NChooch's Carolina Bourbon
NcHooch
Post by NcHooch »
Try this: I've done 7 runs of this recipe and it produces an excellent result . But first, a few words about Bourbon whiskey, 'cause ya cant just whip up any whiskey and call it bourbon.
* Bourbon must be made of a grain mixture that is at least 51% corn.
* Bourbon must be distilled to no more than 160 (U.S.) proof (80% alcohol by volume).
* Neither coloring nor flavoring may be added.
* Bourbon must be aged in new, charred oak barrels.
* Bourbon must be entered into the barrel at no more than 125 proof (62.5% alcohol by volume).
* Bourbon, like other whiskeys, may not be bottled at less than 80 proof (40% alcohol by volume.)
* Bourbon which meets the above requirements and has been aged for a minimum of two years, may (but is not required to) be called Straight Bourbon.
* Straight Bourbon aged for a period less than four years must be labeled with the duration of its aging.
* If an age is stated on the label, it must be the age of the youngest whiskey in the bottle.
* Only whiskey produced in the United States can be called bourbon.
In practice, almost all bourbons marketed today are made from more than two-thirds corn, have been aged at least four years, and do qualify as "straight bourbon"—with or without the "straight bourbon" label. The exceptions are inexpensive commodity brands of bourbon aged only three years and pre-mixed cocktails made with straight bourbon aged the minimum two years. However, a few small distilleries market bourbons aged for as little as three months. <- this might be you :wink:
this is my Carolina Bourbon ....and it's fine tastin'
5-6 gallon wash yield.
I Start with 7 pounds of cracked corn, n cook in 4 gallons of good water for at least an hour (i usually go 90 mins) at a low simmer. ...careful not to burn it.
*optional - you may add a half pound of 6-row malted barley while cooking the corn to loosen it up a bit ( this is called pre-mashing) as it gets very thick.
Then cool to exactly 150f.
Pour into a large cooler (helps conserve heat during the mashing session)
Add 3 pounds of 6-row malted barley ...The temp should drop to approx 145f
...stir well every 15 mins, while you mash for 2-3 hours. Keep covered.
* Note: Don't add malted barley to the corn if it exceeds 155f! the enzymes will be denatured in short order and and you won't get no conversion.the mashing process requires that you keep the mash at 145f +/- 5f for the entire duration of the mash session which is why you use the insulated cooler.
*optional - If you want, you can add a lil beano (we'll look the other way)for additional conversion...and let it continue to mash overnight.
At the end of the mash, cool to 80f and transfer to fermenter (grain and all).
Top up to 6-7 gallons total volume.
Aerate well and pitch yeast (Prestige WD or your favorite yeast).
Ferment for a week on grain.
After fermentation is complete, strain out grain, and transfer wash to boiler. No need to let the wash clear.
*Note: I use a 5 gallon nylon paint strainer bag to separate the grain from the wash.
I distilled with my Bok (removed a lil packing so the spirits are 80% )....make appropriate cuts and dilute final spirits to 60% abv using good water.
I oaked at 60% with 2 pcs of my own new charred white oak sticks for 6 months in a glass jar (once again, we'll look the other way if you dont have a barrel). As long as you're using new charred white oak I think you can call it Bourbon.
Once your agin'/oaking is complete, dilute down to 45% and bottle.
This is what a recent bottle looks like after just 6 months on the oak. I love the color.
...and like I said, it's fine tastin .
a slightly earthy, woody smell with vanillas in it.
and a nice cherry /vanilla/oaky taste that does down really smooth
Cheers,
NChooch
NChooch
This topic has 1044 more replies
Register Login
