Dan's Flute x2, 4" x 5 plate 42" column
dan
Re: Dan's Flute x2, 4" x 5 plate 42" column
Post by dan »
:yawn:
Dima
Post by Dima »
Finally got to the last page! took me days to go through, very informative. Thank you Dan!
Will be building 3" 5 plate, since copper is very expensive in my area and 4" in nearly non existent and 3"x36" pipe my neighbour hooked me up for free :)
I must have been too tired and missed where did you get those brass ferrules for second gen, i ran into some the other day at still dra_gon is that where yours came from ?
edit: added screenshot
dan
Post by dan »
Dima,
That is exactly where they came from! Good luck with your build..
Dan
dan
Post by dan »
Does anyone still read this thread?? What do you have to do to get better than a "Swill Maker"?
-Dan
Expat
Post by Expat »
dan wrote:Does anyone still read this thread?? What do you have to do to get better than a "Swill Maker"?
-Dan
The titles are associated with how many posts you've made to the board. So short answer is you'll need to post more.
Alternatively, there are titles for site doners, admins and other titles as bestowed at the pleasure of the gods.
_____________________
EXPAT
Current boiler and pot head
Cross flow condenser
Modular 3" Boka - pics tbd
___________________
Im sure people look at old threads all of the time, this ones been viewed 66,719 times.
WillieP
Post by WillieP »
-Dan
Well, I do Dan.
I am in the research and design phase of a 3 inch flute build. (I know..., but the 3 inch was free). I have read and bookmarked every flute build thread that I can find. I just came back to re-read yours, and I must say that it is one of my favorites. Lots of copper porn, and very detailed.
I hope to pick and choose the things I like out of all the threads I have read and try to combine them into something that will be the sum of all the great inovaton that have been shared here on HD. So many cool, different ways of doing things. Advantages of this or that, depending on what you are looking to be able to do with your final build design. When I am ready, getting close, I will start a thread in the construction page and run my ideas by the crew.
Thanks for this one Dan,
WillieP
30xs
Post by 30xs »
I’ve read the whole thing. Amazing work, sir.
dan
Post by dan »
30xs - Thank you Sir!
Dan
PDBRadley
Post by PDBRadley »
Dan-
Saw your build on youtube a while back. It wasn't until a couple of days ago that I found the link to here. Very impressive work. I hope you don't mind a few questions.
What are the tolerances for the plates along the column walls? Does the gap get closed off by the liquid or capillary action or does vapor pass through to some degree without diminishing the performance? Just concerned if I try it that the pipe or the plate may end up out of round, leaving a gap.
In your opinion, would a reducing coupling instead of the double plates at the top of the column provide enough support for the product condenser and parrot? I ask because fittings may be cheaper for me than plates.
What grade of copper did you use for the 0.125 plates? (110 -O, 110 1/8-1/4, ...) At that thickness does it matter?
In your earlier build it looked like you used smaller diameter pipe in the dephleg and downcomers. What was the reason for upsizing them?
Thanks again for posting the entire process(es) and answering questions along the way. I'm sure it will save myself and others a lot of time and $ in trial and error.
Much Respect
-PDBR
30xs
Post by 30xs »
Dan isn’t on very often, but I will try to give some info that is only taken from what I’ve read from many flute build threads and from the “Flute talk” thread. I do advise to also search other threads on flutes looking at the newer builds and see what designs were used and make your decisions on your blueprint from them.
PDBRadley wrote:Dan-
Yes, it has been done on many builds, search this site is see. A reducing coupler is $40+. I ordered 6 plates 1/8” for about $53 shipped off eBay.
There has been quite a bit of discussion about the height of the water column inside the dephleg and the volume of the vapor tubes. With his larger tubes it reduces a restriction, which causes an increase in vapor velocity, and it also means there is less water inside the dephleg which would give a faster reaction time to any changes in coolant flow.
Much Respect
-PDBR
You may also try searching Emptyglass flute and DetroitDIY flute. Those are the two off the top of my head, besides this one, that are well documented with photos. Read the Flute Talk thread, long but informative, and the HD google search button in the middle of the header is a wonderful thing. It will keep you in this site while you search. Don’t delete what comes up in the browser, just space and add what you are searching for. Good luck.
PDBRadley
Post by PDBRadley »
30xs-
Thanks for your reply. I will follow through per your suggestions.
Regards.
PDBR
Rastus
Post by Rastus »
Its been a long time, but i do reflect back on this thread from time to time. it was the main influence on my own build. this thread and actual communication with Old Dog where he answered some of my questions on the deflegamator and the use of a 3 way valve to operate the condensers.
but Dan, its an awesome thread .... stand proud
She was just a moonshiner,
But he loved her Still
dan
Post by dan »
:shifty:
Corsaire
Post by Corsaire »
Thanks for bumping this thread Dan, I enjoyed the read. And the pretty pictures!
new_moonshiner
Post by new_moonshiner »
Very inspirational builds Dan !! Excellent workmanship, I have read this thread page for page at least twice . thank you for sharing your work and all the great pictures . looks like I have found a project to start .
NM.
new_moonshiner wrote: ↑Sun Feb 21, 2021 4:03 pm Very inspirational builds Dan !! Excellent workmanship, I have read this thread page for page at least twice . thank you for sharing your work and all the great pictures . looks like I have found a project to start .
NM.
This is why we advice others building to document with both instructions and pictures as it is very helpful to other members.
dan
Post by dan »
I just read back through my column build and can not believe it is coming up on 10 years ago that I started this thread! I have been missing in action for at least the last few years and need to get back to this hobby soon. My last distillation was over three years ago! And is still aging on oak.... new_moonshiner - I will try to attach the last drawing I had for the plate perforations so here you go...
- Dan
Perf Plate.pdf
Dan it’s great to have you back this thread is actually linked under stills listing some of the better build threads:
https://homedistiller.org/forum/viewtop ... 17&t=47262
new_moonshiner
Thank you Sir !! Hats off to you friend . Your perfection speaks volumes , True asset to this hobby and inspiration to many, new and old myself included . thanks Bushman for the link .
NM.
dan
Post by dan »
"Still" around if anyone has any questions... Hahahaha
- Dan
Wow where you been the last two years?
StillerBoy
Post by StillerBoy »
Welcome back Dan..
You were instrumental in influencing with some design of yours.. below is my parrot which I copied..
by dan » Wed Sep 02, 2015 10:49 pm
Well Gentleman..... There is a common theme in all of my proofing parrots but I think this is one of my favorites.
Dan
viewtopic.php?t=21774&start=360
Mars
– Albert Einstein
dan
Post by dan »
- StillerBoy,
That looks awesome, well done!
- Dan
Oldhenry1
Post by Oldhenry1 »
This is an amazing thread, so much great information.
dan
Post by dan »
Nice to see people are still looking at this build... Just bumping, LOL :wave:
-Dan
