4 inch dephlegmator build
Post your builds here.
Re: 4 inch dephlegmator build
I love this forum, I get to learn how other people build things from the safety of my keyboard.
Here's one more look at the dephleg from a different angle before I put this part of the build to rest and move on to the next.
http://homedistiller.org/forum/viewtopi ... 50&t=58012
Looks like it's in a hurry to get some were :lol: :lol: :lol:
frodo
Location: hiding behind a pine tree. bout 100 miles east of new orleans
Post by frodo »
I know this thread is old.
but i ran into the same thing as you did chasing leaks on a shotgun
like playing wak a mole at the fair
that did not work..
ripped out the copper and added SS tubes
Tazewell
Post by Tazewell »
@shadylane is the 1/2 tube from this build OD or ID?
Reason: removed unwanted advertisment
pope
Post by pope »
I'm currently working on an all-copper dephleg and have the same issue with welding copper. Without back-purging the inside, every time I try to fix pinholes I just boil more oxide up from the inside to the surface. My plan is to test the cylinder for leaks.. if I don't have any lucky me, I'll weld the plates and solder the inner pipes. If I have leaks, I solder the inside of the weld to fill them, then solder everything else onto the thing.
Tazewell wrote: Thu Dec 14, 2017 12:08 am @shadylane is the 1/2 tube from this build OD or ID?
It was 1/2" OD
pope wrote: Fri Nov 08, 2019 12:00 pm Without back-purging the inside, every time I try to fix pinholes I just boil more oxide up from the inside to the surface. My plan is to test the cylinder for leaks.. if I don't have any lucky me, I'll weld the plates and solder the inner pipes. If I have leaks, I solder the inside of the weld to fill them, then solder everything else onto the thing.
I wound up welding everything but the tubes, those I silver soldered.
I may be wrong, but backpurging isn't needed for welding copper
pope
Post by pope »
I noticed a lot of black sooty oxidation on the inside surface of the pipe when I welded, so I'm assuming purging that area of oxygen would help keep it from oxidizing. I think a lot of the contamination I got was from that. A pro buddy suggested backing the section with a heat sink like aluminum, which would help avoid pushing the liquid puddle through to the other side. I'd also say helium would probably help since copper sucks so much power, but I opted to not buy anything else! The copper fittings were expensive enough as-is.
Halfbaked
Post by Halfbaked »
Beautiful work shady
pope wrote: Fri Nov 08, 2019 4:21 pm The copper fittings were expensive enough as-is.
No need to buy big fittings if Ya have scrap copper and a tig welder :wink:
On a side note. After all this work I found out.
Using coiled tubing to make a drop in dephleg is easier, cheaper and better
Than making a shotgun dephleg
shadylane wrote: Sun Nov 10, 2019 1:53 pm
Not sure I totally agree with that full statement as my shotgun condenser is a lot sturdier than my condenser coil. Many members have kinked a lot of coils trying to wind them although for me the coil was easier to build and cheaper.
The best way to learn, is to try all the options.
And I've got the scars to prove it :lol:
pope
Post by pope »
My buddy has a metal lathe so guess at least theoretically I could make my own copper ferrules. Just that time = money thing and where xyz falls on the spectrum. If you did a 4” dephleg with a coil, what kind of coil are we talking? Double helix with a cold finger? 1/4” tubing?
Here's a couple different dephlegmators
viewtopic.php?f=87&t=74391
pope
Post by pope »
Damn man! That's a lot of fabrication there. I might have to add a dimroth dephleg condenser to my build journey some day, I did really enjoy making one for my 2" boka.
shadylane wrote: Fri Nov 08, 2019 2:11 pm
It was 1/2" OD
Quoting myself to correct for a mistake.
The tubing is 1/2" ID
I also found a pic of Sassy here on the post I'd forgot about.
The best dog that ever owned me.
I could "think" about going outside to piss and she would go check if it was safe.
