i get what you are saying, but i have different experience with my equipment. its a tall (54") potstill...but just by virtue of re-running them you are in fact on your second distillation cycle. by diluting with water, i'm basically hydro-separating the same as you...but with the addition of heat.Odin wrote:My two cents: on a potstill I don't rerun feints as is. You just get more smearing and bigger heads and tails cuts the next run, because the separation power of a potstill is, well, limited (like 1 distillation cycle). Still, since those heads and tails contain lots of good ethanol, what I do is hydroseparate them I dilute them to 17%, so heads will sink off and the oily tails will start to float on top. I syphon out the middle 50% and rerun that with the next spirit run. The feints container gets the new heads and tails cut and because heads and tails concentrate (remember, you take out 50% of pretty good ethanol after hydroseparation) better, you can even see them (if you have a glass feints receiver): foggy bottom (sorry) and oilsy on top. No pun intended.
Regards, Odin.
every time i do a 1.5x distillation, the second go those feints are 2.5x distilled, the third time those same original feints are 3.5x distilled, the second one 2.5x and the latest batch is 1.5x (all mixed together) my experience says the spirit gets better, more flavour and a larger hearts cut.
with each distillation i get more hydro-separation, or scrubbing of the original run. since i'm compressing the fores and tossing them each time, and leaving more and more tails in the boiler when i'm finished, which is also disposed of the feints jar gets cleaner and cleaner with each distillation.
this is just anecdotal evidence of my experience, not science. when i do the first stripping run of, lets say an AG...it is very cloudy. when i re-run these, the spirit run is clean, and the feints don't get cloudy until the tails. when i 1.5x, the cloudiness in the tails comes less and later.
