Well water pressure fluctuations and CM, WTF!!!!!!!!!
Posted: Mon Jul 12, 2021 4:05 pm
by BrewinBrian44
Hi Guys,
I may be regretting moving to this house.... Long story short, my water pressure fluctuates up and down with my well system between 30-50 psi "what it reads at the gauge." Anticipating issues with my CM still, I did a little research on here and bought an in-line garden hose pressure regulator. It's supposed to hold 25 PSI rock solid.... well, it doesn't. FINALLY after fiddling with the knobs, I was able to dial everything in to a steady balance of take off and reflux, then I hear the relay click on the water pressure tank and boom, head temps drop like a rock and output comes to a drip.
This is the product I bought, recommended by some members on here https://www.dripdepot.com/item/senninge ... psi-15-psi . I ended up going with the 25 PSI since I'm running the defleg/PC from a splitter on my wash tub tap, both independently controlled with needle valves. I put the regulator on the tap BEFORE the splitter. I'm wondering if if would even help to un-split my water and only run the defleg from the wash tub and the PC from a different hose.
I have a 4 plater with a defleg for reflux and used city tap water before. Had this puppy dialed at the old house! I REALLY don't want to set up big barrels with pumps/radiators as my stillin space is already VERY small. Have any of you guys remedied this issue and have a product suggestion? I'm extremely bummed out.
