Anyone use a 1500 Watt element for keg still?
If it plugs in, post it here.
CanadianBacon
Re: Anyone use a 1500 Watt element for keg still?
Post by CanadianBacon »
Bob Loblaw wrote:3 prong works plug fine. Two hots and a neutral. 4th prong adds a ground.
The ferrule you want has an OD of 51mm/2 inches like this one: http://www.amazon.com/dp/B00835O0J6/ref=biss_dp_t_asn" onclick="window.open(this.href);return false;" rel="nofollow
Check w/ your controller order, larry might be able to add to your order. + element guard + gasket + clamp. Save you some shipping. They carry all the stuff you need, prices are decent.
I already four a ferrule ss sanitary in ebay from china, and i think the kit comes with the clamp
Bob Loblaw
Post by Bob Loblaw »
IIRC, it comes with one clamp, which holds the cap to part where you attach your element. You need another clamp to secure the whole rig to your boiler.
CanadianBacon
ok, do you happen to know is SUS 316 stainless steel Is ok? says its second to 304 but has molybdenum.
Bob Loblaw
It's fine. I think it's more expensive than 304 due to added corrosion resistance properties. But AFAIK, you can use either safely
CanadianBacon
Bob Loblaw wrote:It's fine. I think it's more expensive than 304 due to added corrosion resistance properties. But AFAIK, you can use either safely
Good to know, everything is ordered aside from my element. So I think I am set. I'll post the build along with the keg build when I Finnish making it electric. Hopefully it helps someone out because even with all the material to read it hard to figure out the entire project.. What type of insulation you use for over keg?
CanadianBacon wrote:. . . . What type of insulation you use for over keg?
I used that Reflectix insulation material from the big box store. Its an aluminum foil with encapsulated air pockets. Great "R" value, though not inexpensive. Its easy to cut with a scissors and can be taped with HVAC aluminum foil tape. It makes a good looking boiler and improves its efficiency.
