It does, the higher the takeoff rate, the less reflux there is. They are generally very dependant on each other. Youe either control the takeoff rate, which affects the reflux ratio, or you control the reflux rate, this changes the take off speed.Steve Broady wrote: ↑Sun Apr 13, 2025 4:25 pmTrue.. but doesn’t that directly control/impact the reflux ratio? Or am I misunderstanding something g?OtisT wrote: ↑Sun Apr 13, 2025 1:34 amHi Steve. I think the M in Management stands for the management of the take off rate. I may be mistaken. Could not find and answer for sure with some searches.Steve Broady wrote: ↑Sat Apr 12, 2025 5:48 pm
I think it’s worth point out that the “M” in LM, VM, CM, or CCVM or referring to the means of controlling the reflux ratio.
LM, VM, CM still designations.
Re: LM, VM, CM still designations.
Sure, adjusting the V or the L or the C can impact the reflux ratio and it also can change product ABV, but I was talking about what the definition of VM, LM, CM is and I’m pretty sure the M is not in reference to the reflux ratio. People don’t measure the reflux ratio, they measure product output.Steve Broady wrote: ↑Sun Apr 13, 2025 4:25 pmTrue.. but doesn’t that directly control/impact the reflux ratio? Or am I misunderstanding something g?OtisT wrote: ↑Sun Apr 13, 2025 1:34 amHi Steve. I think the M in Management stands for the management of the take off rate. I may be mistaken. Could not find and answer for sure with some searches.Steve Broady wrote: ↑Sat Apr 12, 2025 5:48 pm
