What should my wash look like?
Hello everyone...
This is my first wash so I'm not sure if something is wrong. I used 8kg of sugar with 21l of water. Water temp after dissolving sugar was around 100 deg f. I added a packet of Alcotec 48 and stirred it up and have let it sit for 5 days now. It has been a steady 70 deg F I just checked it and it seems to have stopped fizzing but it looks the same as day one. It is a solid off white-yellow color through out. Isn't it supposed to have seperated with the spent yeast on the bottom? The only instruction I didn't follow on the Alcotec packet was that I used an airlock. What should my wash look like and at 70 deg F how long should it take?
Thanks in advance
Thanks in advance
If its stopped bubbling then fermentation is complete (as long as it did bubble at some point)
The wash will be cloudy and if you leave it for a week or 2 it will start to settle n clear.
Time is normally as stated on the packet and varies between yeasts (mine takes up to 4 weeks
but thats for higher % 18+ )
Taste it for sweetness if you haven't got a hydrometer. I've just finished a Turbo and if you include the settling time it wasn't much faster than the 16% house plonk I've been making for years.
I already owned a Harris Quickfine so polished the wash with that. I wouldn't buy a Quickfine just for distilling but if you've any plans for winemaking as well it's worth having.
i only ever used finnings when i was after a wine to drink quick n bought a kit that came with 2 packs of finnings the result was a wine that cleared over night
(much quicker than using nothing).
However i prefer to not add to many chems to my wine and i prefer to not use kits to often (unless im low on wine n expectin lots to dissapear at a party).
In short i wouldnt buy them unless i had a stubborn wine that wouldnt clear itself, id let it clear itself with time and i wouldnt use them for my stilling mash.
Good point, rectifier. The commercial companies use fining agents (isinglass, gelatin, PVPP, etc) because consumers (mainly Americans) won't accept a cloudy product. But there's nothing wrong with it. If you made it, and know its good, drink it! (Actually, the dead little yeasties are good for you!) And if your distilling, it's even less of a problem, though you want to remove the majority.rectifier wrote:Waste of money. I don't even use clearing agents in my wine...
Purposeful motion, for one so insane...
