If you like a really smooth whisky you need to try this recipe I have run it several times. It is easy and so far I have never had a ferment stall. If you try it let me know what you think. I have some that has aged on oak for about 2 months and it is really smoothing out. I oak at 55% ABV.
this is for 6 gallon wash
4" of sweet feed in the bottom of the bucket
7 pounds of white sugar
5 packets of bakers yeast or 8 tablespoons
heat 2 gallon of water to good hard boil then pour the water in the sweet feed add your sugar and stir for about 15min. the let stand for 90min. fill to 6 gallons with cool water after waiting 90min., your temp should be around 90F sprinkle your yeast in and stir gently. cover with lid and add your airlock. Mine is normally bubling away in about 4-6 hours. will run pretty good for about 2 days then will slow to a very slow rate. leave it for 5 days or untill you see it trying to clear sometimes it is 6 days. after that set it a cool place for about 24hours then rack it off and distill it. I normally get about 4 qaurts of low wines. sometimes my quart in the middle taste good enough I keep it aside and drink it just as it is.
after I run this through a pot still I use about half of my backset while it is still hot I put 7 pounds of sugar in the hot backset and convert my sugar. Let that cool to about 90F pour this back into your fermentor on your grain and yeast that was left in your bucket. add enough water to make 6 gallons normally my yeast wake up and are bubling away in about 4-5hours.
It seems very easy to me. I have really had good success with it. you can normally get your sweet feed at any farm supply store 50lbs for 7 bucks. It will last a long time
Mod edit to help with different size vessels:
Thanks Prairiepiss for the extra time on the calculations
So NIN posted that 4" in a 5 gal bucket is 7.69 lbs. It doesn't need to be exact. So let's break it down here.
You could go 1.5 to 1.75 lbs of sweetfeed and 1.5 to 1.75 lbs of sugar to a gallon of water. With no problems.
Or for the metric guys. .180 to .210 kg of sweetfeed and .180 to .210 kg sugar to 1 lt of water.
Or easier terms. Equal parts sweetfeed and sugar to end up with the SG you want.
sweetfeed whisky
Kentucky shinner
