HOBBY continuous still!
We don’t condone the use of Continuous Stripping stills as a method of running 24/7 as this is a commercial setup only .
Home distillers should never leave any still run unattended and Continuous strippers should not be operated for longer periods than a Batch stripping session would typically be run to minimise operator fatigue..
JaCh
Post by JaCh »
LAST EDIT - 2013_12_08-11:55
Preface:
For a while I have been pondering how I CAN make a still as compact as possible.
I attempted to do so in this thread /viewtopic.php?f=17&t=43039 but my design wasn't very good and I was met with a lot of criticism.
I now understand the drawbacks of my design and am working on something better.
I will frequently edit this post to keep it up to date with improvements to the design so it is possible for anyone to overview it in it's entirety without scrolling through my outdated information.
Advantages of a compact continuous still:
-Save space/easier to conceal
-Save materials
-Can strip larger washes; therefore allowing use of lower ABV for smaller heads cuts (less heads produced during ferment)
Message to Naysayers:
I understand there is some resistance to the idea of a continuous still for hobby use, however I feel there are some users of this forum who would be prepared to help me.
If you would like me to clarify any of my reasoning for pursuing this project please PM me, if I receive multiple similar PM's I will modify this post to include sufficient reasoning.
Specification:
Essential-
-Must function well as a stripper
-Must remove majority of water content
-Must not scorch the wash
-Must be simple to make
-Must be simple to run
Desirable/Non Essential-
-Must remove majority of tails
-Must be regulated by an arduino uno
-Must remove heads
-Must produce neutral potable spirits without need for further process
-Must be able to be passed off as an essential oil extractor
Materials I have:
-2.5" diameter by about 3.5'
-2" diameter by 2'
Boiler Design:
-My aim is for as little ethanol as possible to ever reach the boiler.
-Initially the left section would be charged with water, as the run progresses it would contain spent (/almost spent) wash.
-The right section is for producing steam (using electric element) to heat the initial water charge/spent wash. (This prevents scorching)
-The steam boiler is fed at the top right by used coolant from the reflux column.
-Spent wash/initial water charge is output on the far left.
-Vapors rise into the column to be separated and cause separation of input wash.
Column Design:
-Input wash could be heated by a primary vapor condenser.
-Input wash is introduced towards the top of the column.
-Input wash is distilled as it falls through the column and alcohol rises.
-Input wash is mostly spent by the time it reaches the boiler.
-The column must cause a large amount of interaction between falling wash and rising vapor.
-The column must be under forced reflux.
-Spent reflux coolant will be sent to steam boiler.
-Some tails could be removed towards the bottom of the column.
COLUMN DESIGN IDEA 1:
-Coil at top of column causes main reflux
-Concentric column supports temperature gradient
COLUMN DESIGN IDEA 2:
-Vapor is removed at the top of column.
-Vapor is refluxed below this.
-Wash is preheated by vapor out and reflux coolant.
-Wash is introduced below reflux.
-Falling condensate interacts with rising vapor on perforated plates
Closing Remarks:
Thank you for taking the time to read and contemplate my ideas.
Any feedback received will be considered and modifications/additions to the design will be made to this initial post as they are discussed.
JaCh
Additional Clarification:
TBC
This topic has 36 more replies
Register Login
