
I hope that other forum members will see a value .
What exactly you don't understand from my post?
