Bokakob 54mm x 150cm column
bionut
Post by bionut »
Today i took the plunge and started to work at my column. As the title say is made out of 150cm of 54mm copper pipe.
I made a wood jig for making the flange. Image Started to hammer the flange with very little succes Image
A few minutes later and after annealing the copper the pipe is forming like some modeling clay :D Image Image Image Image
I measured 300mm from the top for the condenser and taped the 2" template on the pipe Image note that i didn't have clear tape so i used a brown one. The lines were still visible Image The job was very easy with a hack saw Image and the result Image
With a little filing the slant plates will fit snuggly Image
I will return with more pics when i will get the solder and the tubing for the condenser.
LE: I had some problems with the pictures host. I hope now it works.
This topic has 112 more replies
Register Login
