I have made some informal ad hoc private arrangements with a few people. Nothing professional. Say, how expensive is it to ship from Oregon to the UK?Mikey-moo wrote:Are these for sale now then? Where can we buy them from please...
- Badmotivator
Trying to make it real compared to what?
Badmotivator Barrel Construction, Start to Finish
Many pesos :-(
I'll start saving up
I just spent a little over $20 to send a small box (about 8x8x8") to the U.K. That was the cheep option.Badmotivator wrote:I have made some informal ad hoc private arrangements with a few people. Nothing professional. Say, how expensive is it to ship from Oregon to the UK?Mikey-moo wrote:Are these for sale now then? Where can we buy them from please...
Toasted French oak medium. Also a head made from a white wine barrel would be cool.Badmotivator wrote:What do you have in mind?rubber duck wrote:Could you do some custom oak? Like it would be a pain in the ass but but I would pay you for it.
- Badmotivator
I would be happy to make those, but I can’t think of a way to get French oak merrains. Any ideas?rubber duck wrote:Toasted French oak medium. Also a head made from a white wine barrel would be cool.Badmotivator wrote:What do you have in mind?rubber duck wrote:Could you do some custom oak? Like it would be a pain in the ass but but I would pay you for it.
Making a head out of a used white wine barrel is more do-able. I don’t have any ex-white staves but I could get some. The ex-wine heads I made were from a red wine barrel, but the technique would be the same.
- Oldvine Zin
Hey BadMo,
We stopped barrel aging whites a long time ago so I can't help you with those staves, but I could set you up with an almost endless supply of red ones.
OVZ
OVZ
I know where to get them. Next time in wine country I'll get some and pm you.
- Badmotivator
In post #380 of this thread I mentioned a barrel whose metal can split. Yesterday I cut the curled lip of the can with an angle grinder, cut the can with big snips, released the head, sanded it down a bit, re-waxed the croze, and pressed it into a new can.
#45 lives again!Trying to make it real compared to what?
In the end I managed to complete the elements to prepare the barrel according to Badmo. Oak boards 1 ", unfortunately I have not been able to buy similar containers like Badmo, so I prepared a section of 220 mm pipe.
Badmo, how did you water the barrels? Is it just inside or can I insert a filled water bucket into a bucket and pour the whole water?
In the meantime, I burned the covers
Pretender. Please do not upload pics via tap talk. Those of us not using it can not see pictures and down the road those pics won't be available. Please follow the procedure to upload directly to the site. There's a sticky on how to do this if you are unsure.
I'm sorry, I only use the phone ... I'm improving [WINKING FACE]
- Badmotivator
Hey, that looks fun!pretender wrote:In the end I managed to complete the elements to prepare the barrel according to Badmo. Oak boards 1 ", unfortunately I have not been able to buy similar containers like Badmo, so I prepared a section of 220 mm pipe.
I swell and test my barrels by filling them with water, and often leave them upright with water on top of the wood. In the end, though, to prove that it is tight, you need to see how it does with water only on the inside. Then you will either see places where it is leaking or you won't. Give it a couple of days though, as sometimes those weepy spots fix themselves.
I note that you used flat-sawn boards. This will increase your loss rate somewhat (I don't know how much) because of the orientation of the oak's medullary rays, which on your barrel are pointing from the inside of your barrel to the outside. I recommend using only quarter sawn oak in the future.
Also, were you able to weather the oak outside for a good long time before making your barrel heads? If not, you may find that the wood gives an aggressive, tannic, green flavor to your spirit.
I wish you luck!
I do not understand that, I do not know what's going on, can you explain?Badmotivator wrote:... I note that you used flat-sawn boards. This will increase your loss rate somewhat (I don't know how much) because of the orientation of the oak's medullary rays, which on your barrel are pointing from the inside of your barrel to the outside. I recommend using only quarter sawn oak in the future ...
I also hope that the oak was adequately aged.
As soon as the barrel stops leaking, it will take its toll on the apple distillate.
- Skipper1953
Check this link for an explanation of quarter sawn vs flat or plain sawn lumber. You can also get a look at a picture of medullary rays.
https://www.google.com/search?q=&tbm=is ... 8612821444" onclick="window.open(this.href);return false;" rel="nofollow
- Badmotivator
Medullary rays are tubes which carry nutrients horizontally across a tree. Oak wood can be as much as 30% medullary ray. That's a lot of tubes! Flat sawn boards have the medullary rays pointing from one face to the other. If you make a barrel head with this the medullary rays can carry spirit right out of the barrel. Your loss rate may be quite high. Quarter sawn boards have the medullary rays pointing across the face of the board, and so they are in the plane of the barrel head. I hope these diagrams help.pretender wrote: I do not understand that, I do not know what's going on, can you explain?
hmmmm .... how many variables affect it all ...
Thx Skip, now I understand.
I am curious whether they are getting me such boards.
Badmo
Yes, now everything is clear. I hope the ones that I have will prove to be good.
Thank you gentlemen for the explanation, as usual helpful
PS
Leaks are getting smaller
Badmo
PS
My New Yard Feature.
BadMo, you said I needed to age my oak outside for a year or two, and I’m marking my 2019 calendar now to make my first BadMo Bran-Marie oak barrel. I’m using the legs of an abandoned couch and chair project. 30 lineal feet of 2 3/4” x 2 3/4” heavy flake quarter sawn American white oak. I bundled it up with stickers in between for spacing and stuck them in my backyard.
I covered the bundle with some boards, allowing air between. Look about right, or do I need to ditch the cover?
Just a suggestion. You're going to want to mill the lumber closer to the size you're going to use. Those look to be 4x4? You're not going to get the same weathering effect while they are still that thick. 1.25 inch or 1.5 inch would be better suited for your needs.
Yak
Yak
- Badmotivator
Good on you, Otis!
Yeah, the cover is contraindicated. The rain is an important cofactor in seasoning the wood.
And listen to the wise yak. You should definitely cut merrains out of that lumber. It will allow the wood to get the right amount of exposure to air and water, allow the tannins to exit the wood or be converted into better stuff. The merrains should be about 9 inches long, 3 ⅛ inches wide, and 1 ¼ inches thick. Those dimensions leave you room for shrinkage and then planing and jointing before barrel construction, resulting in staves that will sized so that three of them can make an 8" round, 1 ⅛ " thick, with a little waste.
Ok, the cover will go. I just reread the thread start to finish again and realized my covering mistake. I’ll also turn my bundle 90deg every 2 months to get things evenly wet.Badmotivator wrote:Good on you, Otis!
I was thinking that 1 1/8” thick was not quite enough thickness, based on the evaporation stats in past posts. Like you, my production way outpaces my consumption, so long aging is fine with me. I was thinking of something a bit thicker, maybe 1 1/2” thick on a 5 or 6 qt pan. Do you think that is overkill? Given that I will be cutting these down, i could go even thicker. I could get double the yield by splitting, but I just don’t want to regret not doing these right.
- Badmotivator
Thicker staves probably have a lower loss rate, but they also have a lower oxygenation rate so your spirit will mature slower than even a large oak barrel. Big barrel staves are about an inch thick, with 1 ⅛ at the extreme. My hunch is that my loss rate has improved a lot since I last talked about it, though I haven't measured it. Here's why:OtisT wrote: Ok, the cover will go. I just reread the thread start to finish again and realized my covering mistake. I’ll also turn my bundle 90deg every 2 months to get things evenly wet.
- My jointing is better. I have moved to using a flush-cut bit on my router table to make beautiful glassy-smooth flat joints. Compared to "jointing" on my table saw, it's no contest.
- I paint beeswax between every stave, providing extra insurance against leaks between the staves.
- I cut my round on a circle-cutting jig on my little bandsaw. This makes a better circle than the jig I was using on my router table, and with a better taper too.
- I wax up the spigot stem and use the nut to pull it tight up to the face of the barrel head.
- I paint beeswax around the edge of the head before pressing it in, providing extra leak insurance at the wood-stainless interface.
BadMO. Have you considered using a t and g router setup? This would allow the oak to swell into each other possibly creating a better seal. If you've already tried it and it failed let me know so I know to avoid it.
- Badmotivator
Nope. It’s worth a try, I suppose. I’d be interested in what you find.yakattack wrote:BadMO. Have you considered using a t and g router setup? This would allow the oak to swell into each other possibly creating a better seal. If you've already tried it and it failed let me know so I know to avoid it.
Ok, so an inch+ should be good enough if I get a good seal, and because it’s quarter sawn, my evaporation should be reduced. I guess I need to break out my thin kerf blade and split these things now before they get out of square. Damn, that is a shit load of BadMo barrel heads there. . Thanks for setting me straight before I let this stuff sit out all year.
I like the idea of a shaped edge between boards. I was planning to go this route ( pun not intended). I think I have a router bit that will do the trick.
I like your bevel bit set for making the bung and hole. I may have to look for one of those if I can’t make what I have work.
Thanks again. I’ll be back to this next year when my wood is ready. Not sure if I’ll want to wait more than about 9 months, but before then I’ll do more reading on aging/weathering wood to see for sure how long I should be doing this. If water and frequent weather changes are what drive wood weathering, I’m in the right region (Pacific North Wet) to speed this up.
[update. I left three thick for a big barrel project, and split 6. Let the rains begin. ]
Badmo in spite of poorly cut planks, after 24 hours of flooding the distillate everything is fine. No leaks, nothing left. Although yesterday was a moment of terror when flooding. When I poured the distillate I noticed on the joint the wood was leaking steel, the lid became wet. But this morning, everything went back to normal. Density difference water alcohol?
- Badmotivator
That's great news! I don't have a good explanation for the strange behavior. There's still some mystery involved in this for me...pretender wrote:Badmo in spite of poorly cut planks, after 24 hours of flooding the distillate everything is fine. No leaks, nothing left. Although yesterday was a moment of terror when flooding. When I poured the distillate I noticed on the joint the wood was leaking steel, the lid became wet. But this morning, everything went back to normal. Density difference water alcohol?
Congratulations! Would you post a picture?
Of course. I still have to work on aesthetics. But I have already ordered a pipe for the next barrel. I also see some things that I would have done differently, for example, I would put the boards upright, the edges of the boards with sandpaper - necessarily. And burn the decks, maybe a roast? But how? As you think, just put a metal plate on the gas stove and burn the wood on it?
- Badmotivator
Nice! I love it! I especially like the little legs.pretender wrote:Of course. I still have to work on aesthetics. But I have already ordered a pipe for the next barrel. I also see some things that I would have done differently, for example, I would put the boards upright, the edges of the boards with sandpaper - necessarily. And burn the decks, maybe a roast? But how? As you think, just put a metal plate on the gas stove and burn the wood on it?
I would love to answer your question about “burning the decks” but I don’t quite understand what you mean. If you will clarify the question I’ll see what I can do.
