Uncle Jesse
Site Admin
Post by Uncle Jesse »
Saltbush Bill wrote:
Uncle Jesse wrote:Whoever modified my recipe to change "flavor" to "flavour"... it's spelled "flavor"!
:wave:
That U.J. depends on what part of the world you live in.
Yep and in my part it's flavor.
We don't try to cheat at scrabble!
Post by The Baker »
I do, I'll use the proper spelling or the American quite happily.
The Baker wrote:I do, I'll use the proper spelling or the American quite happily.
:thumbup:
Uncle Jesse
Site Admin
Savor the moment!
:lol:
HDNB
Post by HDNB »
:wave:
when you do this wash Jesse, what colour is the wash? do you ever keep temperature charts on the vapour?
Have you ever seen your spouse trounce on a mouse that pounced on a grouse? Was she lounging in a blouse in the house before she put a few ounces on the mouse?
just a thought, but i guess that's enough ou words.
:roll:
now i drink for evil.
Pikey
Post by Pikey »
Should, could, would, mould, poured .......
Uncle Jesse
Site Admin
Ah you blokes!
HDNB wrote:Have you ever seen your spouse trounce on a mouse that pounced on a grouse? Was she lounging in a blouse in the house before she put a few ounces on the mouse?
Some what off topic but anyway.
If the plural of house is houses and the plural of mouse is mice, why shouldn't mice be mouses and why shouldn't houses be hice?
Don't matter where your sitting or how ya look at it the English language is a strange thing.
Post by The Baker »
And the plural of spouse should be spice?
Post by The Baker »
Then there was the time I delivered bread to the hospital kitchen.
A mouse ran along the bench top and quick as a flash I flattened him with a pound of butter.
Geoff the mighty hunter
Post by The Baker »
Pikey wrote:Should, could, would, mould, poured .......
For a fantastic read on the weirdness of English spelling and pronunciation google The Chaos.
cosminman
Post by cosminman »
Hi guys. I am planning to start a UJSSM as soon as I finish my pot still build. I was wondering, since I will have a new still to clean, if after running vinegar wash for cleaning I could run the 1st generation of UJSSM as sacrificial run and use the backsets to sour the 2nd generation? I mention that only the still is new, the pot is a 50 liter electric pot that I also use to brew beer, so it does not need cleaning. I have to clean only the freshly soldered copper still.
Also, does anybody use a pot still with thumper for UJSSM single runs? If yes, could you tell us a little bit about the ABV's you get from a single run?
acfixer69
Post by acfixer69 »
The backset from the sacrificial run will be full of the crap just cleaned. So no
AC
cosminman
Post by cosminman »
Doesn't the crap get carried away by the steam? I repeat, the crap would be only in the copper riser, arm and condenser. The pot is stainless and has been used many times... Does the crap fell down in the pot or something?
acfixer69
Post by acfixer69 »
Yes there is passive reflex in the pot. Not going to argue it, it is a sacrificial run. You asked. I answered. As with all things you can do what you want.
AC
cosminman
Post by cosminman »
I really appreciate your answer, I did not think at that. Will definetly do a simple sugar wash for the sacrificial.
sltm1
Post by sltm1 »
Cosminman, I do a 7 gallon pot (filled to 6), W/ thumper for my UJSSM runs. With using 1.25 qt of heads and tails from a previous run and adding another pint of water in my 3 gallon thumper, after culling the 1st pint in 2, 1/2 pint jars, I start collection with approximately 3 pints of 150, 4th is approx 145,and the 5th is 135-140, then I run down to 90 on the last 2 or sometimes 3 pints. The 1st, last and the second half of the foreshot collection are what go into my thumper for the next run. I know I seem to collect too much foreshot liquid, but hey, it works for me. Also, run it slowly, 1/2 a pencil lead stream. It's never exactly the same each time, but close enough to share with certainty.
cosminman
Post by cosminman »
Thanks :). How many hours does it take you to run 6 gal?
sltm1
Post by sltm1 »
Approximately 4 hours from when I turn the element on.
Canuckwoods
Post by Canuckwoods »
Tried my third run and first with a pot still. Ran my first run of UJSSM first generation it started at 120p I collected down to 80p, not a bad flavor. I know I am doing something wrong, am I too hot? I have a 1500w electric burner I am waiting for a controller to arrive. 5 gall pot with 3.5-gallon washes. Thanks
sltm1
Post by sltm1 »
120 is right for a straight pot still. I'm running my thumper with a high ABV so the re steaming is picking up more alcohol which creates a higher proof output.
Canuckwoods
ok, I was concerned as in the original post it said to start at 160 (80) and stop at 120 (60).One other observation it seemed to take a lot longer to get to temp than a sugar wash.
wooddog
Post by wooddog »
hi my first post just joined just wondering if I've messed up I did this recipe but alterd it slightly I put poultry corn in when I Googled it.
it said it was 50 corn maize and 50% wheat will this work?
And when I checked the sg it was 1085 and today 20hrs later it reads 1095 I don't normally check it until about 6/7 dates later but I was just curious is it because of the wheat it has risen or is it just me and some how got my readings wrong but I'm sure they where pretty accurate thanks any info will be greatly appreciated
wooddog wrote:...when I checked the sg it was 1085 and today 20hrs later it reads 1095...
What????
The gravity went UP? That doesn’t happen unless the tmperature went DOWN significantly. Was it hot yesterday when you checked it? Is it close to freezing today?
Or....you’ve been drinking when measuring....
jedneck
Post by jedneck »
Solids in sample will cause a high readin also.
big help
Dunder
wooddog
Post by wooddog »
Haha allways drinking but the temp is exactly the same as yesterday slowly bubbling along been making tpw for about 5 month now and never as it gone up.
but in my ujssm there is a lot of wheat/corn fizzing at the top it might be effecting the reading apart from that I'm pretty confused thanks
sltm1
Post by sltm1 »
Put a fine strainer over the top of a small measuring cup insert them into your wash and remove the liquid that way, very few solids will get in the liquid
wooddog
Post by wooddog »
jedneck wrote:Solids in sample will cause a high readin also.
thanks jedneck I've just checked again making sure to use a trail jar and getting minimum solids in there and the reading is 1070 so I'm guessing you're spot on about the solids
wooddog
Post by wooddog »
Thanks sltm1
sltm1
Post by sltm1 »
No problem....after doing it wrong a dozen or so times, you'd have come up with the idea yourself (been there LOL).
