Throw in some fresh sage from the shop.
Probably work?
NormandieStill wrote: ↑Sat Mar 05, 2022 2:15 pmI just made a test batch of gin with camomile and lemon balm (melissa). Both at 0.16g / litre. I find it very herby. Neat the juniper is very present but mixed into a G+T you get a strong herbaceous cut grass odour. It's only been a week since I distilled it though so it might yet settle out some. I'll be interested in how you get on with the addition in yours. It'll help establish whether it was the camomile or the lemon balm that added that note.
That's an interesting idea, but my hand-held blender is plastic. Perhaps when we get a SS one I might try it...
...then again, I'm rarely that pressed to run a new gin. I can afford to let it macerate for a few days before running it.
Can't even get my hands on fresh. I am off to have a look again in 30min.
Thanks for the tip, I do not know if we have it here, I will check.MereCashmere wrote: ↑Sun Mar 06, 2022 7:21 am @art-
If you can get your hands on sum “confetti bush” I think you’ll be very pleased. It’s like lemon, liqorish, raisin, and basil all wrapped up in one gentle plant.
Sounds like you might have got some carry-over from the previous batch. You really want as clean as possible for gin (or complimentary flavours if you know the flavour profile of your botanicals). Personally I wouldn't use a neutral that tasted bitter to make gin. That sounds like early tails to me.
Andrew_90 wrote: ↑Mon Mar 07, 2022 11:56 am Ok so the pilot run is over. I have the equivalent of 4 x 750ml bottles busy stabilizing waiting for the water to get to temp before final dilution.
So some important notes;
I had 7 000ml @ 45% ABV of a previous batch of Gin (horrible tasting) which I decided to mix with my fresh stripped sugar wash of 27.6l @ 33% ABV. The output from the CCVM was 96% ABV spirit. One would have though that the bad tastes would have been stripped out. Could the strong taste have carried through despite the high ABV?
I took enough from this batch to do a trial run of 4ea 750ml bottles. When the run was over I took a little more and diluted it to make a double tot to sample with gin.
The nose is not as clean as I would have thought, I cannot put my finger on the smell.
There is a bitter and unpleasant aftertaste, very much in line with the previous poor batch.
The same smell and taste exist as per a batch when I thought I had added too much Mandarin Peel. No Mandarin in this batch????
Extremely disappointing.
So the only botanical that is strong and in abundance are the Juniper Berries, so I chewed on one to see if the taste was Juniper, it was not. I am totally stumped.
Am am going to chuck the entire batch. Any ideas for me?
Agree with that, some of my gins really smell harsh especially at day 1 and just after I dilute the gin, so as NormandieStill suggests waiting could change the overall taste especially after 2 weeks, but for gin you need the pure hearts, it should be clean because you want the taste the overall taste of all the botanicals you include if you didn't make the cuts correctly and lets say you got some early tails, that will carry over even you distill with a CCVM still.NormandieStill wrote: ↑Mon Mar 07, 2022 12:48 pmSounds like you might have got some carry-over from the previous batch. You really want as clean as possible for gin (or complimentary flavours if you know the flavour profile of your botanicals). Personally I wouldn't use a neutral that tasted bitter to make gin. That sounds like early tails to me.
Not that this helps you now. I'd let it sit for at least a week if not two before trying it again and see if it balances at all. If not... back in this still with it and take great care with your cuts.
One last thing, I understand that you wanted to save your previous gin batch that was not very successful, but while trying to save the old batch you are risking and mixing your pure hearts with an old gin that has already been macerated with botanicals, but as I said before, I suspect that maybe there is a problem with you initial fermentation. can you confirm how was your first spirit run tasted when you reached hearts did you taste it ? How was it ?Andrew_90 wrote: ↑Mon Mar 07, 2022 11:56 am Ok so the pilot run is over. I have the equivalent of 4 x 750ml bottles busy stabilizing waiting for the water to get to temp before final dilution.
Andrew_90 wrote: ↑Mon Mar 07, 2022 10:13 pm Thanks all.
@arto. I use Shady's Suger Shine Wash and don't skimp on anything.
@howie. Well spotted, that is indeed a typo, I used 1.9g/l of the the Tea.
Had a smell of the neutral early this a.m. there is no hint of the offensive smell, got my wife to smell it and she says there is no smell but she described my Gin as having a perfumed smell, she is a non drinker.
I tasted some neutral at 07;00 and she tastes neutral.
I wonder if I don't have a bad / poor quality batch of Juniper Berries. The one I had last night was near tasteless and dry.
This is so disappointing.
It sounds like you have missed out on some common reading material and easy solutions.
I totally agree with you NZChris, for example, "Turkish Raki" is an anise based spirit, which you add the anise wait 48 hours and redistill again, for example in this run, you have to capture the early tails, in order to get the anise oils, the easiest test to understand whether you extracted enough anise oils is once you finish the run and dilute it to 50% ABV you drink it with 1 part raki and 1 part water once you add water it has to go cloudy around 38% ABV if it does not goes cloudy it means you did not extract enough anise oil in the early tails, for many tails needs to be discarded, but in this case you need it, same goes with gin as well, if what. you are looking for is a big juniper aroma than you need more juniper oils to begin with. In order to combat touching I am thinking to keep the gin around 50% ABV this is what I do with Raki as well.NZChris wrote: ↑Sat Mar 12, 2022 10:51 pm For some of my gins I include the foreshot after smelling it. Just because somebody, somewhere, recommends discarding a foreshot, doesn't mean that it is the right thing to do for every gin you might decide to make. If your juniper isn't particularly strong, removing a foreshot might be a mistake.
If the foreshot smells like nail varnish I never include it.
I recently made limoncello, following Demy's recipe and the louching is essential. Frankly the clear spirit before proofing looks a lot a urine sample, but the almost shimmering oils if the proofed down one look fantastic. I would tend to agree that while appearance is of some importance, flavour is everything.NZChris wrote: ↑Sat Mar 12, 2022 11:25 pm You don't have to 'combat louching' unless you are selling to a market that expects your product to be clear. As a home distiller, that shouldn't be a problem. Embrace the louche, be proud of the fact that you don't use so few botanicals that your gin is as clear as the finest mountain spring water etc., etc., blah, blah, blah.
God forbid that I should ever have to make an Absinthe that doesn't louche at 50% in the bottle.![]()
Apologies, this ought read .... too way early into heads with heavy Juniper oils coming throughI suspect that you have cut too way early into hearts with the heavy Juniper oils coming through.
