Whoohoo!
It's been a long time coming, but the Mashimizer is alive and so far, exceeding my expectations.
I built a support frame for the Mashimizer so that I can wheel this thing around. The boiler just sits on the parallel bars and tilts very easily. Makes dumping the contents effortless
- Back view
I ran a 4% citric acid solution at 180F for 2hrs in both the inner and outer vessels to passivate my welds. That went well, I did discover a pinhole leak in the outer vessel. That was fixed in a jiffy.
Here's a front view with my super-duper levelling device. This makes sure that my (not built yet) column is perfectly vertical and stabilises the boiler.
- Levelling device
Ok, so far so good. Now for the real test.
I loaded up the boiler section with water. I then leaded the mash section with about 5 gallons of water for the next test.
Powered up the unit at 100% power, 5500W element.
After about 1 hr the contents were at 88C (I loaded her up with the hot water tap @60C).
At 92C the boiler was actually boiling, you could definitely hear it and the steam began to flow through the check valve into the vessel.
It then took about 1/2hr for the water temperature to go up to 98C. I normally stop my runs at 98C, so this is definitely a successful test.
Water at my elevation normally boils at 99C.
- Boiling
Here's a shot of the controller.
- Success!
I've got a batch of wheated bourbon ready for a stripping run.
I'm going to transfer the whole shabang to the Mashimizer and strip it on the grain. I'm hoping to increase my yield by about 30%
Yea baby. YEAH.
Oh, yea I almost forgot ...
Is anybody following this?
I'm feeling pretty lonely here
