Halfbaked wrote: ↑Sun May 17, 2020 6:35 pm
You have 2 heats and an agitation on your controller. Do u use all these? Are you 60 amps input or 2-30 amp connection? If the later does the fan come on with either or big?
I don't run it all at once, but I think I probably could. I have a 50 amp circuit. Each heater goes up to about 23 amps if I do 100% power on the controllers and the motor uses about 1 amp, so that's 47 amps total verified by a clamp meter on one of the 240 legs when I was setting it up. Not exactly a ton of headroom if you're following the 80% rule on a circuit, but it hasn't blown yet. The supply cord doesn't get warm, but the cords leading to the heating elements do get warm. I'd like for them to be a bit lower gauge and will replace them at some point. The fan comes on when you turn on one of the two heater controls, but not the other. The fan isn't temperature controlled.
Because I'm paranoid I never run everything at once, though. I do run both heaters all the way on (11,000W) when doing the initial heat-up until the mash volume temp gets up to around 180F, then I start turning it down so I can start the agitator going for the strip. During the heat up I also drop the power from time to time to run the agitator for 30 seconds or so every 10 minutes just to distribute the heat.
When I'm actually doing my stripping run I turn one heater off and run the other (the one that includes the fan control) at around 15 amps, so that's 3600W. Spirit runs I do at about 2000W.
