Rate My Column
Steelers_Stiller
Rate My Column
Post by Steelers_Stiller »
My goal is to build a modular column that can be used for stripping runs/potstill mode running with the top of the column capped and output coming thru a liebig or, remove the cap from the top, and insert a copper wound coil to introduce reflux.
The main 2 things I'm curious about are
#1- do you think the length above the Tee is too great?
#2- where would be the best location for a thermometer port? I was thing just below the Tee. I intend to solder in a 1/2" NPT copper female adapter into the column somewhere. I have a stainless thermometer with male threads. I've read countless posts here saying a thermometer is not needed and you can't run a still by temperature and threads explaining why you can't. I understand that. I feel temperature is still a valid reference, especially for someone new to all this. Plus, it would look cool. :) Copper porn is half the fun, right?
Any other insight you all have on this setup?
This topic has 80 more replies
Register Login
