So, you'll be using the ferment, partially, for your final run
Yes. I will cut the low wines with fresh wort. My goal is to have an ABV of 20% for the boiler charge in the spirit run. My takeoff should be in the 65% to 70% range so less dilution before adjusting ABV for the barrel . It will also bring more flavor to the spirit.VLAGAVULVIN wrote: ↑Mon Dec 09, 2019 12:58 amSo, you'll be using the ferment, partially, for your final run![]()
Corene.. I'm assuming that the 50% abv is the overall average.. and if so, what was the reason for stopping the strip run at that level..
I understand saving some for the spirit and mixed with the low wine, but I missing to understand is what will be added to the thumper on your spirit, if you are going to use the thumper.. more wort or some backset..
corene1 wrote: ↑Mon Dec 09, 2019 6:46 am Yes. I will cut the low wines with fresh wort. My goal is to have an ABV of 20% for the boiler charge in the spirit run. My takeoff should be in the 65% to 70% range so less dilution before adjusting ABV for the barrel . It will also bring more flavor to the spirit.
How much yeast makes it into the boiler will depend on how well you let the ferment clear before using it.VLAGAVULVIN wrote: ↑Mon Dec 09, 2019 7:12 am So interesting intentions but,,, won't the product have caught somewhat "cooked yeast" aroma? And what is your estimation on its aging: few months, a couple of years?
Thanks Corene..
When I built my thumper and pot column my thought was to use it for stripping only 22 gallon boiler and 15 gallon thumper. I thought it would be a great time saver when doing corn whiskies. There always seems to be some slurry that won't clear in these types of mashes. That is where the thumper comes in. Being able to strip these safely without fear of scorching.StillerBoy wrote: ↑Mon Dec 09, 2019 7:14 pmThanks Corene..
As to which still you will you, just some thoughts on a process I been working at..
About 14 months back I did a number of batches of tugboat rye that I first stripped down to 35% overall, did one run using pot and thumper both having wort added to them, 16L in the boiler along with 8L of wort and 4L of wort only in thumper.. the other run I used the same boiler loading and mix with an overall load of 20L, I used the 2" x 20" column on a LM concentric packed with 11mm glass marble.. compressed the heads, then run the body section in a pot mode, then compress some of the early tails..
A week or so back, I sample the two of them, which were all oaked the same way on 4 sticks each per gal jug (filled with 3 1/4L @ 62% and 5/8" x 4" - 2 roasted at 380* for 2 hrs and 2 with the same roast but charred on 2 sides).. and the LM one was very good.. mind you both were nice, but the pot one need a little more time.. whereas the LM is almost there, nice mouth feel and flavour with no burn, with both reduced to 45% and aged for a few days..
So that the route I've been working towards of late.. much easier, much more control in the cut section and selection.. still need to work out the process that will allow me to use less water in reducing to 62.. off the top of head, and I would have to check my notes, the overall run average was around 72..
Mars
No disagreement from me on that statement..
But it's not like that profound filtration stuff all those lagerbeer boys normally use, was it? I used a couple of hillbilly methods only:corene1 wrote: ↑Mon Dec 09, 2019 5:06 pm There should be no yeast taste since there was no yeast in the wort when I distilled it. The turb stays in the fermentation barrel only the cleared wort goes into the boiler and thumper.
The aging will probably be at least 2 years and maybe more. George gave me some of his Rumsky that had been in a cask for 7 years , it was quite good. This is a once used barrel, it had bourbon in it for 3 years so my spirit shouldn't over oak to easily.
I don't do anything special. Just let the wort settle in the cold and pull off the top . The last few gallons goes into another barrel to re settle any turb that gets sucked into the pump, then pull the cleared wort off of that barrel. Never had any type of a yeast taste in my spirits.VLAGAVULVIN wrote: ↑Tue Dec 10, 2019 9:06 amBut it's not like that profound filtration stuff all those lagerbeer boys normally use, was it? I used a couple of hillbilly methods only:corene1 wrote: ↑Mon Dec 09, 2019 5:06 pm There should be no yeast taste since there was no yeast in the wort when I distilled it. The turb stays in the fermentation barrel only the cleared wort goes into the boiler and thumper.
a) bentonite (for sugar-based) and
b) kick the wifie in the cold (for grains).
Both work but some suspension remains, anyways... what was your clearing manner/skill?
Once upon a time I over-oaked my bread-ish distillate and was forced out to re-distill it. The oak tea had gone then. But kinda peppery and spicy stuff was added. I dropped the fair amount of "used and retired" oak chips in and started to wait. Not sure yet, but seems to my nose I "added a year" to my product by that run. Would such a heat cheer the oxidation of all those "parquets" up?
Holdback some mash/wash to mix in with the 50% stripped to lower it and keep flavor perhaps? Sort of like what was already mentioned?corene1 wrote: ↑Mon Dec 09, 2019 7:47 pm On this stripping run with the thumper inline, I was collecting late heads through early tails from 70% down to 65% I think this is why my average ABV was at 50%. Once I hit tails it dropped ABV very quickly as well as flavor. Might have been a better idea to strip in pot only mode to lower the low wines ABV.
Sweet feed aka corn, oats, barley and molasses for horses.
Only better, corn, white wheat, malted red wheat and malted barley with a gallon of fancy molasses.
