FLUTE TALK
Re: FLUTE TALK
I plan to use perf plates, but if they give me trouble I'm going to go with bubble plates instead. I will probably go ahead and make the bubble plates just in case, that way they will be ready to go if I need em.
I shouldn't have any trouble with enough steam though as a use an old burner from a natural gas hot water tank and it puts out crazy heat. As a matter of fact, I can't turn it down enough with the current head I use to get the right output. Instead I have it setting on bricks and when I need to lower the heat I just remove a couple of em and move the burner farther away from the bottom of the pot. Thanks for the comments guys. I hope to get this thing done soon, and yes, you will see it in the family photo album.
The stone age didn't end due to a lack of stones
Re: FLUTE TALK
Thanks Mr. Spooky. I'll see what I can do about the build thread, things are pretty busy here right now though. I am taking pics as I go so I will get it up when I get the chance and go from there.
Shiner
Shiner
Re: FLUTE TALK
We have come a long way in the last year. Twelve months ago no one was even considering using a 4"plated column keg mounted for home use. I was playing around with my Evil Twin 2"twin column plated still, and LWTCS was developing his Humper thumper. I then built the Magic Flute as an experiment just using basic tools to see if it was possible to drive a 4"column from a keg, and to incorporate sight glasses on a home based still.
Since then there has been a whole orchestra of Flutes been built, all with their different variations, but all based on the same theme. Kentucky Shiner was the first to replicate the build, and his results were identical to mine, the high ABV from a single run, lots of flavor, and potstill speed.
I am flattered that so many folks have had the confidence to follow my build, and its great to see even more variations on the theme.
OD
OD
Re: FLUTE TALK
im realy hoping that every piece of this build will be done out of sheet copper (no prefab fittings)
spooky
spooky
Re: FLUTE TALK
I can't wait to get it done. I got the shipping confirmation today for the rest of my sheet. OD, I must give a big THANK YOU for coming up with the idea. The boss is out of the office tomorrow and said he didn't care what we do, said we could have a sword fight if we wanted, he didn't give a damn. Guess what I'ma gonna do.
Spooky, your makin it tough on me. I had thought about doing no pre made fittings, but had changed my mind. So far nothing at all is pre made with the exception of the downcomers and caps. The dephlag is going to be made of sheet but the inside will more than likely be made of 2" copper pipe, but we'll see, I may get creative.
Re: FLUTE TALK
Moonshiner Dave, you just took the cake dude.. That sombitch is looking great.. I love the all copper build.. I have been wanting to make me a boiler from all copper.
How thick is the copper sheet?
Re: FLUTE TALK
Thanks KS. The sheet is 18 oz., somewheres around .024" thick. You should give the copper pot a go, I built mine in the living room floor minus the soldering.(before I replaced the carpet with hardwood flooring)
Re: FLUTE TALK
so you have a good supplier for the sheet copper that you could share?
Re: FLUTE TALK
The 18 oz. I bought from ebay about 3 years ago. The sheet I just ordered to finish the flute I bought from http://www.guttersupply.com. I went with 16 oz., .021",. I don't think 2 oz. a sq. ft. is going to make much of a difference though. I found some 18 oz. 4' x 10' but it was like $400.00 or more if memory serves me. I didn't get it though since I don't need nowhere near that much. I have found that guttersupply is cheaper than what I could find on ebay though, for the same thing.
Edited 1 time to get the dang link to work.
Shiner
Shiner
Re: FLUTE TALK
Here is the latest pics of Dolikeadrinks 4 - 6 - or 10 plate monster, all the hardware is now finished, I just have to cut the cork and teflon seals and cut the glass to go into the sightglass fittings. This still will be able to run in either 4 plate, 6 plate or ten plate modes, depending which column or columns you use.
OD
Dolikeadrink made a 4 to 2 sankey adapter to mount it on my keg so I will be able to do a cleaning and test run before shipping it back to him.OD
Re: FLUTE TALK
OH SH*T!!!! holy melonfarming column. so stoked!olddog wrote:Here is the latest pics of Dolikeadrinks 4 - 6 - or 10 plate monster, all the hardware is now finished, I just have to cut the cork and teflon seals and cut the glass to go into the sightglass fittings. This still will be able to run in either 4 plate, 6 plate or ten plate modes, depending which column or columns you use.Dolikeadrink made a 4 to 2 sankey adapter to mount it on my keg so I will be able to do a cleaning and test run before shipping it back to him.
OD
Re: FLUTE TALK
Holy shit olddog! That sir is a beauty! Just out of curiosity how much is it gunna cost to ship that monster back east? Would have to be atleast a couple of hundred.
I want one!
I want one!
Re: FLUTE TALK
She looks great OD.. that is a freaking beast.. I cant wait to read results from that baby.. If I were you I would have to run a wash through it just to see how she will run.
Looks great.
KS
Looks great.
KS
Re: FLUTE TALK
I am going to do a cleaning run to make sure everything is sealing properly, then it going to have a good polish and make it shine ( excuse the pun)Kentucky shinner wrote:If I were you I would have to run a wash through it just to see how she will run.
OD
Re: FLUTE TALK
This is a sensitive question, but how much did the materials for that beast cost?
ScottishBoy
HD Survival in a Nutshell...
Re: FLUTE TALK
I don't know, Dolikeadrink sent the copper tubes to me with the tri-clamp fitting attached, I manufactured the plates and the sight glass fittings, made the dephlagmater and Graham condenser, and assembled.
OD
OD
Re: FLUTE TALK
whew...40 pages finished and only a couple of pissing contests
my boka looks sad and lonely in the corner now.
Going after lunch to the metal salvage yards to try and secure some 4" Cu
I do have a question on those copper to SS ferrule connections. I am looking for something really clean, like a press fit. Earlier in the thread I saw someone was using a freezer and torch to get a press fit (I think it got soldered anyway). This seems like a sizable chance to take (salvaged pipe may not be the same dimension as modern pipe, and just manufacturing variances) for me. I wonder if a muffler shop can expand 4"
Perhaps I should call the muffler shop
2" Boka on a sanke and a 4" 6 plate flute (learning setups)
Current setup
Wall mounted steam stripper
Wall mounted 6 plate "flute"
50 gallon immersion heated mash kettle
Current setup
Re: FLUTE TALK
You have to be carefull expanding copper. I have done some but you have to go really slow.. I have had some hard copper to split. You might be able to anneal it before trying to expand it but I am not sure if that will help much. On the 2" I freeze the ferrule then heat the copper almost red hot. take the ferrule out of the freezer and you can tap it right into the copper pipe. I always solder mine also just for some extra strength and make sure I get a good seal.
Re: FLUTE TALK
Very cook,
Thank-you KS
Also is there any opinion on 304 vs 316 ss?
I found some fairly inexpensive ferrules and clamps here, http://www.gvc.net/p/242/butt-weld-ferrules" onclick="window.open(this.href);return false;" rel="nofollow and http://www.gvc.net/p/785/double-hinged-clamps" onclick="window.open(this.href);return false;" rel="nofollow
I will try the freezing method on the 4" or at least mic them for measurements to see if it has a hope of fitting (the walls on 4" are surly thicker than a 2")
I need a few pieces before I can start my own flute build thread.
Thank-you KS
Current setup
Current setup
Re: FLUTE TALK
Alright, no worries or belling the copper, really glad I asked. It could have been an expensive mistake.
I figure at worst I can have either the fitting or the pipe interior milled down to fit.
Thanks Guys.
.......So yeah I'm using thinking I'm going to be investigating DLADs rig very very closely, it just screams pro build
Thanks Guys.
Current setup
Current setup
Re: FLUTE TALK
Awesome,
OK OD and DLAD,
Since I'm going to try my damnedest to replicate your build, I have a couple of minor questions
what kind of plates are you using and what kind of spacing?
Looks like all of your cooling tubes are the same size but what size are they 1/2" 3/4" 1"? I was wondering because I want something sturdy enough to handle someone torquing the ball valves (I child proof as much as possible due to occasional stupidity)
What are the lengths of the 4" on the 4 plate and 6 plate lengths.
BTW the lapping of the site glass brass with a 4" grinder blade was pure genius OD.
Hoping I'm not asking questions already overly discussed.
OK OD and DLAD,
Current setup
Current setup
Re: FLUTE TALK
never mind on the length, I figured out how to search OD and DLADs posts
length question answered
The lower section is 700mm and will have 4 plates in it for flavored spirits, The top section is 800mm long which will have 6 plates
sorry about that, ignore anything else that has been already been answered
Current setup
Current setup
Re: FLUTE TALK
Thanks Mikeolddog wrote:Here is the latest pics of Dolikeadrinks 4 - 6 - or 10 plate monster, all the hardware is now finished, I just have to cut the cork and teflon seals and cut the glass to go into the sightglass fittings. This still will be able to run in either 4 plate, 6 plate or ten plate modes, depending which column or columns you use.Dolikeadrink made a 4 to 2 sankey adapter to mount it on my keg so I will be able to do a cleaning and test run before shipping it back to him.
OD
That's awesome mate thanks very much for the effort and attention to detail you put in too your builds, You are a true gentleman and a pleasure to do business with, As I said in the PM please don't put your self out take your time enjoy your Christmas with friends and family, Finish the MMF of and send it in the new year.
Regards: Dolikeadrink
"Your putting on the agony but missing all the style" Ya want a good Still PM olddog
Re: FLUTE TALK
G'Day SB It's not a sensitive question to me, I am in the shed and the missus in the houseScottishBoy wrote:This is a sensitive question, but how much did the materials for that beast cost?
Note
With out HD and OD this would not be possible for me
THANKS HD AND ALL MEMBERS FOR MAKING THIS SUCH A GREAT SITE
Cheers: Dolikeadrink
Re: FLUTE TALK
Sweet, so I will start collecting the obvious parts and impatiently await the finer details
Thanks both of you, This looks amazing.
It's like a personal brick oven. Yeah it's heavy, expensive and takes up 70 sqft and only has one purpose, but its so damned gorgeous I built my kitchen around it.
Current setup
Current setup
Re: FLUTE TALK
Ok for everyone who is questioning the success of perforated plates. This is a 6 plated column I just finished for another member. The plates are all sealed against the walls with solder.. You will see all plates are bubbling very well and did so thru the entire run. I collected at 1 gallon per hour at 90% thru the entire hearts run... How can it be any better.. This was a 10% sweet feed wash. I said on the video the plates were drilled at 7/32, That is wrong they are 3/32.. I had a brain fart.. each plate has 60 holes.
Here you go. check it out...
KS
http://www.youtube.com/watch?v=C_csb0KQCIA" onclick="window.open(this.href);return false;" rel="nofollow
KS
Re: FLUTE TALK
SO I just watched the video... HOT DAMN! Every plate seems to be bubbling away! I may be wrong here, but I swear in other videos I've seen the bottom plates just dont seem to have that much action?!
Dont forget to send an operation manual with that thing!
KS... you are the man!!
Re: FLUTE TALK
Looks great KS. How'd you solder the plate against the column? I don't see any cutting
I do all my own stunts
Re: FLUTE TALK
Once I installed the plates. I make sure it is very clean then use the harris liquid flux. cut a length of solder that will just fit around the perimeter of the plate next to the wall of the colomn. Then take my torch and heat from the outside until the solder melts and attaches the plate to the wall.blind drunk wrote:Looks great KS. How'd you solder the plate against the column? I don't see any cutting
Hope this helps you out.
Re: FLUTE TALK
Pretty short run. I only had about 4 gallon of 10% sweet feed wash.. It was over pretty quick. The gallon an hour was calculated. by the speed. I only got about half gallon of hearts.rockchucker22 wrote:How long was the run? How much mash was in the boiler? Looks good.Kentucky shinner wrote:Ok for everyone who is questioning the success of perforated plates. This is a 6 plated column I just finished for another member. The plates are all sealed against the walls with solder.. You will see all plates are bubbling very well and did so thru the entire run. I collected at 1 gallon per hour at 90% thru the entire hearts run... How can it be any better.. This was a 10% sweet feed wash. I said on the video the plates were drilled at 7/32, That is wrong they are 3/32.. I had a brain fart.. each plate has 60 holes.
KS
