Cooling water
Re: Cooling water
Is your fan facing towards the ceiling or towards the ground?
Also, you said you used 3-4 buckets. Looks like only two where needed. Could you explain a little bit?
Re: Cooling water
WhenWildcatdistiller wrote:Is your fan facing towards the ceiling or towards the ground?
I face the fan up. I tried down as well, this worked better. 3-4 bucket confusion: I previously ran a worm styled condenser in a 5gallon bucket and it took me 3-4 times (bucket fulls) replacing the water (it got too hot).
I used two 5 gallon buckets to build this. I also have a better design (higher capacity) I haven't built yet.
Re: Cooling water
looking foward to seeing the new design
Modular 2" Pot Still
Re: Cooling water
It's been a while since I visited this topic, but here's a simple build for recirculation of cooling water. I built this out of things I had lying around. The only water loss is evaporation. I am using a home built shotgun liebig and run it as fast as it can condense. I typically run 15 gallons of mash thru a thumper with a yield 2 gallons of 115 proof. The cooling tower water does heat up, but also keeps up. I can reuse the same water for a few 15 gallon runs without adding any.
Re: Cooling water
Cool, I like the new developments! So the air is now being drawn in through the holes drilled around the lid of the reservoir? Are you using the colander to shape a dome of the AC filter material? Great work!
Re: Cooling water
I really like this idea. If set up correctly, I can see how an undersized cooling setup could easily keep up. Or even keep up when running hard.
Ive been around these type of fans/coolers for years. They work wonders when its 90%+ humidity & 100*+ Chicken houses use the same thing as the fans, just scaled WAY up. Scaling it down or even using one in the cooling system could work since they have built in pumps.
Re: Cooling water
Kimbodious,
The collander was a cheap plastic one, about a dollar. It was a cheap, easy way to hold the media and already had holes for the water drainage and airflow.
This entire idea saves me from wasting alot of water. I wonder how much waste a liebig has if it just runs out on the ground over a 15 gallon mash run.
- FlintHills
Re: Cooling water
That is pretty impressive that 5 gallons is able to cool your 15 gallon still. I finally got a chance to do a cleaning run done on my unit and decided to try out the cooling system, only using a five gallon bucket and it didn’t stay cool for long. Ever since, I’ve been racking my brain trying to determine a cooling method that will work well enough to start my first run. I think this will help me out a lot! So thank you Being my unit is a bit bigger I think I’m going to try your concept with 20 gallon barrels
Re: Cooling water
Flint,
You could use a cheap box fan and a 55 gal drum pretty easily.
I doubt this $15 harbor freight pump will meet your demand if you're alot larger.
My intentions are to get another keg and increase to a 30gal pot. I may or may not have to upgrade cooling. I'll try this first.
- FlintHills
Re: Cooling water
A 30 gal is what I currently have, I have a decent pump I believe, I’ve been struggling with the water capacity I may need or a way to help cool the heated water. A box fan and a drum may be a sound idea, I wonder if a box fan would pull enough cfm to make it efficient?BamaBill wrote:Flint,
Re: Cooling water
I would think so, this little fan I'm using will handle a 25 gal pot. If not you can always use the fan the next time to blow on you while you're out there. Lol
What kind of condenser are you running?
- FlintHills
Re: Cooling water
I use a 24” Liebig. As I tend to go up and beyond what is necessary, I picked up 2x 44 gallon brutes and a 14” floor fan; I’m working towards build a larger version of what you builtBamaBill wrote:I would think so, this little fan I'm using will handle a 25 gal pot. If not you can always use the fan the next time to blow on you while you're out there. Lol
Re: Cooling water
Visited a distillery yesterday and he hasn't changed his tanks of water in years, every thing is cooled with radiators. Impressive set-up wish I would have taken pictures.
- FlintHills
Re: Cooling water
I always wish I would take more pictures when I go to them. I went out to bluefish dillery in Colorado, he’s a member in here, he keeps 2 ibc totes for cooling water and only has to top them off maybe once a yr. I wish I had enough space for that lolBushman wrote:Visited a distillery yesterday and he hasn't changed his tanks of water in years, every thing is cooled with radiators. Impressive set-up wish I would have taken pictures.
Re: Cooling water
The radiator is not a working radiator he just ran a fan at it while the water past through the radiator, I see an experiment in my future.
- FlintHills
Re: Cooling water
I gotcha! I actually found a few cooling (maybe heating) coils that came out of a small fridge from a different project, I thought I’d do the same if for some reason my current cooling build doesn’t sufficiently cool the waterBushman wrote:The radiator is not a working radiator he just ran a fan at it while the water past through the radiator, I see an experiment in my future.
- bluefish_dist
Re: Cooling water
Yep, use two ibc's for cooling. They work great in the winter, but struggle a little in the summer as it takes longer to cool down and they don't get as cold. 60 deg winter, 80 summer for the base temp. I have considered adding a radiator to the return line to help shed some heat.FlintHills wrote:I always wish I would take more pictures when I go to them. I went out to bluefish dillery in Colorado, he’s a member in here, he keeps 2 ibc totes for cooling water and only has to top them off maybe once a yr. I wish I had enough space for that lolBushman wrote:Visited a distillery yesterday and he hasn't changed his tanks of water in years, every thing is cooled with radiators. Impressive set-up wish I would have taken pictures.
Formerly
Dsp-CO-20051
Dsp-CO-20051
- Oldvine Zin
Re: Cooling water
Something like this?
OVZ- FlintHills
Re: Cooling water
I was pretty impressed with your solution to retain the water. It wasn’t something I had thought about yet when putting my setup together. But I’d imagine it’s pretty cost saving over the long term.bluefish_dist wrote:Yep, use two ibc's for cooling. They work great in the winter, but struggle a little in the summer as it takes longer to cool down and they don't get as cold. 60 deg winter, 80 summer for the base temp. I have considered adding a radiator to the return line to help shed some heat.FlintHills wrote:I always wish I would take more pictures when I go to them. I went out to bluefish dillery in Colorado, he’s a member in here, he keeps 2 ibc totes for cooling water and only has to top them off maybe once a yr. I wish I had enough space for that lolBushman wrote:Visited a distillery yesterday and he hasn't changed his tanks of water in years, every thing is cooled with radiators. Impressive set-up wish I would have taken pictures.
That’s pretty snazzy! How’d you go about finding a radiator that was almost the same size as your box fan?Oldvine Zin wrote:Something like this?OVZ
Re: Cooling water
I bet a transmission cooler HEX would work great. Check out your local automotive parts shop. They'll have them. Maybe even the Walmarts.FlintHills wrote:That’s pretty snazzy! How’d you go about finding a radiator that was almost the same size as your box fan?
Re: Cooling water
Do you mean something like this? They're transmission coolers and are available from Amazon. They heat the basement pretty well.still_stirrin wrote:I bet a transmission cooler HEX would work great. Check out your local automotive parts shop. They'll have them. Maybe even the Walmarts.FlintHills wrote:That’s pretty snazzy! How’d you go about finding a radiator that was almost the same size as your box fan?
Re: Cooling water
RedwoodHillBilly are you doing a full run with only a sink of water? That's impressive!
Re: Cooling water
Normally, yes it will. If I run it in extended reflux, I might need another sink full. In pot still mode, it has plenty of cooling capacity with just one sink full.Bushman wrote:RedwoodHillBilly are you doing a full run with only a sink of water? That's impressive!
Re: Cooling water
I love the transmission cooler, fan idea. my still is small at only 8 gallons....think I could get by with a single cooler unit, or small radiator with fan blowing through it?
Drink tonight.....For tomorrow We Ride!
- Oldvine Zin
Re: Cooling water
Was working on a BMW 320i and bingo saw the radiator was about the right size. A friend had an almost new one that wouldn't pass a pressure test, traded for a bottle of wineFlintHills wrote:
OVZ
Re: Cooling water
Bloody hell Redwood HB . How did you get away with screwing that sexy cooler to the Kitchen wall
I see my nuts kicked hard Iff'n I even thought about it
Re: Cooling water
Hijack much! BamaBill's compact efficient design cools the water directly by making it fall down a column of chilled air and through a chilled permeable layer.
Re: Cooling water
The "kitchen" is in the basement. It's my lab/man cave.Yummyrum wrote:Bloody hell Redwood HB . How did you get away with screwing that sexy cooler to the Kitchen wall
