![Very Happy :D](./images/smilies/icon_biggrin.gif)
Fixed by the good mod fairies
Love that still!
You cant go wrong with Ted's FFV
+1CoogeeBoy wrote: ↑Sun Nov 15, 2020 2:59 pmYou cant go wrong with Ted's FFV
I have read a number of times that you can't use the airlock as an indicator of activity and that is true but this morning, I went to check on my TFFV and there was no activity on it whatsoever. Tested the SG and it was under .90 (was just over 1.00 on Saturday so two days later). Full marks to you Ted, and thanks for the recipe, it works like a dream.
Very cool, looks awesome.Rrmuf wrote: ↑Fri Nov 06, 2020 4:33 am My first batch of Odin's Gin was distilled yesterday from ~14l of Wineo Wash low wines. After cuts, it yielded about 8l @42%, and I held back ~1l @80% of the more neutral jars in 'reserve' in case of clouding and I think I am glad I did: When I was diluting with dist. water it was crystal clear @45% and when I diluted a bit further to 42% it seem to cloud over a bit! I understand from the discussion in the Odin Gin thread that it is likely due to botanicals (I hope!) falling out of suspension with the dilution.
I think I will wait it out a bit, then if it remains a bit hazy then I will use the neutrals to see if I can bring it back up to 44-45%
BUT this represents my first attempt made 100% from HD tried and true recipes, and the first attempt sourced entirely from the grocery store! No turbo yeasts at all.Thank you all for being such a great resource in my journey!
In other news, I finished a Teddysad FFV fermentation and that looks great too!
I might misunderstand your meaning by 'taking a small first cut' but I did make a foreshot cut and a bit of a tails cut on the contributing stripping runs, and I did make foreshots cut, small heads cut, and a more significant tails cuts on this spirit run. There was one jar at the 'edge' of tails that might have contributed to the cloudiness. NB. @45% it largely goes away but I can tell I am on the edge here: When I chill the gin, a bit of a haze returns.B_Stilling wrote: ↑Mon Nov 16, 2020 11:13 amVery cool, looks awesome.Rrmuf wrote: ↑Fri Nov 06, 2020 4:33 am My first batch of Odin's Gin was distilled yesterday from ~14l of Wineo Wash low wines. After cuts, it yielded about 8l @42%, and I held back ~1l @80% of the more neutral jars in 'reserve' in case of clouding and I think I am glad I did: When I was diluting with dist. water it was crystal clear @45% and when I diluted a bit further to 42% it seem to cloud over a bit! I understand from the discussion in the Odin Gin thread that it is likely due to botanicals (I hope!) falling out of suspension with the dilution.
Did you not take a small first cut from the last run? I believe it holds a lot of oils from the citrus peel, which makes the product cloudy.
Yeah I was wondering wether or not you discarded the first bit, as I believe thats where the cloudiness comes from, not the tails.Rrmuf wrote: ↑Tue Nov 17, 2020 3:39 am I might misunderstand your meaning by 'taking a small first cut' but I did make a foreshot cut and a bit of a tails cut on the contributing stripping runs, and I did make foreshots cut, small heads cut, and a more significant tails cuts on this spirit run. There was one jar at the 'edge' of tails that might have contributed to the cloudiness. NB. @45% it largely goes away but I can tell I am on the edge here: When I chill the gin, a bit of a haze returns.I am going to experiment to reduce/remove the haze using mmethods already covered here. However, it tastes pretty darn good!
Good luck!!!B_Stilling wrote: ↑Tue Nov 17, 2020 4:23 am
Good you got the taste down, mine is going in the pot tonight![]()
Thanks! Just pulled about 500mls of OEG at about 74% ready to be dilluted to drinking strength. Now comes the hard part; not touching it for a few weeks...Rrmuf wrote: ↑Tue Nov 17, 2020 4:54 amGood luck!!!B_Stilling wrote: ↑Tue Nov 17, 2020 4:23 am
