Page 18 of 19
Re: Oaking and aging the T-Pee way
Posted: Sun May 13, 2018 4:16 pm
by bitter
This should last a little bit
Posted: Sat Jun 02, 2018 7:46 am
by Chickenbone
We have an almost unlimited supply of 1/4" white oak planks and are planning to toast and char our sticks the T-Pee way. Given that most here use sticks with a thickness = to or > 1/2", I'm wondering if the sticks we will make are going to be too thin, especially for charring purposes.
I also toasted a few 1 x 5 x 1/4" sticks in the oven at 400 degrees but may have left them on too long. The house smelled ethereal at about the two hour mark but after four hours the smell greatly dissipated. Should be able to still use them after four hours toasting at 400, yes? Did I take them past their peak?
Posted: Sat Jun 02, 2018 8:37 am
by OtisT
My personal opinion is that 1/4” is too thin. When toasting sticks I try for a gradient of toast, with the inside of the stick receiving less toast. Hard to get a gradient with no depth/thickness. This is just my preference.
IMHO, think you toasted way too long for that thickness of wood. My guess would be somewhere less than an hour for 1/4” thick pieces to toast all the way through. As you toast, pull a stick once in a while and crosscut to look for toast penetration. My understanding is that temp determines the level of toast, while time determine the level of penetration. Once the center has reached toast temp, there is no benefit to toasting longer.
Otis
Posted: Sat Jun 02, 2018 8:56 am
by der wo
Chickenbone wrote: The house smelled ethereal at about the two hour mark but after four hours the smell greatly dissipated. Should be able to still use them after four hours toasting at 400, yes? Did I take them past their peak?
Make new sticks. There is not much left in those sticks but a few burnt flavors.
Posted: Sat Jun 02, 2018 10:26 am
by Chickenbone
Thank you Otis and der wo for confirming my suspicions. The sticks I over toasted will make their way onto the grill. Since 1/4 inch is all we have right now, I think I will try toasting a new set for a much shorter period of time. More like an hour as Otis suggested. I’m thinking of toasting four sticks total per gallon with each stick toasted at a temp corresponding to a flavor peak on the chart. It’s all a shakedown cruise for us right no, so we’ll see how it goes.
Posted: Sun Jun 03, 2018 6:06 am
by Shine0n
I toast mine (1"×1"×5") for two hours and it works well, I have some locally sourced white oak I cut myself but I also have a half barrel from the feed store I cut into the size I wanted.
I believe 1 hour is the max you'd want for 1/4", maybe even 45 minutes.
Try some for half hour, then 45 minutes and then one hour, then you'll know what level of toast you have and could use them in different applications for different spirits.
Good luck
Posted: Sun Jun 03, 2018 10:02 pm
by Distillernz
Just wondering how the flavour changes with time? I am ageing a neutral spirit at 130 proof using one toasted and charred oak piece about 1" by 1" by 3" per quart. Now after a week I have sampled and the flavour is not quite was I was hoping for. I have only used the JD chips before and they were pretty good. I realise the original post said a month and a half on the oak and then a month and a half with oak removed will flavour change a lot in this time?
Posted: Mon Jun 04, 2018 2:59 am
by greggn
Distillernz wrote:I am ageing a neutral spirit at 130 proof using one toasted and charred oak piece about 1" by 1" by 3" per quart. Now after a week I have sampled and the flavour is not quite was I was hoping for.
Oaking a neutral isn't going to give you much in the way of depth or complexity of flavor.
Posted: Mon Jun 04, 2018 8:55 am
by OtisT
Distillernz wrote:Just wondering how the flavour changes with time? I am ageing a neutral spirit at 130 proof using one toasted and charred oak piece about 1" by 1" by 3" per quart. Now after a week I have sampled and the flavour is not quite was I was hoping for. I have only used the JD chips before and they were pretty good. I realise the original post said a month and a half on the oak and then a month and a half with oak removed will flavour change a lot in this time?
That’s a proper sized stick for the volume.
. In my experience, the spirit will smell/taste bad/worse soon after adding oak and it won’t start improving for many months. (6-12 months and more in some cases). This may vary by wood type and wood seasoning, with more seasoned wood making the turn for the better sooner that unseasoned oak. I find the smell of the young oak offensive at first, but it will eventually subside and will be taken over by vanilla and other wood related eaters. While the smell of a youn oak is not good to me, the taste is even worse.
Something like the JD chips, or other previously used wood, won’t have as much of a harsh/young oak to it and would likely taste better sooner ( or maybe that should be said, it won’t taste as bad up front.)
When sampling what’s in your jars, be sure to let the jars air out first each time you sample. Even a jar of good stuff can smell a bit off right after opening. I find that opening jars and let them air for 30 minutes before sampling makes a huge difference by allowing some of the most offensive and off smells to dissipate.
I also find that jars smell better before they taste better. An early change I get is some of the sweet smells, like vanilla after a few months. The taste of young oak lingers longer, taking more time to work out.
This is just my opinion, but Oak in a neutral would not be exciting to me. Something akin to oak tea. I think the oak needs something in addition to ethanol in order to develop into something nice. With enough time you’ll probably end up with something that smells nice, but the taste may be a bit flat. ( speaking from personal experience.
Otis
Posted: Fri Jan 18, 2019 1:23 pm
by thumper123
I have found your aging process to be very similar to my own, and I can tell you that it's the very best way for us novices to produce a great product.
My kids love my bourbon, and they're always trying to compare it to the commercial products out there. They present me with an incredible array of microdistillery products on holidays in an attempt to best my stuff - all in fun. I've noticed that some are pretty good, but others are nearly impalatable. The really bad ones seem to be aged on bad wood or something. They taste green. I don't know what the hell they are doing - red oak? poorly dried white? I can only assume that leading up to the aging process that the distillers could certainly make an acceptable spirit, but when it comes to barreling they fall down. Any thoughts on this.
Posted: Fri Feb 22, 2019 8:33 am
by Honest_Liberty
So I've had terrible results up to this point, here is what I've done:
Cut wood into 6" x 5/8 -3/4" x about the same. Not exact because I used a hatchet.
A bunch toasted at 380 for 90 minutes.
Another few just charred with the MAP torch, with once glowing stopped. I can't remember if i doused.
Put two sticks of each in separate 750ml bottles of 60% sweetfeed double distilled glory, about two months ago.
Been taking random taste tests. Extremely underwhelming and unimpressive, although the nose is the toasted is superior.
The charred smells of new sneakers and tastes like campfire smoke. It's friggin terrible. I'm so disappointed.
The toasted is more mellow, no camp fire smoke taste, but just... Boring and not worth drinking in my estimation.
I am a bit of a whiskey snob. I'll drink and enjoy cheap, don't get me wrong, (Jim Beam black suit me fine for everyday bourbon fix), but when it comes to the work I'm putting in I want to create something I'd pay $100 bottle.
Right now i couldn't pay a bum to take this ish off my hands.
I'll likely go back to Jack Daniels chips and nuclear aging. I sampled my first single pot run I aged that way, about 8 months after being off the oak... We forgot about it...
It tasted incredible! I really wish I could have success with this method but I'm nervous about bulk aging my all grain batches once I have 5 gallons if I'm likely to produce such pure shite.
I don't know what I'm doing wrong
Posted: Fri Feb 22, 2019 10:25 am
by OtisT
Honest Liberty, it takes more than two months of aging on new oak to produce a $100 bottle of whiskey. Patience. My experience with sticks is that I don’t see any turn for the better before 3 or 4 months minimum, sometimes up to 8 before it starts smelling remotely nice, and even then you will still want them to age longer if you can. If you do revert back to JD chips and nuking for your big batch do yourself a favor and stash away a few jars with your sticks in them and try them next year (vent monthly.)
Re: charring. I had a horrible time getting a char I liked but I finally figured it out. This is just my opinion but I think my problem was the gas types I tried in combination with the wrong tool (a small hand torch). The small hand torch had me charring with the torch too close to the wood, and I think it was so close that the gas had not fully burned, leaving a bad taste. The small torch also meant that I did not char all the surface at once, so where I started was more burnt than where I ended.
The solution I found that solved my problem was a propane attached flame thrower. ($20 at harbor freight.). I now char sticks either on one side or two and I’ll do a dozen or two in a single batch. With a pitcher of water near, I line up all the sticks side by side on concrete then blast the entire lot for 25-30 seconds then gently douse all the sticks at once. (Gentle so you don’t knock off the scales of char). With the big blast area, the torch head is plenty far away from the wood and it seems all the gas is being burnt clean, so no more bad smells.
Otis
Posted: Fri Feb 22, 2019 2:59 pm
by Honest_Liberty
Ohhhhhh! Snap! I appreciate it.
I'm going to do this on the burr oak i picked up. Already toasted.
Thanks for clarifying. I must have misunderstood what you tipped originally. Thank you sir!
I'll just set them in the garage and wait. Cool
Posted: Fri Feb 22, 2019 3:01 pm
by ShineonCrazyDiamond
Soak the charred sticks in water overnight to grab some of that "smoke" before it gets in your whiskey.
Posted: Fri Feb 22, 2019 3:56 pm
by Honest_Liberty
Awesome. Thanks. I was worried it would be the opposite
Posted: Fri Feb 22, 2019 5:05 pm
by Little Hank
I really am in no way qualified to give advice here but thought I'd just share my experience. I did a sweet feed run and went to a local wood craft shop and bought a 1/2" dowel rod of white oak. I cut it in 3 5" lengths, baked at 400 for 15 min or just till the aromas started to fill the kitchen wrapped in foil. I have a LP gas stove. I Then pulled the sticks out, light the top burner and stuck the stick in with tongs. I let the dowel rod fully catch fire for about 45 sec. to a min. And the outened it under water for a few seconds. I used 4 sticks for 500 ML and let it set for 4 weeks. This was my first batch of sweet feed and I wasn't really impressed, surprise but after the oak sticks it was much better and I was able to tolerate the flavor. I just started running some all grains mash( just corn and malted barley) and once I get my cuts right I'll try it again so I know if my method will really work to my liking. Once again thanks for all the helpful reading ya'll post.
LH
Posted: Fri Feb 22, 2019 8:51 pm
by T-Pee
Sweet feed + charred oak = 3 months minimum. Leave it alone. It'll come around.
tp
Posted: Sat Feb 23, 2019 9:26 pm
by Honest_Liberty
I heated the bottles I have up on the stove in water tonight. They were out in the cold the last 2 months? Hell, it's been like 3 months already but almost all cold because of winter. I haven't heated up until tonight. They've been placed in the garage tonight. Tomorrow afternoon, back to heating up. tomorrow night back to the garage (I'll repeat 3 more times) where they'll stay until fall.
I'm pretty sure I tossed in the oak before we closed on our newest home, which would have been before Dec 20. It may have been as early as November 20'ish. I think its the torch, plus not dousing (but again, 50'/50 on what I remember doing. IIRC I lightly doused just to get glow done and then set outside, but then again, sh#t I can't remember.. Seriously. I must start taking notes!!! laziness is holding me back.
I did get a very amazing chocolate back end tonight when I tasted the toasted oak bottle (much sweeter but much, MUCH smoother than Makers at 45%. my wife tasted and agreed). It was outstanding. Lingered for nearly 30 seconds in diminishing residual flavor until so slight it turned into a soft memory. Very promising!
both at 60%, 750ml. (I can't tell if the photo saved properly at 600x338. Pardon if it didn't. First time I'm trying this
Posted: Mon Oct 19, 2020 4:43 pm
by Honest_Liberty
So I have had this SF recipe, very tight cuts, sitting oaked in a gallon jug at my cabin at high altitude for about 12 months now. It tastes terrible.
flat. pepper. bland. oak.
it is undrinkably terrible and I'm getting very frustrated with not being able to make a robust whiskey. I must need to add some heads and tails because it tastes nothing like a whisky at all. Then again its a rumsky. I dunno.
my chapitalized concord brandy is aging great though, with the same time, size jar, and oak
Posted: Mon Oct 19, 2020 5:47 pm
by zed255
I'm no expert, but I think anything home distilled has to be put up surprisingly dirty to resemble almost any commercial example. Tight cuts are for drinking white and making loose cuts are better for ageing on wood. Also, I think AG batches will stand up better than any sugar based recipe. Maybe I'm off base here as I'm just really getting into AG now but I can see the potential in these efforts already.
Posted: Sat Feb 06, 2021 3:26 pm
by Honest_Liberty
Zed, surprisingly dirty is the unfortunate conclusion I've reached.
I don't like that conclusion but I've yet to have any craft distilled whiskey that can compare in complexity. It's my understanding the heads and tails provide the complexity, whereas the tightness of a clean product produces boring, flat, sharp differentials in flavor as opposed to fluid flavor cooperation.
Does what I wrote make sense?
Posted: Sat Feb 06, 2021 4:02 pm
by Deplorable
zed255 wrote: ↑Mon Oct 19, 2020 5:47 pm
I tend to agree. Sugar washes are for white lightning. AGs are for making aged spirits.
After I finish this run of CROW bourbon I am in the middle of, I'll be making a 25 gallon wash of Gerber to make a big ol' bunch of neutral. Then on to more bourbons for aging on oak.
Posted: Sun Feb 07, 2021 12:47 pm
by Honest_Liberty
Well, I cut my SF second batch of 5 gallons pretty wide to age on oak. I just tested it after about a month. Yep. This is going on oak.
Followed the T-Pee way but with a recycled half barrel from Lowe's that held red wine.
Sanded, toasted at 380°F, charred.
Put in 15 stick in my 6.5 gallon glass carboy filled with 5 gallons at 60%.
Gonna try to keep my hands off er fer a year
Posted: Sun Feb 07, 2021 1:16 pm
by Bushman
This becomes easier once you build up a supply, I have actually forgot I had some aging now that I have multiple 10 liter barrels.
Posted: Mon Feb 08, 2021 7:43 pm
by Oldvine Zin
Bushman wrote: ↑Sun Feb 07, 2021 1:16 pm
So true Bushman I keep finding barrels that Ive forgotten about, maybe that's only the good thing about becoming old and ...
Think about that you youngsters
Stay safe
OVZ
Posted: Tue Feb 09, 2021 2:27 pm
by Honest_Liberty
Right now I've got the following:
5 gallons 120 proof SF aging on oak
2 gallons 120 proof bourbon on oak with 44 gallon wash at 7% to run this week followed up with a gumballhead on those grains, hoping to end up with 2.5 gallons at 60% for aging stock with other bourbon move to 5 gallon glass carboy on T-Pee sticks I created.
Gumballhead hopefully 1.5-2 gallons cut for white to share
3.5 gallons 100 proof sweetfeed cut for sipping white (will bottle when caps arrive)
2 gallons feintkenshine at 72%
1 gallon feintkenshine at 58% on oak
1.5 gallons concord Brandy at 55% on oak
So I'm thinking I'll have nearly 20 gallons at standard 80 proof before I start my season and hang up the still for 8 months.
Sadly, at the rate I an my friends drink, we will likely go through the white sweetfeed before it has a chance to shine (pun intended).
I make the sweetfeed so I can keep my habit on the cheap and the rest is exploring the joy of distilling.
Also, these T-Pee style sticks are excellent for brandies
Posted: Sat Nov 27, 2021 5:10 pm
by BrewinBrian44
Reviving an awesome thread! Read the whole damn thing.
I posted this in another thread, but thought I’d share here.
I recently acquired a full Buffalo trace barrel that was used for aging imperial stout from some friends at a local brewery. Their beer is world class. I had a concern the beer may have negatively impacted the oak for our uses, but I think I was wrong. I made some fingers that are 1.5x1x4 and am currently testing a single stick in 3 different quart jars of honey bear bourbon.
To get the wood ready, I ground off most of the char layer and also the scum built up on the outside, then cut them to size
First jar. Re-charred, untoasted from the barrel stave. Used the Tee Pee method for charging with my propane torch, until everything had an even glow.
Second jar. Toasted at 400deg for 2hrs then charred the same way. The house smelled amazing, like I was making a desert in the oven!
Third jar. Toasted the same way, but un-charred.
They’ve only been sitting in the jars for a few days, but I’m already seeing how different they smell. The first jar “charred untoasted” smells fruity, almost like stone fruits. Awesome.
The second jar that’s toasted and charred has an awesome vanilla and light caramel coming through.
The third only toasted jar has a very intense molasses/dark caramel coming though. Very rich for the short timeframe.
This is waaaaay too early to indicate any outcome, but more to talk about how different they are. I have a feeling it’ll almost be like 3 different recipes in the end. I plan to experiment more with lighter toasts and different levels of char to find the sweet spot for my tastes, or perhaps blend different jars together to make a more complex final spirit.
I plan on leaving them for 6 months then re evaluate. I might try to replicate a breathing barrel by sandwiching a piece of paper towel under the lid of the jar, could be a terrible idea lol.
Thanks to everyone who contributed to this thread, it was a great read!
Posted: Tue Nov 30, 2021 6:13 am
by EricTheRed
Thanks BrewinBrian44 for bumping this post - you cost me 2 hours!
This has been a most informative thread, so thanks T-Pee for starting it way back when!!
I ran across that toasting chart at the OP of this thread on some other forum (cannot remember where) - and the accompanying article was interesting.
So i found some white oak (not easy here is southern africa) and toasted some staves (20 x 30 x 170mm) for 3 hours at 200°C
Toasted straight on the rack. Came out smelling wonderful and had a dark colour to it - not black, but dark brown.
I then charred 3 - after reading this whole thread - we'll call it lightly and another 3 a bit more
I had no frame of reference (as i had not seen this thread yet) - so decide to hedge my bets!
I had 9 litres of partial all grain at 59% and i put 3 light char into one, 3 light-med char in another and 2 uncharred into the 3rd.
they were wooded November 16th, so 2 weeks ago
The jar on the left is uncharred, middle is light char, right is light-med char
Was going to do a taste on them in a month, but after all the reading today, will wait.
Might do a taste out of each one to get an idea of how they are progressing.
Gotta love this place!
Posted: Wed Apr 20, 2022 11:24 am
by bitter
BrewinBrian44 wrote: ↑Sat Nov 27, 2021 5:10 pm
I found 9 to 12 months was pretty normal depending on the whiskey.. and I was happy with it.. I started testing 1x a month after 6-8 months... Its pretty evident when things are ready some take longer than other also depending on cuts.
B
Posted: Wed Apr 20, 2022 4:05 pm
by BrewinBrian44
bitter wrote: ↑Wed Apr 20, 2022 11:24 am
B
After almost 7 months, they definitely need more time. Some of the good flavors in a couple of the jars have transitioned to earthy flavors. No surprise, the untoasted/uncharred jar tastes like wood, a little vanilla and not much else.
The charred and untoasted jar is a little better, but still has an earthy twang to it that I’m hoping smooths out over time.
The clear winner is the toasted/charred jar. Deepest color and richest flavor. Presents itself with chocolate and caramel with powerful vanilla. I could drink it now to be honest, but no sense rushing.
