![Clapping :clap:](./images/smilies/icon_clap.gif)
Love the hole pattern .
![Crazy :crazy:](./images/smilies/icon_crazy.gif)
![Thumbup :thumbup:](./images/smilies/icon_thumbup.gif)
Did you sort this out ?DetroitDIY wrote:Quick question regarding the sieve plates. I've been soldering them in place, and soldered one with a 1/8" tilt across the 4" diameter. That's an angle of ~1.75 degrees (slope of 1/32). Does anyone know whether this slope will cause an issue or not?
Cleaning is NOT an issue, a bubbler needs nothing more than a rinse out with fresh clean water after each run.dan wrote:You are going to find it hard to clean your final product condenser tubes with the 90's in the way. I finally went with a 4" to 2" stainless reducer and a 2" 180 to make my life easier. It is super nice to be able to break your column down into small components for cleaning.
With flamage vapor there is no acceptable leak. post a question in a thread and I'll bet you will get helpDetroitDIY wrote:Quick question for the veterans (or not) out there. I have a stainless tri-clamp fitting that I've been trying to sweat to a 2" Cu elbow. I've added a 2" Cu pipe cut off inside the end of the elbow, and the ferrule sleeve is tucked inside of that... the ferrule to pipe fitting is not tight. I've done this a few times in the past, but this one's giving me fits. There is a sneak path leak that is dripping about 1 drop water / 58 seconds with 6" head on it.
The question is, is that leak rate OK? Or do I need to get in there and try to clean it up (again)? Or is re-work silly and I should just smudge some flour paste on it? Thanks in advance for the advice.
DetroitDIY
If you use a light DOUGH that won't happen.thecroweater wrote:Some guys will say flour paste is the cure all, I found if its in joints where it can't bake before vapours hits it it will wash out and leak through. I'm with AC on this, find the problem and sort it
