Thumper build plans.
TxBrewing
Re: Thumper build plans.
Post by TxBrewing »
waiting on a few parts to arrive, I think I am going to need a scrap of 2" pipe, not sure where to find that, only need like 2 inches or so
Corn Cracker
Post by Corn Cracker »
TxBrewing wrote: Wed Apr 16, 2025 6:03 pm Ok, so after a bunch of this and a bunch of that, I am picking up the copper parts tomorrow.
Decided to just run a 3/4 inch line out of the head into a top feed thumper set up.
I will add a union to connect the run and one off the thumper exit, this will allow me me to switch between a regular pot and a thumper set up.
I have not soldered in about 10 years, but I do not think the small stuff will be an issue, but I am worried about the 2 inch ferrule to the 2 inch tee.
It is a copper to copper connection, is there a video to watch for copper to copper, or does anyone have any pointers.
last will propane be hot enuff? Or should I get Mapp gas?
I have recently learned to start heating the copper a few inches above the ferrule and work it down, with map gas I didn't have to actually put the flame to the ferrule.
If your around Houston I can help ya with a bit of 2 inch, no problem
I think I'll go home and fire up my still, it might not make me feel better but, I bet it will
TxBrewing
Post by TxBrewing »
Corn Cracker wrote: Tue Apr 22, 2025 2:01 pm
I used to be in the Houston/Galveston area, that is where I grew up.
The army took me away, and when I retired in 2017, I stayed in Colorado.
But thanks for the advice and offer
Corn Cracker
Well, at least you're away from the humidity 😅
jackfire57
Post by jackfire57 »
Would like some straightforward advice i have a 18gal pots still and wanted to add a thumper so by design i need at least a 5 gal thumper to be effective . That being said i bought a 21 l /5gal pot with sealed and clamped lid. Now my question is the down and vent pipe positioning , i see some are designed closely together and others far apart which would you advise and any other design options would be appreciated.
Jackfire
Both methods will work . A lot will depend on the lid you have . This will determine the difficulty of adding fittings .It is easier for setup reasons to have all in/out tubes vertical .If the lid is domed , then you will have to be creative on how you seal the tube to the lid , especially if it is thin Stainless lid .
Not that its a big deal if you are handy with metal and soldering . Just cut a copper washer and use a copper coupler ( with the stop filed out on the feed through tube) and solder it all to the SS lid for a solid build .
This is often why the inline method are used . You can simply add a weld-less bulkhead triclamp fitting in the middle of the lid and feed in and out tube concentrically .
This method is also popular fir kegs as no holes need to be drilled in the keg .
You may have noticed the two styles of inline thumpers . Either in at the top and out on the side ( which is the easier if the two) …or… in at the side and out the top ( which is more flexible equipment wise )
Note: A copper washer can be made by cutting open a piece of pipe and annealing ( heating it to cherry red and letting it cool down ) and flattening it between two pieces of wood . While still annealed ( softened) you can easily form it to the contours of your lid.
This isn’t exactly what I mean but you can see how easy it was to press the copper to match the contour of a domed lid .
Another way to fit thump tube is with Brass compression fittings . Use low lead fittings . This took me about 10min .
Ground off hex face on a Compression nipple and cut to angle of lid .I could solder it on but for extra strength added a copper washer.
Cut a copper disc out of some scrap and brazed it to the cut nipple . I could have soldered this on but the heat of brazing means the copper washer will be soft enough to shape to the lid .
Also , it will stay together when I soldered it to the SS lid .
So now , fit olive to thump tube and tighten Kinko nut . Use copper olives , not the nylon as shown .
If you are funny about using brass , you can “Tin” the inside of the nipple with Lead free solder .
