Page 129 of 160
Posted: Thu Dec 06, 2018 7:33 pm
by acfixer69
Budapest8485 wrote:Curious... How much corn is enough to do 7 gallons of sugar wash at 9%? Trying to make a neutral spirit to run through a reflux still. The yeast is soooo happy about the nutrient in the corn! I've been making wine for 15 years and only once have I seen air passing through an airlock faster than this. There's a party going on it my fermenter!
Some is the easy answer None is the better answer if you looking for a neutral. UJ makes a good vodka in the first 2,3 4, gen's. Better to start with a recipe aimed for a neutral look at the t & T .
Posted: Fri Dec 07, 2018 8:08 am
by Budapest8485
I get it. I just like the way this ferment is going. The BW was a pain to ferment which I think might be part of why I have an off flavor neutral on my hands. Obviously you don't do generations when your intent is a neutral...so starting new each time I wonder how much corn is enough to provide the nutrient. I like corn better than tomatoes!
Posted: Fri Dec 07, 2018 12:41 pm
by Saltbush Bill
Using this recipe but replacing the corn with wheat gives a good neutral from my experience. No generations.
Posted: Sat Dec 08, 2018 10:56 am
by Budapest8485
Saltbush Bill wrote:Using this recipe but replacing the corn with wheat gives a good neutral from my experience. No generations.
This is a good point. Then I'd have something like Grey Goose I think... Tito's is corn I believe.
My pot still head is assembled. I have it full of 50/50 vinegar and water...I'll do a cleaning run tomorrow probably.
Posted: Sat Dec 08, 2018 12:22 pm
by NZChris
To make a wheat vodka, I split off some UJSSM trub and backset and add wheat instead of corn to make a three or four wash ferment, strip that, then put it through a Bokakob.
Posted: Sun Dec 09, 2018 5:43 am
by Budapest8485
NZChris wrote:To make a wheat vodka, I split off some UJSSM trub and backset and add wheat instead of corn to make a three or four wash ferment, strip that, then put it through a Bokakob.
That surprises me. Seems like this would be something other than a neutral with the backsets and trub. When you say 3-4 wash ferment, do you mean you're doing 3-4 generations of it?
Posted: Sun Dec 09, 2018 6:36 am
by still_stirrin
Reading Chris’s reply, I would believe he ferments enough to charge the boiler 3 or 4 times, stripping each charge and then running the low wines through the Boka....’cuz that’s the “way it’s done”.
Wouldn’t you?
Posted: Sun Dec 09, 2018 2:08 pm
by NZChris
Once I'm happy with the number of generations, I upscale the next generation to do at least three strips worth, each subsequent generation making enough low wines for a spirit run. For a wheat vodka, I pinch some of the trub and backset from that to make up a 3-4 wash ferment. I don't have any reasons to ferment and strip three successive generations of vodka wash, or any desire to single run washes in a Boka, so I just get the job over and done with quickly.
Posted: Tue Dec 11, 2018 6:09 pm
by Budapest8485
Gen two is started, Sour Mash is born! Sugar added to those backsets it tastes like sour patch kid.
Gen one smells like a barn...I didn't know I was smelling corn every time I went into a barn. Stripped it starting at 70% and took it down to 15%.
Posted: Wed Dec 12, 2018 5:21 am
by Budapest8485
I've been making wine for 15 years and generation two has more air passing through the airlock than I've ever seen before. It's like an air compressor blowing bubbles...no burps, just a steady fast stream of air. 83 degrees without any heat suppliment. I pulled the blanket off the fermenter to keep it from getting hotter.
I will likely be stripping this stuff over the weekend at this rate...48 hours to dry is my estimate. Those are some happy yeast!
Posted: Thu Dec 13, 2018 9:14 am
by Canadashine
Hello everyone. I'm on my 5th or 6th gen now and no problems so far. Great recipe thxs for all the good information. Just one thing tho on my 1st gen it fermented down to .990 and now everyone since stops at 1.000 so there not stalling. But I did try something on the last one. I made up the sour mash as the norm but with my leftover backseat I did a wash without the corn just 30% backset and sugar. The one with the corn in it stopped at 1.000 but the one with no corn went to .992. Does anyone know why this would happen. Same recipe just no corn. The only thing I can think of is the fresh yeast. Any ideas would be muchly appreciated thanks
Posted: Thu Dec 13, 2018 12:49 pm
by BoisBlancBoy
Canadashine wrote:Hello everyone. I'm on my 5th or 6th gen now and no problems so far. Great recipe thxs for all the good information. Just one thing tho on my 1st gen it fermented down to .990 and now everyone since stops at 1.000 so there not stalling. But I did try something on the last one. I made up the sour mash as the norm but with my leftover backseat I did a wash without the corn just 30% backset and sugar. The one with the corn in it stopped at 1.000 but the one with no corn went to .992. Does anyone know why this would happen. Same recipe just no corn. The only thing I can think of is the fresh yeast. Any ideas would be muchly appreciated thanks
I’d say the higher reading is from the unfermentables, which is no problem. As long as its getting close to 1.000 your good to go!
Posted: Fri Dec 14, 2018 7:24 pm
by 6 Row Joe
I tried something new. I added a small bag of sweet corn to the mix. It sure smells good.
Posted: Sun Dec 16, 2018 5:08 pm
by tjans
Just started gen 1 today. Oxygenated with my Stone and she took off three hours later![img]https://uploads.tapatalk-cdn.com/201812 ... 17008a.jpg[/img]
Posted: Mon Dec 17, 2018 8:21 am
by 6 Row Joe
6 Row Joe wrote:I tried something new. I added a small bag of sweet corn to the mix. It sure smells good.
Just transferred it to secondary. It finished at .990. 11.610 sounds good.
Posted: Wed Dec 19, 2018 4:47 am
by tjans
2.5 day ferment, finished at .996. Wowza.
Posted: Wed Dec 19, 2018 11:42 am
by Canadashine
My first 5 generations were all done in less than 3 days. Now my 6th is on day 5 and still going but that's probably my fault since I went from 30% backset to 60 65% to try and get more flavor
Posted: Wed Dec 19, 2018 1:41 pm
by Budapest8485
It moves fast! I'm sure my gen three is done in 3 days...I can't still it tonight, so I'll just wait to check when I have time to run it.
I doubled the batch for gen three. I'm going to double it again for gen four and hold it at that level. Then I'll have enough to do four striping runs and a spirit run every generation.
Posted: Wed Dec 19, 2018 1:54 pm
by tjans
I can't still mine until Saturday which is a bummer.
Posted: Fri Dec 21, 2018 9:39 am
by Budapest8485
Doing the spirit run today...wow this stuff is smooth! I'm happy. This is gen 1, 2, and 3 stripped going through it now. Much of the corn forwardness is gone.
Feints... I'm collecting them now. I dumped the foreshots. Should I add these feints into the low wines from generation 4? Or are feints used for vodka in my reflux bokabob?
Posted: Fri Dec 21, 2018 10:08 am
by tjans
Budapest8485 wrote:Doing the spirit run today...wow this stuff is smooth! I'm happy. This is gen 1, 2, and 3 stripped going through it now. Much of the corn forwardness is gone.
So you lost a lot of the corn flavor?
Posted: Fri Dec 21, 2018 10:11 am
by Bushman
You can do it either way, I usually run feints in my next generation. But at times I have saved up feints for an all feints run. It has produced some of my best neutrals.
Posted: Fri Dec 21, 2018 10:37 am
by Budapest8485
The corn is still there, just not the only thing I notice now. I'm searching for butterscotch...not sure it's there yet, but I detect something.
Posted: Fri Dec 21, 2018 11:59 am
by tjans
Nice. How much did you yield out of your strips?
I'm gonna strip my first gen this weekend. Looking forward to it. Wonder how many gens I'll need to get to my full boiler capacity.
Posted: Fri Dec 21, 2018 12:30 pm
by Budapest8485
I get about 1.5 gallons of low wines per 6 gallons of UJSSM. The ABV of gens 1-3 in the boiler was about 40 percent...maybe a little higher. So I had four 6 gallon stripping runs to fill up my boiler.
Dropping in ABV now. Down to about 140 proof. I'm not sure where I should expect to get into the tails, but I don't smell anything yet.
To finish I'm going to crank it up and strip the rest off for recycling.
Posted: Fri Dec 21, 2018 12:52 pm
by tjans
I think they recommend 80 down to 70 for Spirit run.
Posted: Sat Dec 22, 2018 6:16 am
by Budapest8485
tjans wrote:I think they recommend 80 down to 70 for Spirit run.
I just cranked up the heat when it was down to 110 proof and stripped the rest out. There wasn't much left...maybe half a gallon.
I took the deep hearts to a party last night... Told them I know a guy who makes moonshine :lol: A wide range of feedback...hardcore, smooth, different... I drank it mixed with soda all night and I feel like a champ this morning. I get hangovers easy and I'd probably have one on anything else after 5-6 drinks last night.
Posted: Sat Dec 22, 2018 6:37 am
by tjans
That's awesome. Looking forward to distilling mine tomorrow.
Posted: Sat Dec 22, 2018 8:47 am
by Budapest8485
My places smells like day old beer... Not sure if it's from the distilling or the UJSSM gen four.
Posted: Sat Dec 22, 2018 9:21 am
by kiwi Bruce
Budapest8485 wrote:My places smells like day old beer...
That's AWESOME! :clap:
Mine just smells like wet puppy dogs and feet...and sometime cooking :oops:
