Gin botanicals basket query ????????
Re: Gin botanicals basket query ????????
What is your winebrite filter housing made out of?
sampvt
Post by sampvt »
NZChris wrote: Thu Dec 24, 2020 6:27 pm What is your winebrite filter housing made out of?
Durable plastic that is unaffected by 45% spirit, or is this something they are selling that we shouldn't use. So with that logic, we shouldn't be using racking canes, plastic jugs, plastic equipment that everyone uses in the shed or brewery. I am still waiting to hear what rule I broke, please advise soI can become a better person.
I've already posted a link to the rule.
viewtopic.php?f=15&t=81386#p7644797
Corsaire
Post by Corsaire »
Wine and beer isn't as high proof so there it's all right to use plastics.
Lots of people found plastic measuring cilinders to become brittle and opaque when used with spirits. So leaching is an issue.
Also, the use of plastics can turn into almost religious flame wars. So the forum's policy is don't use it.
I'm a grown up and you can do whatever you please in your own home. But you shouldn't advocate using plastic with high proof alcohol here.
sampvt
Post by sampvt »
Corsaire wrote: Fri Dec 25, 2020 3:08 am Wine and beer isn't as high proof so there it's all right to use plastics.
Thanks for the explanation, pity I wasn't pointed at this particular section of the rules, so I knew what was being mentioned. Now I realise. I am aware that high proof spirit causes problems with plastic, but the only plastics I use are PDFE and are supposedly recommended fit for purpose when dealing with spirits under 45% which is all I do. Ive changed to glass measuring jugs glass cylinder for proofing, copper elbow joints on my still and high density pdfe thick non yielding tubing that comes with the still for the spirit out feed. I cant change anymore to be safety conscious and the wineebrite filter come with carbon filter pads specifically for use on spirits, so I thought I was ok there as the plastic they use looks food grade PDFE, Anyway I now realise it is an emotive subject and ill measure my responses accordingly, thanks for the exact explanation I needed.
What is PDFE?
sampvt
Post by sampvt »
NZChris wrote: Fri Dec 25, 2020 11:17 am What is PDFE?
HDPE, sorry we all make typos occasionally. High-density polyethene I think. I get mix up sometimes hardly.
Make good cuts......run enough reflux dont rely on temps to run the still and then there is no need for carbon filtering.
sampvt
Post by sampvt »
Saltbush Bill wrote: Fri Dec 25, 2020 2:29 pm Make good cuts......run enough reflux dont rely on temps to run the still and then there is no need for carbon filtering.
Thanks Bill but it wasn't about filtering spirit, the post was about the haze from mixing water with gin and I said I got rid of mine by using a filter padsoaked in water and Chriznz scolded me for using plastic, then I , not knowing, defended the filter I used and he scolded me for breaking the rules which I apologised for. :(
Don't read into my posts more than what I say, please.
I told you that I wouldn't use that filter on my gin and, at the same time, gave you a link to the forum rule on discussing plastics that was in place before I joined this forum.
sampvt
Post by sampvt »
NZChris wrote: Fri Dec 25, 2020 4:47 pm Don't read into my posts more than what I say, please.
Chris. the last thing I want to do is fall out with you. I respect and follow you with great interest, but in a truthful critique of your posts and hopefully, my critique will be taken as an observation and not a slant or dig at you, but ie read enough of your posts to know that you are a man of few words and in many of your posts, you give the guts of the reply but leave the giblets to one side hoping the reader gets the gist, without actually saying anything pertinent. Ergo this leaves most of your posts open to the reader interpretation. Why didn't you just say we don't advocate discussions on plastics and that would have been great, instead of pointing me at a rule book that had myriad of points which I couldn't relate our issue to.
Those rules.....All of them, should have been read at the very begining......this conversation would not now be happening.
sampvt
Post by sampvt »
Saltbush Bill wrote: Sat Dec 26, 2020 7:49 am Those rules.....All of them, should have been read at the very begining......this conversation would not now be happening.
they were read but maybe not digested verbatim. my issue was assigning the rule he was subliminally pointing at.
Go back and read that first post. As well as giving you the link, it says “rule i”.
I didn’t tell you we don’t allow discussion of plastics with distilled products, because I’m not a moderator. I’m just a member of the forum, the same as you.
