Sorry nomoon, I've been off-line for a while and I didn't see your post. 3 feet might be a little short,nomoon wrote:I'm leaning towards an air cooled condenser after some thought. I want to be able to do this without a supply of water because I want to do this on the second floor of an unplumbed barn.
I found this at Home Depot. http://www.homedepot.com/p/Unbranded-Fi ... /202312893" onclick="window.open(this.href);return false;" rel="nofollow
Nice price, nice length. For Mason Jar and Shadylane... Do you think 3 ft will be enough? There is also a 4 ft for 40.00.
depending on how much power you are putting into your boiler. My condenser is 5ft long and it can
knock down everything my burners can throw at it. I measured about 1.6kW of steam (not heat input,
but rather actual steam) and less than half of the condenser was warm. See page 3 of my thread
here: http://homedistiller.org/forum/viewtopi ... 6&start=60 if you want a little more info. Based on that I could
have gotten by with 4ft I think. I suspect you could as well, unless you have a REALLY powerful burner.
Yes, it really is that simple. I like the way shadylane built his condenser using a box fan and zig-zagnomoon wrote: Other than the fins, I need a fan and the connecting pluming. That's about it, right? It sounds too simple.
finned tubes because it's a bit more space efficient than my design, but I think mine is easier to build
since you don't need to solder up all the bends in the pipe. If you have got the space, and don't mind
using several of those little computer fans, I would suggest just using one 4 or 5 ft section of the finned
pipe with 6 or 7 fans mounted on it. Simple and very effective
