Page 14 of 22
Re: Jimbo's Electric Conversion
Posted: Sun Oct 18, 2015 10:43 am
by raketemensch
4xRotor wrote:The adjustable potentiometer. Is it wired pins one and three or two and three?
From left to right, I use 1 and 3, leaving 2 and 4 empty.
Posted: Sun Oct 18, 2015 10:45 am
by raketemensch
Jimbo wrote:Nope, if youre using one of these controllers like I did you need 220 in and out. Check wiring diagram here... http://homedistiller.org/forum/viewtopi ... 0#p7131036
Ah, so you have one leg going in 1 and out 3, and the other going in 2 and out 4?
Posted: Sun Oct 18, 2015 10:47 am
by 4xRotor
I would check with an ohmmeter to see if the resistance of your potentiometer is changing when you move the dial
Posted: Sun Oct 18, 2015 11:05 am
by raketemensch
Well, that definitely didn't work, I just let the smoke out of my SCR.
<sigh> Not been a fun weekend.
I assumed you meant this one
The breaker didn't throw, but I got a nice loud pop and a stink from my control box.
Posted: Sun Oct 18, 2015 11:10 am
by Jimbo
I don't know whos drawing that is but its wired just like my drawing. You must have a crossed wire somewhere double check all your wiring good thing those things are cheap I hope you bought a spare
Posted: Sun Oct 18, 2015 11:12 am
by raketemensch
Jimbo wrote:I don't know whos drawing that is but its wired just like my drawing. You must have a crossed wire somewhere double check all your wiring good thing those things are cheap I hope you bought a spare
Well, all I have is red, black and ground, so I kinda can't cross them, right?
Posted: Sun Oct 18, 2015 11:16 am
by Monkeyman88
If you have an scr with four terminals. You need to have both hot wires going in, and both hot wires going out.
Posted: Sun Oct 18, 2015 11:19 am
by FreeMountainHermit
Forgive me for being on the thick as a brick side but I don't see a potentiometer in the diagram above so wouldn't that be full power all the time?
Getting ready to take the plunge thus my comment/question.
by Monkeyman88
Potentiometers only have three legs. I think you may be getting terms confused. Are you able to post a picture of what you have? That would help a lot.
Posted: Sun Oct 18, 2015 11:21 am
by Monkeyman88
FreeMountainHermit wrote:Forgive me for being on the thick as a brick side but I don't see a potentiometer in the diagram above so wouldn't that be full power all the time?
An scr is a complete unit that has a potentiometer built into it. An ssr is a seperate thing and needs to have a pot wired to it.
Posted: Sun Oct 18, 2015 11:24 am
Bowing at the waist here, Sir.
Grasshopper sez thank you !!!!
by raketemensch
This is what I'm using.
If I attach both power leads in, and both out, I get a pop as soon as I plug it in. I tried switching the leads into it, and got the same pop. Didn't think it was even possible to get a pop twice, you learn something new every day.
Posted: Sun Oct 18, 2015 11:26 am
by 4xRotor
Sorry I thought you were using a separate potential to run the thing
Posted: Sun Oct 18, 2015 11:29 am
Now I'm really mixed up.
No knob for power input adjustment
http://www.ebay.com/bhp/silicon-controlled-rectifier" onclick="window.open(this.href);return false;" rel="nofollow
Posted: Sun Oct 18, 2015 11:30 am
by Monkeyman88
The best way to tell where the wires go it to take a multimeter, turn the pot to full on, and the measure the continuity between the terminals.
Posted: Sun Oct 18, 2015 11:34 am
by Monkeyman88
FreeMountainHermit wrote:Now I'm really mixed up.
Hmm. I have no idea what that is. Lol. But it's not the one you want.
Posted: Sun Oct 18, 2015 11:41 am
Please disregard my post mm88.
I went to the beginning of Jimbo's thread as I should have from the start.
A thousand pardons, Sir and to the rest of you good folks.
Blowing retreat with my bugle !!!! :lol: :lol: :lol:
Peace, FMH.
Posted: Sun Oct 18, 2015 11:47 am
by Monkeyman88
Haha. No probs. All the different names and abbreviations can get confusing when just starting out. Haha
Posted: Sun Oct 18, 2015 11:48 am
by Monkeyman88
4xRotor wrote:Sorry I thought you were using a separate potential to run the thing
A separate pot is for if your using a SSR.
Posted: Sun Oct 18, 2015 11:52 am
by raketemensch
I'm aborting the run for today, fortunately I have a few gallons of backset stashed in a freezer so I can start the 25-gallon UJSSM (moving up from a 5 gallon).
I'm still not sure what I've done wrong, everything appears to be correct. But POW.
Thanks for the assistance, everyone, I'll regroup tonight when the frustration level is back down. I appreciate the help.
Posted: Sun Oct 18, 2015 12:04 pm
by Monkeyman88
I know this may be a silly question. But how do you have the wires? 1 and 2 are the input and 3 and 4 are out.
Posted: Sun Oct 18, 2015 12:06 pm
by raketemensch
Monkeyman88 wrote:I know this may be a silly question. But how do you have the wires? 1 and 2 are the input and 3 and 4 are out.
Yup, 1 and 2 are input, 3 and 4 are out to the element.
I just noticed that the wiring diagram has a neutral going to the keg, which seems odd to me.
I'm using a 3-prong dryer cord, with the two hot legs being standard and I'm using what would normally be the 3rd neutral wire as the ground. It's hooked up to the ground bar in the sub-panel, but then again so are lots of neutral wires. Maybe that's my issue?
Posted: Sun Oct 18, 2015 12:09 pm
by Monkeyman88
Ah yes. The keg must be grounded. That's a safety issue.
Posted: Sun Oct 18, 2015 12:10 pm
by Monkeyman88
I'm going to guess that the 'pop' that you heard twice. Is probably some kind of safety measure to make sure that you can't turn it on if it's not wired correctly.
Posted: Sun Oct 18, 2015 12:11 pm
by HDNB
input wires black / red in on the right, output wires black red out on the left? thats the way that drawing shows, but it maynot be how the controller you have is wired...for example it may be black in/out on the right, red in/out on the left...
you measured 120vac black to ground, and 120vac red to ground...and 240vac red to black on the supply side?
you measured the element for good? i think 5500w are around 20 ohms? (with nothing but the meter connected)
the pop/smoke makes me think you have one hot (black) on the input side and the other (red) on the output side of the same phase...when power is supplied the weak part starts sizzling.
damn, if a guy could only read chinese....is there no other diagrams or lables on that thing anywhere? no supporting docs to tell which pin does what?
by raketemensch
Monkeyman88 wrote:Ah yes. The keg must be grounded. That's a safety issue.
Well, I believe it is. There's no neutral, so what would normally be the neutral wire is a ground wire.
I have it going to the ground bar in the sub-panel, and wired to the keg.
But the ground bar also has neutral wires on it, I'm not sure how that works.
Posted: Sun Oct 18, 2015 12:13 pm
by Monkeyman88
Have you got the ground going to the scr as well? That also needs to be grounded.
Posted: Sun Oct 18, 2015 12:16 pm
by HDNB
and you should be using box ground on the keg, not neutral.
Posted: Sun Oct 18, 2015 12:22 pm
by raketemensch
HDNB wrote:input wires black / red in on the right, output wires black red out on the left? thats the way that drawing shows, but it maynot be how the controller you have is wired...for example it may be black in/out on the right, red in/out on the left...
It appears to want red/black in on the left, red/black out on the right:
All of that checks out, at the SCR and again at the keg.
I need to find my multimeter, my wife did some cleaning....
Maybe I just shouldn't trust the label on this thing, or maybe they mean that it alternates, and I'm just reading it wrong, and they mean that they alternate.
Posted: Sun Oct 18, 2015 12:27 pm
by Monkeyman88
Once you find your multi meter. Make sure it's not supposed to be red/black in then black/red out.
You could even try taking out both blacks and twisting them together. Then just have red in on one and out on three. If nothing then try out on four.
