Re: CM Still Output Improvement Mods Mile High / Brewhaus PSII.
Posted: Sat Mar 13, 2021 6:54 am
Prairiepiss... Thanks for this sticky! I have tweaked my process by using some of your mods for great improvement.
I use a Grainfather kettle with a Mile High dual purpose still. My first vodka run was 82%... believe it or not... it tasted good since it was the Teddysads FFV... but it wasn't clean. After using some of your mods I hit 95% with a TPW... it is really good and clean. The wash was 4.5 gallons at close to 7%. I pulled 1.35 liters of 95%, .5 liters of faints at 75% when blended, and threw out 100ml of foreshots. Total time from turning the power on to stopping power was just under 4 hours. I could have taken the tails down further... but I was too darned giddy about getting 95% that I was happy with the outcome to waste much more time.
So the modification that I think helped the most was using the copper mesh in the reflux condenser. I put the filter screen for my sight glass below the condenser to break the flow of liquid as well. I couldn't find anything to make a conical to break up the flow... thus the filter screen.
I also split the water lines. The water line to the liebig condenser ran at a trickle. Once the top of the column was hot to the touch I ran the water full blast in reflux condenser... then adjust accordingly over time.
As I stated, I have a Grainfather for the kettle. I had an older controller since it is an older model. That only allows 1600w and 650w... works for stripping but hard to control power output. I forked out some change for a new controller since it has the capacity to adjust power level (it will also allow me to modernize my brews a little better... another positive). At the same time that I hit full blast with the water, I pulled the power back to 80% (appx 1300 watts). It wasn't long before it hit equilibrium and it was a thing of beauty!
As for the columns... I did keep a mixture of copper mesh and ceramic raschig rings. At the bottom of the column I have two rolls of copper mesh. Then I fill the rest of the column with the ceramic raschig rings. It seemed to work great and since I got that great recovery I am reluctant to change. (just a question for anyone who reads this... would you think about putting just copper mesch in the column maybe 3 or 4 rolls? Or use steel raschig rings to keep temps a little consistent?)
Once again, THANKS! The little things... I did take good notes and made sure to document your changes in my log.
