Good info. I've mostly run 15-27 liters in a 35 liter boiler, but this weekend will be running ~50 liters in a 65 liter boiler, so it'll take some dialing in. And this info helps. Thanks!Yummyrum wrote: ↑Tue Apr 07, 2026 9:57 pmyes yes yesMattHoll wrote: ↑Tue Apr 07, 2026 7:39 pmI helped a local brewery run about 1200L recently, and the total run time was something like 7 hours, so seems roughly consistent. Interesting that the greater or lesser volume doesn't affect the run time.NorthWoodsAb wrote: ↑Tue Apr 07, 2026 8:32 am While in Scotland a few years back i visited a distillery, 14000L boiler, about 6 hrs run time, sounds like a law of physics regardless of boiler volume.
This is the key point![]()
Watts per litre of low wines .This will directly result in low takeoff speeds for small boiler charges and high takeoff rates for large boiler charges
Small charges need less power , big charges need more power .
Give small charges big power means very fast takeoff rate and smeared to buggery .
Alas when I ran Potty I was on gas so unable to give magic number , but around 50 watts per litre .
So iff’n yiu have 5litres in boiler , want to run around 250w .
Got 20litres in boiler , want to run about 1kw
50litres , you’d be up around 2.5kw
Offtake speed
- MattHoll
Re: Offtake speed
- Username
Re: Offtake speed
I came upon the column in a round about way so it's what I got and I want to learn it.PalCabral wrote: ↑Tue Apr 07, 2026 12:59 pmYeah, you're right. I didn't catch that, subbrew. I don't have any experience from plated columns either. I always thought though you would need more than one plate to get much of the effect. I am sure it pushes the ABV up a couple of nudges but will it be enough to allow you to push the power up? I don't know.subbrew wrote: ↑Tue Apr 07, 2026 11:43 amHe is running a single plate, so I assume some sort of reflux to keep it loaded. That changes things. I have no experience with that so can't really help. Does a plate let you run faster?PalCabral wrote: ↑Tue Apr 07, 2026 10:40 am With such a high portion of wash in your charge (2/3'ds) and such a low ABV (16%), I would have run it considerably slower. It's basically more of a one and done than a one and a half. But I honestly don't have much experience from one and dones/one and a halfs.
Running a deflag up top, so plate fully loaded, single plate most defiantly makes a difference, hearts stayed at 80% abv for pretty much the full time
It is difficult to find info on plated columns, I'm kinda flying solo but enjoying it
CuriousRay
Re: Offtake speed
Thank goodness I ordered a larger still
Re: Offtake speed
There is a ton of information spread around the forum about running and building plated columns.
You might not find a lot about running just one plate though.
The reason for that is that less than two plates is considered by many to be to fiddly to run and in general more trouble than its worth.
- Username
Re: Offtake speed
Thanks Bill, I'm a couple of hundred hours of reading in, on various subjects and I'm sure I've still to find a lot more info.Saltbush Bill wrote: ↑Wed Apr 08, 2026 3:47 amThere is a ton of information spread around the forum about running and building plated columns.
I didn't find the single plate troublesome from a running point of view, I thought it was comparable to 2 or 3 in that respect, easy to load and keep loaded. I did get lower abv,(obviously) but that was what I was looking for (right or wrong) and more distinct whiskey flavour
I ran very slow to start so separation point of heads to hearts was pretty easy
I must go search again
Any feedback you have on my technique would be much appriciated
Re: Offtake speed
Not sure that I can be of a lot of help, the least number of plates I've tried running was two,
Three is my usual minimum, I'm just going on what I've heard and read a lot of others say over the years.
Swedish Pride a member here has a lot of experience with 2 plates and less from memory , maybe he will pipe up.
- Username
Re: Offtake speed
Much appreciated, my next spirit run is coming due shortly and as it happens it's a RumSaltbush Bill wrote: ↑Wed Apr 08, 2026 9:30 am Not sure that I can be of a lot of help, the least number of plates I've tried running was two,
Not your recipe, molasses is not available at anything like affordable here. But I liked what I got from Jaggery before in a one and done.
I've 20L of low wines at 29%abv and 27L of wash at 8%
I just need to decide what way to configure my still for the spirit run
- Swedish Pride
Re: Offtake speed
From my limited experience i believe 1- 2 plates can work well if you run caps, this is just from reading, never did get caps.
I ran 2 perf plates and it was like spinning plates, constantly fucking about with settings to get it to behave, more trouble than its worth.
Never did try a single per plate but can't imagine it being any fun at all.
Most platers seems to be caps these days, not sure how come, was about even in the early days. Maybe caps are easier to mass produce?
Don't be a dick
MooseMan
Re: Offtake speed
Not to take this off topic, but if you can thump, put rum heads, any trub/cloudy wash from the ferment, and vinegar in the thumper, and the low wines and wash in the pot including any tails you have from the last run.Username wrote: ↑Wed Apr 08, 2026 10:14 amMuch appreciated, my next spirit run is coming due shortly and as it happens it's a RumSaltbush Bill wrote: ↑Wed Apr 08, 2026 9:30 am Not sure that I can be of a lot of help, the least number of plates I've tried running was two,
I just need to decide what way to configure my still for the spirit run![]()
You'll add heaps of flavour to your jaggery rum.
- Username
Re: Offtake speed
Cheers SP, yeah I run Still Dragon pro caps, they are supposed to be easy, I guess they are.Swedish Pride wrote: ↑Wed Apr 08, 2026 10:25 am From my limited experience i believe 1- 2 plates can work well if you run caps, this is just from reading, never did get caps.
I found it no more challenging running 1,2 or 3 plates
- Username
Re: Offtake speed
I don't have the ability I'm afraid MMMooseMan wrote: ↑Wed Apr 08, 2026 10:56 amNot to take this off topic, but if you can thump, put rum heads, any trub/cloudy wash from the ferment, and vinegar in the thumper, and the low wines and wash in the pot including any tails you have from the last run.Username wrote: ↑Wed Apr 08, 2026 10:14 amMuch appreciated, my next spirit run is coming due shortly and as it happens it's a RumSaltbush Bill wrote: ↑Wed Apr 08, 2026 9:30 am Not sure that I can be of a lot of help, the least number of plates I've tried running was two,
Not long after getting set up and blew any remaining budget on Badmo's
Next to get set up to try clone these before I can put more money into my set up
OtisT
Re: Offtake speed
+1 to this approach. Calculate your expected yield then do the math to determine what your collection rate should be. Once you dial in the rate, record your power setting. Each time you do a a similar run (Same volume, ABV) just set the power and your golden.
