I think I got it.
Hound Dog wrote:
I am running the exact same setup as Cranky. If the connection is moved to the input side of the SSR, will it not just always read my maximum voltage being fed and not the cut voltage actually going to the heating element? I already know I have 237 volts feeding in. If I don't know the voltage and amperage output going to the element how do I determine the wattage?
That is exactly where I started from, and why I raised a fuss in Edwin's first post about the magic meter.
Edwin wrote:
This meter measures a couple of thousand times a second the actual voltage and current value. It multiplies the numbers which each other and add the results together. After a second the result is the real power. So it only measure the power when there is current flowing through your element. I am working on a simple explanation but that is quite a challenge When I studied this subject it was not one of the easiest one's
The rest of this will be "Lectricity for Dummys" written by a dummy, so if this is inaccurate I hope Edwin will show up quick to correct it, cuz the one thing that is worse than no information is wrong information.
The rapid sampling seems to be just a matter of accuracy, or resolution. More samples equals more accurate. The regulating agencies require an energy meter, used by the power supplier to bill customers, to read the waveform accurately to the 10th harmonic. The scientific community has agreed to accept the accuracy of a sample rate that is double what is required. This turns out to be 2k samples per second at 50Hz, 2.4k at 60Hz.
The meter measures voltage and current separately and calculates the waveform of each. [Picture the two waves superimposed on an oscilloscope screen.] They are not the same. We ignore the amplitude. The frequency is identical, but one is ahead of the other. This is called phase shift. The measure of the difference between them is the phase angle. Capacitance causes voltage to lag behind current. Inductance causes current to lag behind voltage. In either case the phase angle is between 0 and 90
o.
Apparent Power is VA, a simple calculation. The actual energy available for the user to put to work is the Real Power, represented by the area under the curves, which is considerably harder to quantify. [The area under the curve for a true sine wave is 0.707 of the peak, which is the RMS value.]
The phase angle (
0) is calculated from the waveform data. Mathematically, the power factor is given by the cosine of the phase angle. The power factor is also defined as real power (P) divided by apparent power (S). So cos
0=P/S, and BINGO the meter has everything necessary to tell us how much power is going out by reading the inputs only.
There are a couple of things that still bother me, but I will keep them to myself for now to avoid muddying the waters with nonsense.
Edwin?
[Or anyone else who really understands this shit, but no one else has stepped up so far.]
