these boys would fill it full of sand find the right pine tree coil it then cut the tree right above worm.
so im tole
need help with condenser.
BigA,
I just coiled about 15 feet of 1/4 inch soft copper to fit into my 3 inch condenser housing.
First, I wrapped the coil around a 1.25 inch PVC pipe about 10 turns. Then I took a 12 inch piece of 2 inch PVC pipe and cut it in half, sandwiched the coil in between the halves and taped both ends so it won't fall apart. I then transitioned wrapping the coil over the 2 inch pipe another 12 or 13 turns. No kinks or any problems.
I think maybe you are not finding the base raw material needed to do your coil. When I was looking to buy the 1/4 inch, there are two types of copper. The one I used is the 1/4 inch soft copper and it is thicker, I just called the plumbing supply store where I bought the material and he said there are no specifications but the pipe is rated for some 400 PSI.
The other 1/4 inch soft copper I used came in a pre-packaged and was for refrigeration. I actually used it and it kinked right away and was awful to work with.
Hope this helps. I know this could be frustrating. When I was working trying to make the coil, my hands were sweaty and I knew the investment and the effort.
Re: 3/16" pipe
tubing size is od/pipe size is id/1/4 tube measure's 1/4"od 2" pipe measure's about 2" id depending on the wall thickness of the pipe.There is type l tubing and type k-type k is extra heavy and hard to work with.I like refrigeration grade type lbigA wrote:I've read a few posts using this pipe, and once again I don't understand if it's O.D or I.D. I'll assume for the moment, that it is I.D., that would make the bending a lot better, but mistakes more costly(a kink in a smaller pipe would make it useless). 3/16" isn't found at the local lowes here, but i could get it if you guys think it would be better for my purpose.
Thanks a lot,
NostillyetA
Re: need help with condenser.
Fill your tubing with water, freeze it, do all your coiling needs while the ice inside is frozen. Water melts right out, no cleaning. It's how brass instruments are made.
