Mulekicker's Heat Controller Project
If it plugs in, post it here.
MuleKicker
Post by MuleKicker »
There has been alot of talk about 220V high amp contollers, and I have been talking about building this PWM 220V High amperage controller for some time. So I have it finished, I have done testing with water, while monitoring current flow with an amp probe. Its too cold here to run a mash, and the old lady wont let me do it in the house, so its gonna be a couple months before I can still with it. But I am confident that it works. I have 5 settings in 20% intervals. I have in this one a 25A solid state relay, so it will handle the current most hobby stillers will throw at it. Running wide open my element pulls right around 13A, and my 20% setting pulls 2.5A, 40%-5.1A, 60%-8A, 80%-10.5. I am including pictures of the build and I will post the program I made for the microcontroller. I dont have alot invested considering, and I got most of my stuff from ebay. here is the breakdown:
micro controller: $23
Controller breadboard for circuitry: $8
25A SSR, $20
rotary switch: $4
Box: $4
Heat sink: FREEBIE! (Im sure you can get them cheap, or scavenge from something)
EDIT: Making your own likker.......$PRICELESS! :lol:
Some misc. wire, and electrical supplies
Power supply for the micro controller, I hacked an old cellphone charger. The micro controller runs on 6-14Vdc
I installed a 25A relay, but you can put any SSR in its place for lower amperage, if you like. It just needs to be able to trigger with a 5Vdc 20ma signal. The breadboard is the same size board as the controller and piggybacks right to the top of the microcontroller.
-Control Freak-
AKA MulekickerHDbrownNose
This topic has 60 more replies
Register Login
