Direct Steam Injection
junkyard dawg
Post by junkyard dawg »
I'm a convert. I set up a pressure canner. I have a big all american. I took out the pressure guage and put in a needle valve and attached a few feet of 1/4" tubing. I crimped the end and drilled a bunch of holes. This end went into a 40 gallon stainless fermenter. Put a couple of gallons of water into the canner and turned it on. I was easily able to cook corn and thirty gallons of water. It took a couple of hours to get up to 200 f and takes little propane to keep it hot for hours. Cool stuff that all you struggling with all grain might want to look into.
this is the internet
Husker
Re: Direct Steam Injection
Post by Husker »
Glad there is a 'subscribe article' on this new phpbb, cause I certainly want to mark this topic for quick find.
THANKS for the info JD. This is a no-brainer, once you read it. A very nice method indeed.
H.
junkyard dawg
Husker, this was just my first trial run. I heated a 10 gallon pot up a few days earlier and thought it would work well. It worked beyond my expectations in a thirty gallon mash. (my biggest ever)
Once it gets up to heat and you get a little starch conversion happening it doesn't even require stirring. It won't burn anything. The pressure cooker on a propane turkey fryer was a perfect combo. I could turn the heat up just enough to make 15 psi (250 f) steam. Before I shut it down, I got the whole damn thing to a rolling boil. Next time I get around to playing with it I'll take some pictures of the rig...
Just google direct steam injection for more info than you really need...
be careful... steam is serious business...
Hack
Post by Hack »
I need to get serious about looking into this. I did three five gallon batches of bourbon this weekend just to end up with about ten gallons of mash after straining out the grains. After spending about nine hours cooking mash I realize I need to find a good way to cook large quantities. This seems like the ticket.
Here's a link to some info I found.
http://www.spiraxsarco.com/resources/st ... ection.asp
raildog
Post by raildog »
any pics of the steam wand connections to the pressure cooker?
violentblue
Post by violentblue »
I'm in the process of setting my boiler up for similar use.
I'm reworking my failed stripping column to use steam injection. and I'm building a steam powered mashing tub.
I've been using steam injection, for making gin, for a while now but on a much smaller scale. results are quite nice.
